New WoodChat!
Handscrew Clamps.....? *LINK*
Michael Donaldson
Michael Donaldson
I have seen them in nearly every hand tool woodworker's shop, and when I went and got the rest of my dad's tools, I took the ones that he had. But I honestly have no idea how to use them. I tried while clamping up my workbench top (which is almost done...I will post on that adventure when it is finished) but it was a disaster, that clamp got the best of me. I found this article which helps a bit:
http://www.shopnotes.com/files/issues/106/10-best-handscrew-tips.pdf
but I have a few other questions:
1)How are they used?
2)Perhaps I just use too much glue, but I generally have a lot of squeeze out, how would I prevent a wooden clamp from becoming a permanent part of my projects?
ShopNotes
Re: Handscrew Clamps.....? *LINK*
Bob Entwisle in NJ
Hi Michael,
I use a lot of waxed paper when I glue up to keep the glue off the clamps and keep the clamps from becoming part of the project.
I keep a roll of cheep store brand waxed paper in the shop at all times.
Also clear plastic 2" wide packing tape is handy for applying to cuals and such to keep the glue from sticking to them.
Bob in NJ
Robin Corell in Atascadero CA
A good coat of paste wax will go a long way in keping glue from sticking to any clamps wood or metal.
One of the great thngs about wood clamps is that they are wood. Sounds pretty obvious but most people treat them just like their metal clamps. because they are wood it means you can drive screws in them or even drill holes. I'm sure this may sound sacreligous to some but why not modify them to suit your needs? You can always make a new piece of wood for the clamp if you need to.
I have one that has a hole in it that is just the right size to mount one of those articulating arm lights. Actually it has two holes, one from the side and one at 90* to that so I can mount a light anywhere I can place the clamp and it is more secure than those flimsy bases that the lights are sold with and are always missing when you find them at the thrift store.
I have another wood clamp that is screwed to my tenoning jig for my table saw. I think this is a great way to use these clamps because if you mess up and hit the clamp wth your saw it won't ruin the blade.
One of the clamps I have has one of the handles cut into a short knob. it was that way when it came to me and it has come in handy a couple of times.
don't be aftaid to modify them if it will make them more usable, thats what tools are for.
Robin
Jack Guzman from Maine
Handy handscrews
I also keep waxed paper handy. Hand screws are great. Think of them as small vises. I use one with a v cut into the jaws as a holder for drilling holes in dowel. I also use one laying flat on the bench to hold boards on edge for mortising. I don't use them instead of metal clamps but as an extra, a helper where a little improvisation is needed. If you have plenty of them on hand you will find uses for them.---Jack
George Allchin in Lowell, Mich.
I cut up a gallon milk jug into 1" x 2" pieces to put under the jaws of clamps. Glue doesn't stick and you won't mar your project as easily. Wooden paint stick stirrers work well also.
Work safe,
George
Since no one else has covered it...
James Watriss
Waxing and taping seem to have been covered...
Operation is simple.
-Open the clamp.
-Insert wood/ put clamp around wood until the work is just about touching the center screw.
-Close the center part of the hand screw until it's touching the wood on both sides, with the rest of the clamp opening up to a larger size.
-Once the closing gap is set, tighten the outer handle, that'll close the jaws.
-The tighter the inner part is, the better the grip will be overall.
-This is great when done during a dry fit: the throat gap has been set, so if you simply loosen with the outer screw, the clamp is already set up for the glue up.
As others have said, these things are subject to a lot of modification, and varied usage. I have one that's drilled so that I can bolt it down to a threaded insert on my assembly cart. That way I can tighten the clamp around the leg of whatever I'm building, and bolt the clamp down to steady the project and keep it from accidentally dumping off the cart.
That's one of dozens of ways to use these clamps.
"Moxom" vise
Bill Tindall
For years I owned a set of these clamps and never knew what to do with them. For clamping two things together I prefer the metal "F" style clamps with a good Acme thread. But for clamping that involves a change in direction, as illustrated, they are indispensable. I use an F clamp plus one of these to clamp the bar of the chain saw to the bench for filing, as another example.
William Duffield
Instead of drilling a hole to match the post of the articulating lamp (which is usually about 1/2" diameter), I drill 3/4" diameter holes in my clamp, and drilled a half inch hole in the end of a 3/4" dowel, and glued the dowel onto the post. Now the articulating lamp will drop into any dog hole in the shop, as well as into the handscrew.
Love them
rononkokomo
There all kinds of uses. I love Williams's idea. Hadn't thought of that one. Will do it today.
Stephen Shepherd
Stephen Shepherd
I had a couple of those with metal rods and swivels, but I got rid of them and made some of wood. The tightening method is different but almost the same principle.
The reason I got rid of the modern ones is because every time I used them I got pinched and after tiring of that I went to the traditional design.
Be careful, they pinch!
Stephen
Half tails?
Joe shelton
Bill, I'd have guessed you'd be a half-pin guy.
Joe
William Duffield
Both Jorgensen and Lee Valley make and sell hardware kits that allow you to make any size and shape jaws from any species of wood (or Pergo or Corian or termite barf (MDF) or Garolite :D ) you prefer.
I have one, like Jack's, that has a V-groove cut in it, for holding round stock.
I have another with four 3/4" dog holes in the face, that works nicely as a carving vise for holding wide, irregularly shaped stock.
In fact, this evening's census shows that I have 19 hand screws, from size five all the way down to 5/0, and there might be one or two others holding down the fort somewhere.
Bill shows one being used to complement a shoulder vise for dovetailing. If you have four, you don't need the shoulder vise or the F-clamp. Two handscrews hold two more to the top of the bench, and the second pair hold either end of the board being dovetailed.
bob murphy
I have a hundred, or so, hand screws from 5 thru 3/0 and use them very frequently. Got them years ago when a family owned pattern shop closed up.I always use a handscrew when the work piece will be anywhere near a saw blade, or router bit.
I have never seen a pic of a rack, or cart, to conveniently store them on. Any suggestions?
storage suggestion
Bill Tindall
I have one wall of my shop that is just studs. I clamp one of the larger ones securely on a stud (clamp is horizontal) and then stack others atop it loosly engaged onto the stud.
I am curious that you find them so useful. I rarely use this style of clamp. I find them inconvenient to adjust, bulky, heavy and they don't apply nearly as much clamping force as "F" style clamps with Acme threads. They do find employment occasionally, but they are not my "go to" clamps for everyday clamping needs. I can't imagine dealing with 100 of them.
Re: storage suggestion
Bob Hackett
Funny you should say you don`t think they`re as effective as other clamps Bill. Machinists have been using all metal versions of them for holding and securing precision set ups in all sorts of machine work for well over a century.
William Duffield
Some hand screws and hand screw kits use acme thread; others use UNC thread. I prefer the Acme, because I think I can apply more pressure, and can better control the pressure being applied. UNC thread works OK, too, and hand screws using it are usually less expensive than the acme threaded ones.
I usually hang mine on Shaker pegs mounted in the rafters. I another shop where I worked, where there were a lot more hand screws than I have, we got a bunch of all thread and matching nuts, and screwed the all-thread into a 2x6 that was mounted to the stud wall. To keep the all thread from chewing up the wood and threads of the hand screws, we slipped some EMT over the all thread.
To use them without pinching yourself does take some discipline, especially when hanging them up and fetching them. I gave up trying to just hang them at random. I'm left handed, so you might want to do everything in reverse if you are right handed. Mine go jaws up and to the right. Front handle to the right, back handle to the left. I always use the back handle in my left hand, because it is stronger and has more control. Also, when clamping horizontally, I keep the rear handle up.
They can't pinch you if you have one hand on one handle and the other hand on the other handle, and you can make coarse adjustments very quickly, by cranking them like a kite string winder.
Hand screws are capable of applying a lot of pressure, evenly, over a wide area, even without a caul. This is very useful when gluing down veneer, or face gluing two boards.
Edward in Vancouver
I bought a pair of 5" cheapies and found many uses for them. Then I splurged and bought two 8" diy kits (a neighbor unwittingly supplied the maple for the jaws when he threw out a table...) and use them almost exclusively for clamping up panels. Clamp them along the short edges of two boards to keep them aligned and use F clamps to clamp the glue line tight.
It's easy to adjust the clamps if you rotate the handles like you were pedaling a bicycle.
I picked up a old, home made monster at the flea market, 18" jaws and 1" dia. wood screws. I haven't quite figured out how to use this one--yet....
Re: Another Handscrew Use
William Duffield
This is clearly a secondary use, but can be an important strategy.
When gluing up panels using pipe clamps, when all the clamps are attached and tightened and the panel is set on edge to dry, I always do a final check to be sure all the pipes are tight against the panel on both sides. Usually, at least one has a gap. If I leave it that way, the panel is likely to come out warped. The easiest way to move the pipe clamp is to apply pressure with a hand screw, one jaw against the pipe; the other against the back of the panel.
If I keep thinking about it, I'll come up with some other uses. Stay tuned!
Re: Guerilla Woodworking
William Duffield
I recently read someone refer to woodworking that you do outside, away from your formal bench, as Guerilla Woodworking. If you can find a sturdy base, even a 6x6 post or a log with two hewn faces, one of these huge handscrews can be recruited to serve as a very effective vise, clamped either to the top or the front of the beam using another hand screw, or as Bill Tindall illustrates, with an F-clamp. I have a friend who packs two smaller ones when he is traveling, and uses them to clamp smaller scale wood work to the table in his motel room.
roger lance
Michael.....I made a flag box and used 12" Bessey K bodies to clamp the glue up.....the weight of the bar hanging off to one side during the glue up was enough to put a little distortion on this piece in terms of flatness....I compensated for this distortion with the feet making the piece plumb. If I had used wood hand screw clamps, then the weight of the clamp would have been equal on both sides of the joint and the piece would be plumb off the clamps.....if I make another flag box, I'll use wood hand screws.
Visual reference points
Bob Hackett
How many of us use squares, adjustable bevels or other reference points set up on the surface of the work to visualize either square or angled cuts or sight when boring holes?
OK, hands down.
Now, how may have knocked those visual references off the work and then had to re-set them?
See, I knew I wasn`t the only one.
Instead of using the bevel or a piece of scrap wood clamped to the work with a C clamp as a reference point use one of these clamps, set it with the bevel gauge, then reef down on it and lock it in place. Unless you flip the workbench over you`ll only have to set it once.
A substantial visual reference point that`s easy to set, easy to release and reposition, and rock solid when in place. With the proper hole in the right place you can even get that bench lamp closer to the work and make things that much easier to see.
Michael Donaldson
Thanks for all the info
Michael Donaldson
I am now excited to explore the uses for my new clamps.
Re: for positioning work lights
William Duffield
Even when I find a dog hole in the right place for the articulated arm lamp, sometimes it doesn't get the lamp high enough. I built two extensions from 1-1/2" square stock, one maybe 5" high, the other about 15". I drilled a 3/4" diameter hole in both ends of both of them, and glued a dowel into one end of each: 2-1/2" deep holes; 5" long dowels. Now, if I want the lamp higher, I drop the appropriate height extension into the dog hole, and drop the lamp into the end of the extension.
Here's a pic of both light lifters and a work light mounted in a hole in the side of a hand screw.
Here's a pic of the work light mounted in a light lifter, mounted in a hold drilled in the edge of the same hand screw.
And here is an enhancement to the 1/2" hole in the end of a 3/4" dowel that I described earlier. I'd been meaning to try this for a while, and this thread was just what I needed to actuallly go do it. The idea here is to get the 3 faceted adjusting knob up off the surface of the bench, so it can be adjusted without lifting the work light out of the hole. I turned this one from a single block of hard maple, but a rectangular block of maple and a length of dowel would work as well. The lamp arm is glued permanently into the hole in the top of the block.
that was useful
Bill Tindall
I have such a lamp sitting uselessly on a shelf. These ideas may provide it gainful employment.
