Band saw kick-back
Band saw kick-back
Band saw kick-back
Bruce McCrory
Hi, I must be asking Google the wrong question, so I come here since turners use band saws.
I am having trouble with some new bandsaw blades. They "kick" the wood while cutting. I have a Sears, 12" Craftsman. I installed a 3/8", 3tpi blade; the intent is to do some resawing. These are .025" spring steel. The first test scrap, a 2x4 suddenly started kicking and banging. I checked everything..
The blade was welded very close to the adjoining tooth which I thought was the problem. But the second blade did the same thing. The kicking is violent enough to move the blade away from the tire center.
I have always used smaller and thinner blades, and had best results with Sears products. These are made by a local saw shop, however. I am nervous about tension--I don't have the power of my youth, so barely reach the tension gauge mark, barely under. I am guessing what the problem is now.
Are there any solutions?
Thanks, for your help.
Bruce
Re: Band saw kick-back
Doug
My first thought was since the blades are new they might be backwards. In other words the teeth are pointing up. But then I reread your question and it sounds like your blade tension is too loose.
I agree with Doug. If the blade tension is too loose. I think the blade sort of hops on the wheel or something. I bought some new blades that were the same brand I've used for used and had that same problem. I thought I had the tension right but when I added more the problem went away.
Bruce After re reading your post I have a question. Are you saying that physically you can't crank the tension adjust to reach the proper tension? If that's true then you need to clean the tension system. It should not be that difficult to turn the arm or whatever Sears uses to tension the blade to the correct setting on the bandsaw. According to a test in one of the magazines in the last year or so the markings one the bandsaw are more accurate than anyone thought so yours should at least be close.
Make sure the spring is in the tension screw and that all parts are loose and can slide easily. Check the threads on the tension screw and nut that rides on it to make sure it runs freely.
Hope this helps.
adrien
I'm no pro, but shouldn't you have more teeth per inch for resawing?
Nope, 3tpi is about right
For sawing thick material, you need to have big enough gullets to carry away all the sawdust. That means fewer teeth.
Barry L Elder
I have an ooooollllddd Craftsman 12" bandsaw/sander (30 + yrs) and the tension marks are pretty accurate for the little sawing I do. Crank your tension up a little and see if that doesn't solve your problem.
robo hippy
The only type of 'kicking' I have experienced is if the piece is not flat on the bed of the saw. When the teeth first engage, the wood is pushed down till it is flat on the saw bed. That can make some noise. Worst case is if you are trying to cross cut round stock without a sled. Other than that make sure the guides are properly set. Blade tension is also important, but not having enough tension seems to make the blade wander rather than cut straight.
robo hippy
Bruce McCrory
I do appreciate your suggestions. Thanks.
My next guesses were going to be Saw incompatability with the thicker steel band (.025"); and/or the low number of teeth cutting through thinner stock.
This is an old saw, too. I suppose parts should wear out, eventually. I complain that I need new shoulders, myself. I have an old Sears blade (1/2"), but not as thick nor as few teeth. It may give a tension comparison. Blades wider than a 5/16 (3/8, 1/2) always were a bear to tension. I will do some more checking.
The tires are still crowned, with no checks. They do slip over the extra area of the pocket.
One thing I noticed was a sudden change in location of blade to the blade guides. The outer two blocks are barely clearing their sockets. There does not appear to be any obvious marks on the blade guide holders/sockets.
Tracked down a manual. No help there.
Thanks,
Bruce
Bruce McCrory
Robo H., I am familiar with your description. This, however, is a very powerful and loud jolt as the blade passes through the wood. No damage or flaws in the cut faces. And, as noted in an earlier post, I can't find any teeth scarring. I even ran it with the cover off. [Talk about scary.]
Galen Vetterick
I have a Sears 12 bandsaw and the scale has always been accurate using Sears 80" blades. Now that I purchase the Wodturners blades they are sold as 80 1/2".
The 1/4" more in vertical height throws the tension scale off and I have to crank it up to componsate. You did not say what brand your new blades are so could this be the case and just not tensioned like most are saying?
I do have to clean the threaded adjustment rod each time I change blades and use a dry film lube on it after.
Scott Crumpton
You mention new blades. Did you ever have this problem with the "old" blades? Could be a blade problem. If the new blades are a little longer, your tension marks will be off and you will need to adapt. If they are way to long, you may be at the end of your adjustment range and the blades will need to be re-welded a little shorter.
Another possibility is bad blade welds. Is the banging occurring once per blade revolution? Place the blade on your table saw top, teeth up, and check that the back of the weld is flat against the top. Also, looking at the blade edge on does the curve at the weld match the rest of the blade? If not, the weld is bent/bad.
---Scott.
Roger in MO
Roger in MO
Bruce, does your blade tensioner have a small knob that is hard to turn? This was the case with my older Sears 12" bandsaw.
I replaced the knob with a nut (3/8 coarse if I remember) to which I welded a 6" length of 3/8x1 1/2 flat iron bar. On the other end I put a bolt for a handle.
This "crank" makes adjustment very easy. Especially if you have cleaned and lub'd the adjuster. Roger
Re: Band saw kick-back other thoughts
Galen Vetterick
The current blade I have is 0.032" so I'd says yours should be able to handle the blade thickness you have.
I see why they sold me the 1/2" longer blade because with 3 teeth per inch it prevents having two teeth right next to each other. Maybe they just did not get a smooth alignment on you blade with not much gullet between teeth.
I do remember one similar problem and it was I had not tensioned the drive belt in years! When starting to cut green wood for turning the slack belt would slip then grap for a hammering sound. Also check the drive pulley setscrew as the hammering can knock the pulley loose.
Slow your feed speed
Dick Coers
Lots of tips and ideas, here's one more. Slow up on your feed speed. I've seen people move the wood way too fast. To gage speed, make a cut and open up the board. If you see saw dust in the cut, you are moving too fast. A proper feeding speed should let the blade pull all the sawdust out. Another reason to have fewer teeth. Not getting rid of the dust can also cause the blade to wander.
Re: If you saw me running to-and-fro...
Bruce McCrory
Wow! All kinds of things can go wrong!
With better light, here is what I see:
1. There is wear on the blade guide housings. Outside mostly--because I am right handed? This is not new.
2. These are shop cut and welded blades. I have not seen much in the way of blades at Sears, let alone wider than 1/4".
3. The tension adjustment guides are pretty close to limit--about 1/4" free to the frame-stop. No, I have never lubricated anything. No. I don't release tension, either.
4. As best I could measure with a steel tape, the one blade I took off is 80-inches.
5. The blades do not like thinner wood. At least cross-cut. A 2x4 (DF) had repeated beating through the 2-inch (1.5") section. A 3/4" piece was worse, just not as frightening. The bottom face had "tear-out"--big chunks broken off. Feed rate is a creep.
6. I ripped a 4" section of Western red cedar. It felt like going through butter. I will put on big-boy under's and test rip some doug fir.
7. I wonder if the whole frame is collapsing from tension? I mentioned the blade aligning very close to the outer blade-guide housing. The wheels hang on a pot metal, thin-wall case (aluminum) "C-frame", pinched close at the traditional post location on other, heavier saws. The blades run very close to the outer guide housing. The tension adjustment is almost max'd out. And, I have not recently (last few years) used anything heavier than 1/4-5/16 inch, thin blades--probably, .018" thick.
Why can't I have easy problems?
Thanks,
Bruce
Jim DeLaney, Austintown, Ohio
Re: Band saw kick-back - try this
Since you said the blade guides are pushed back, away from the blade, it seems likely that the blade(s) have at least one bent - or improperly set - tooth. When the wide-set tooth hits the guide - and the work-piece - it 'jolts' them, and this is the 'bounce you're feeling.
Since these blades were made up for you at a new (to you) shop, it's possible he got a defective roll of stock, or the roll got dropped and some teeth were bent.
Try - with the saw unplugged and the top blade cover removed - rotating the wheel while holding the end of a piece of wood against first one side of the blade, and then the other for a full revolution of the blade. Look/feel for a tooth that sticks out further than the rest. It'll hit the wood while the other teeth ride past the edge.
If you find a bent tooth, then you can either bend it back in line, or mark it with paint and take the blade(s) back and ask for new ones.
Bruce McCrory
Forgot...
8. The motor belt seems good. I prefer it loose to tight, anyway.
BTW, I would love getting a new saw; but .... A big "but"! Even though this is my most used tool in the shop.
Bruce McCrory
Thanks, Jim. I will check your suggestion. The first blade did have a "weld tic" while running. And then, I noticed the tooth issue.
Another idea:
I could be just more slovenly about cutting, and the bigger blades for this machine simply react more violently.
Bruce
Barry L Elder
Your local "Sears" agent will probably have to order 80" blades for you, and they also have Olson blades which are very good. Pricey but good!
Chuck Jones - West TN
I agree with Scott's second paragraph
I have had the bad weld problem from blades made by a local amateur. The blade ends were not straight when welded. My results were similar to what you are experiencing. When the blade (it happened on several blades) was placed on a known flat surface the back edge was obviously not straight at the weld.
As much as I liked the idea of less expensive and local it just didn't work out. I'm now buying bi-metal blades from an experienced supplier in Nashville and paying twice as much and getting three or four times as much use from them.
Re: Leave no problems behind!
Bruce McCrory
I can't move ahead. Now the breaker is tripping off!
I suspect that is due to the air conditioner and heavy power demand to the house. We rarely use AC in the Puget Sound area. Turned off the vacuum, which helped keep the saw on; and gave me better feed-back for a blade bogging down.
I am ripping/resawing some rough cedar fencing material. And, the saw blades seem to be happier. A safe solution to cross cutting is needed. It's no fun changing blades all the time.
I am going to look into table-top and 3-wheel blades. Thinner kerf should do the same for band saws as it does for other saws.
This poor saw is just too little for what I need to do. Jeesh! Sounds like I am talking myself into something.
Unless someone has the definitive answer, I am going to say the saw is too small for for heavier blades due to possible structural failure of the case. Treat it like a scroll saw.
Re: Thanks, everyone!
Bruce McCrory
Forgot the most important consideration ... Everyone, thanks.
I looked into every suggestion you provided, and they helped to bring other ideas to the table. I don't think this was an easy problem, but rather, a combination of issues that surfaced.
Thanks, again.
Bruce
robo hippy
It should be some thing simple as the blades should not do that. I have cross cut 1 inch stock with my big resaw blade (1 1/4 wide with teeth about 3/4 inch apart) with no problems, and a slow feed rate. I have cross cut 1/4 inch dowels with my small blade, 1/2 inch by 3 tpi. Have you slowly spun the blade by hand (unplugged of course) to check if it runs true that way? You could check for bent teeth as well. If the bearing wheels are worn, that could make the blade bind and it would sound like a catch, but it would be the blade making the noise, not the cutting action. Dad gum it, just can't figure it out.
robo hippy
Peter Hyde
Had exactly the same problem myself on a big 20" General. I buy bulk blades and put on a new 1/2" x 3 tpi to do some re-sawing. Bang bang bang went the wood. Quickly hit the stop button and the brake but not before the blade had jumped out of the guides and twisted itself into the side of the kerf. After some thorough investigating I checked the welds on all the blades I had just bought. Placing a straight edge against the back of the blade revealed the problem on 50% of the new blades. There was as much as 3/16" gap at the weld. This meant the one or 2 teeth at the weld were hitting first and the blade was no longer in contact with the rear thrust wheel. Pretty violent reaction caused the blade to jump forward where the teeth grabbed again and increased the banging. Called the supplier who instantly replaced the whole order free of charge with a huge apology. Seems there was a shift change of welding operator at the time the band stock ran out and the new operator hadn't done an alignment check, at least that's what they told me. The replacement blades run as they should.
