Re: Question about jointer plane
Sgian Dubh
"Does planing both edges equalise tension in the centre?"
Derek, I can't see that it makes a great deal of difference if both edges are concave, or if one edge is straight and the other edge is hollow. Whichever is the case pressure at the mid-point of the two assembled boards will bring the edges together along the whole length, although frequently not tight enough when the glue is applied and the joint needs a series of clamps from one end to the other. The pressure required to pull the (ideally) tiny gap in sprung joints of any sort together should be minimal, no more than the pressure needed to hold a downward facing fairly thick telephone directory between finger and thumb - I imagine you remember how thick telephone directory's used to be, but maybe nowadays the analogy should be updated to a fairly thick book of any sort, ha, ha.
You're more likely to have to bend one board more than another, if that's what you were alluding to, to close the gap if you are dealing with boards of markedly different width where the narrower board would naturally bend more easily than the wider board, whatever concavity is worked (or not worked) on either or both edges. In my work, it's seldom the case that I use equal width boards to make up a panel and I've not come across a problem, although I do like to make sure that each join does have a 'spring'.
Actually, if you think about it, there's no real reason for not making joined edges that are wavy, even markedly wavy, or S shaped, just so long as the edges line up very well without a gap at either end that needs extra pressure to pull it up. I can't recall including this feature in any of my own work but I've done it for employers and helped quite a few people do just this where perhaps they wanted to join two different coloured woods together with a sinuous line, e.g., sycamore and cherry, or maple and walnut.
As to the discussion about try planes and the thickness or thinness of the shavings you can, could, or should get out of them, I don't think I've anything useful to add. I've never measured a shaving of any sort for thickness, it being something that has never occurred to me to do. If I need to plane more off quickly I set the iron deeper, and if I just need a light skim I retract the blade a bit, and that's about all there is to it, although it's quite easy to get a slightly heavier shaving for a pass or two without adjusting the iron, if desired, simply by bending the sole of the plane slightly convex in the hands as you use it. Slainte.
