Lee Valley PMV11 chisel evaluation Part 3
Bill Tindall
Background to help put my evaluation in perspective.
My major use of a chisel is for making dovetail drawers, usually half blinds. I am only going to own and maintain one set of chisels so they most do well as multitaskers. Acceptable ergonomics is a must. The chisel must be comfortable in the hand both paring and chopping to a scribe line. These three essential requirements lead me to reject the hoop handled Japanese chisels as well as the top heavy Western chisels. All these factors led me to make chisels using, at the time, the best steel available for chisel making that could be readily obtained and commercially heat treated, Crucible Products CPM 3V.
I am at the end of evaluating the Lee Valley chisel for drawer making- poplar sides and walnut fronts, a typical combination of drawer materials. Half the chisel operations on each drawer were done with my home made 3V chisel and half with the LV chisel. Edge retention and ergonomic factors were judged. Worn edge pictures will be forthcoming in Part 4 when I can arrange with the lab to do the pictures. It could be weeks, or not.
Edge Retention- The edge of the Lee Valley chisel held up somewhat better than the 3V. The edge degraded in both cases by deformation, not chipping, micro or otherwise. If the 3V had been more optimally heat treated to Rc60-62 instead of the Rc58-60 it was at I would predict the results would have been more similar. In previous evaluations of CPM 3V against Sorby, Two Cherries and a chisel made of M2 this 3V chisel had better, to substantially better edge retention. The bottom line is that the steel in the Lee Valley chisel is exceptional for the tasks involved in drawer building, at least as good as or possibly better than CPM 3V.
While edge retention is nice to have I find edge retention in a chisel less important than in a plane blade, for the kind of work I do. Particularly when edge failure is by deformation the edge can often be restored to acceptable function by straightening it (on a micro level, we are not talking about major edge deformation here) by rubbing on a hard smooth stone, such as a hard Arkansas stone. In this current case I would have done a quick rub of the back of each chisel after one complete drawer (actually two half drawers), though the 3V chisel was in greater need of this refinement. Both still pared acceptably after one complete drawer but I do a quick rub on the fine rock when I can see any deformation with a 10X lens or feel deformation by carefully passing finger across the chisel back.
Ergonomics- In Part 1 I reported on the comfy handle and bolster area on the Lee Valley chisel. My home made chisel blade is 0.140" thick and steeply side beveled. It fits in tight places making owning, or picking up, another chisel unnecessary for removing dovetail waste, for example in half blinds. I found that the Lee Valley chisel functioned equally well for all chiseling tasks involved in dovetailing, including removal of the pesky corner waste in half blinds.
Over time I became more accommodating of the thicker blade on the Lee Valley chisel. I no longer think I will grind it thinner. I thought it would get in the way removing pesky half blind corner waste. It didn’t. It is a bit more comfy to hold down near the bevel than my thinner chisel.
Bottom Line- This chisel has exceptional ergonomics and steel in the context of how I use a chisel.
