help w frame&panel curved in depth and profile
Adam of Oakland
Hello Friends -
I've got a build challenge I've set for myself here, and would very much appreciate some pointers on how you might have a go at this sort of problem. I've posted an extract from 'ketchup below. This is a drawing of a sort of "headboard" for a trundle bed in my guest room. It's built into the corner of the room. Dimensions are roughly 72" in length, 42" width and about 22" high
What makes this piece such a stretch for me is that I really want to have the back curve both in depth, and in profile along the outer "stiles" of the frame.
My current plan is to build this in a frame-and-panel maner. The panel would need to be coopered along some curve. The material I have for the panel is some gorgeous 1" thick redwood that I got from a salvaged water tower here in Northern CA. I think I could reduce the coopering to perhaps 4 facets, and then shape the outer surface with my bench planes. The panel would then be rabbeted into grooves around the frame.
The hard part is how do I build a frame about this panel?
I then thought It might be better to build the frame first, and then try to fit the panel to it. Trouble is it will be hard to cooper the panel exactly to the curved groove made into the stiles along the depth.
I then thought I could do a partial approach where I build the frame and apply a groove to the rails. I'd shape the profile curve along the inside of the stiles, but leave them unshaped in depth, and without a groove. I'd then build the panel to fit within the vertical dimension between the rails. Then, I'd use scribing techniques to fit the curved profile of the stile onto the panel so that it butts up against the inside edge of the stile. Then, I could mark the coopered curve of the panel into the stile, and thereby define where the groove in the stile goes.
Rereading this, I'm almost certain it does not make any sense. If you have any wisdom to share, I'd very much appreciate it. If nothing else, wish me luck :-)
Adam of Oakland, CA
