Lathe accidents avoidance
Don Evans
There are two things I would like to say that I've not seen anyone else mention on this or any other forum.
1. Adrien's post pushed me to this (glad you are on the mend Adrien). THERE IS NO NEED FOR SPEED IN TURNING! I've been working with metal and wood lathes for long time (35 at least years) and I only recall going over the 1200 rpm mark once and that was to see what all the talk was about. This was many years ago and people seems to state regularly that turning small stuff was ok at 3000 rpm. Well maybe a pen once it is rounded but there really isn't a need. You gain very little time between 1200 and 2500 rpm turning if any.
2. With all due respect to Robo, there is NO such things as line of rotation (that danger zone) a chunk of wood coming off a plate or chuck can hit the ways or more than likely the tool rest and go in ANY direction. I've been hurt only once with a lathe and that was due to using a home made holder similiar to a Longworth. It came from FWW magazine and it was over 30 years ago. There were no 4 jaw chucks then for wood turning unless you used one made for metal lathe (knuckle busters). Anyway, in my one experience the wood came loose, hit the tool rest, then me in the head. I did have on a faceshield but it still put me on the floor.
My point here is mostly, turning slower is in my opinion the most important one thing you can do. Slower moving objects do less damage! Second wear best safety equipment you can.
Regarding faceshields make sure it is at least rated Z87.1, this is printed on the shield in one of the corners. This is not 100 percent either, it will not stop a bullet so slow down.
I've never seen anything that must be turned faster in order to produce it.
Don
