Raising the floor.....
robo hippy
A little collective advice is needed, please. I am starting to host more students in my shop. Since they come in all sizes, and I am taller than most, and I don't have a bunch of different lathes, how can I adjust the floor so each student can be more comfortable at the lathe? I did build a plywood platform, which may need to be modified size wise, but I am sure there must be an easy solution that doesn't involve just slipping a 2 X 4 under the platform.
robo hippy
Re: Raising the floor.....
david
If your platform has a skirt all around, what comes to mind is different heights or sets of 4 x 4 in the corners that you could quickly switch out for different height needs. May need to be bolted in for added stability.
Chuck Jones - West TN
I just let the shavings pile up.
Re: Raising the floor..... *LINK*
We use "leg-a-matics" in building platforms for sets. Four or six legs per platform work well for a 4 x 8 platform up to 20" high.
They run about $6.50 each.
They work quite well. You don't really need to put a screw in, though you can if you want. The 2 x 4 fits in quite well.
Leg-a-matic
Brad Vietje
Brad Vietje
Looks like a great solution.
I built a few 36" by 48" frames from 2 x4's with 3/4" plywood on top, which work well for club meetings/demos where a number of different people will try out the lathe. I thought maybe I'd build a set from 2 x 6 lumber, but I like the corner leg brackets -- just have to make up legs in different lengths and swap them.
Safe spinning,
Brad Vietje
Newbury, VT
John Scheideman
If you own a pallet jack you can build a platform to put onto it, park it beside the lathe, and adjust to any height you want. That might work.
John
robo hippy
Thanks for the suggestions. I figured it would most likely come to building an L shaped platform, and just slip some riser blocks in under it. I was hoping for anti gravs, or mini car scissor jacks that could work in unison with the push of a button, or my accountant's desk which is on hydraulic risers so she can work sitting down, or standing up. Just wanted to see if some one had a simple solution.
robo hippy
Only because you asked for different...
John Kaner
1st thought was the traditional two height, lathe length step. Then how about drywall stilts? Then you said hydraulics... So, two hydraulic mobile tables ala Nick cook and remove lathe legs and mount on tables. Now instantly height adjustable and easy lathe mobility!
I have a Powermatic 4224 and I'm building the two step for when I get the wheels.
The club has a 4224 on wheels and it could use a 2' platform in front. I plan on making a 2" on one side and 4" on other. Just slip side not being used under the lathe (between the legs). 4224 has the controller box mounted low on the headstock leg... So, space is wasted...
