Screw lid bottle
Screw lid bottle
Screw lid bottle
I made this last night. I had a Clarinet bell reject made from African Blackwood. I turned the bottom and top out of that. The middle is made from Osage Orange.
I have not turned any blackwood before and it's interesting. It turns kind of like turning acrylic. If you push the gouge too fast you can actually hear it cut badly. I relaxed and let the tool do the cutting and fine little curls came off. I had to make light cuts to do that.
I was going to make the Osage middle a little taller and thinner but a bad spot showed itself. I had to cut off almost 1/2" to save it. The ball is also too small but was as big as I could make it with what was left from the blackwood. Hopefully I'll have the time and the wood to make another one and do it right. I would also make the beads on the Osage smaller and more round and probably make the first bead a tiny bit wider and larger to make it stand out more.
Re: Screw lid bottle
Bernie Weishapl
John I like it. Really nicely done. How was cutting threads on the OO? Did you use like a Sorby hand threader? I have a set but found some woods don't do well.
AWESOME!
GaryG in MD
John, I don't remember you making something like this before, but you should definitely make more!
It's spectacular. You may have another design in your head, but it's hard for me to see how you could improve this one. It's terrific as it stands, in all respects.
My only tiny, tiny nit would be that you might have turned the foot under just a tad more to eliminate that straight edge into the table. OTOH, this may be exactly what you want.
Here's your added "fat ring". It is an added visual "feature", and it does grab the eye. That's neither good nor bad -- just different. You be the judge. ...Gary
Chuck Jones - West TN
John, I like this all around. One of the first things I noticed and liked was the beads in the OO. Then I read your comment and decided I might like them better if they were more rounded.
I can see GaryG's point about the size of the bottom from a pure form standpoint, but man I hate things that look like they are going to tip over. This one looks like it might actually stand up in a slight breeze.
Philip Duffy
I think this is a great piece! How did you cut the threads? Phil
Bernie The beads were cut using the toe of a skew. I marked off the distance using a 2 point scribe and then just cut them using my V cutting technique with the toe that I show in my video.
I do need to make the beads smaller and more rounded for the affect that I want. I may build a tool to do that. I was thinking of making a mini beading tool of some sort. Possible like a threading chasing tool but with rounded teeth rather than 60 degree V teeth like the chasers have.
Yea chuck I'm iffy on the bottom as well. I like the curve to continue all the way down to the table which this one does. I may play with rounding the bottom very slightly to see if it lets the piece "float" a little more instead of being anchored to the table.
See the response above.
Randy Gleckler
Looks like a perfect perfume style bottle. Great shape and form. I gotta get back out and try that threading.
Beading tools
John,
Santa brought me a set of D-Way beading tools. I think they are going to be great. I've practiced with them some and used them on a couple finished pieces. They are pretty expensive, but Santa didn't seem to care about that sort of thing as much as I do. The reason I'm bringing it up is you could probably copy the idea. It's sort of a "turn it around backwards" bowl gouge approach.
Don Evans
John, being this is the first BWood you have done, just for fun next one you do with that wood try this. When finished sanding, take a paper towel and using your finger nail or make a stick to simulate nail use one layer of towel and burnish it with the towel and nail, move across it with some pressure. It will get very warm (hot) so take care, but you'll be amazed at how this wood will burnish beautifully. No finish required...
As far as the turning goes, it's GREAT! Don't change a thing.
Don
Me Likey!
Jennifer Indy.USA
This is cool John. I really like it a lot. The shape, the contrast in woods, the sweet little ball top. It all works nicely.
Nice job!
Re: Beading tools
Chuck before I make the next one, and there will be another because I know I can do better, I will try out some miniature beading ideas. A Dway similar design is possible as well as the new Sorby design which cuts the V and then the bead.
Frank Van Atta
I saw this bottle just the other day, and was intrigued with the shape. While still contemplating how to render the shape in wood I came across this post. This is a whole lot better job than I could have done with it.
Wow! Twilight Zone Time...
