New chuck question part 2, a little long
kellyanderson72
All right so I went to Woodcraft and checked out the chucks and left with the Supernova 2 and the insert for a 1x8 spindle, the lathe is a Powermatic 45 so that should be the correct size.
My problem is this - The lathe came with a face plate and it screws on the inboard side of the spindle but not the outboard side. The insert for the chuck screws on the outboard side but not the inboard side of the spindle. What am I missing? The insert seems like it wants to thread on inboard but just does not.
The label on the package says - Nova insert 1 x 8 L/R w/screw (item 153008). Is this the correct one? I assume that l/r means that it will screw on left and right hand threads?
This is the only insert Woodcraft sells for 1x8 thread but Amazon sells one that a reviewer says will only work on the inboard side, is this what I need? I don't care if it only screws on the inboard side as long as it does screw on the inboard side.
I appreciate any help you all can give me. I have no experience with lathes at all so I am kinda lost.
Thanks
