A55 Smoothing Plane
Is my compressor toast?
david
I have a compressor (5hp-120V) Sears Model 919.16522 made by DeVilbiss. Now when I plug it in, the motor clunks a few times, and the circuit breaker for that power source trips. No matter where I plug it in. It seems like if the motor got through the initial power surge, it would start up, but after a second or two of slowly turning over, the breaker inevitably trips. There is a note on the label: "if protected by fuses, use time delay fuses". Any body else have this issue? Need to determine if it is worth trying to repair this unit or throw in the towel and look for another.
Re: Is my compressor toast?
Dennis in Southern Oregon
David, before throwing it out try two things. First, if you can find a source of compressed air, blow all the dust and chips out of the motor while turning the motor by hand (unplug it first). Often, dirt or debris lodges between the contacts of the starting capacitor switch and causes symptoms like you have. Depending on the motor design you may be able to get at the contacts of the capacitor switch and clean them manually.
If that does not solve the problem, remove the starting capacitor which usually looks like an elongated blister screwed to the outside of the motor with wires running into the motor and take it into an electrical supply store to see if they can match it. If you are unable to do these things take to the motor to a local motor repair shop and ask them to check it for you.
Dennis
Rob C
Try this
http://parts.sears.com/partsdirect/part-model/Craftsman-Parts/Air-compressor-Parts/Model-919165220/0247/0703000
could also be the compressor
David, Rob has a point. Pull off the drive belt and see if the motor runs with no load.
Dennis
Dale Bonertz
Where are you located and where do you keep your compressor? I have several compressors (contractor) but the one I use most is a oil cooled portable at my jobs. When it is cold, like now, it can take up to 10 minutes to get it started. Meanwhile it either throws the built in overload switch or breaker or both. If you have yours in a cold location you may need to cycle it for awhile until the oil softens enough to start the compressor. If this is not your situation then disregard.
Cold location???
david
Those who have been around know that I am in the middle of the Pacific, closer to the equator than most of you :) . Thanks for the responses; think I have a few options to pursue, then I will probably take it into a motor rebuild shop and see what the cost of repair is vs. looking for a replacement.
Re: Cold location???
Many if not all compressors have and "unload" bleeder on the pressure switch. On mine its a little "finger" at the bottom of the switch and there is a little tube that runs to the compressor to it. When the pressure switch cuts the compressor off the little finger bleeds off the remaining High pressure air in the cylinders so the unit will not have to start against a huge load. On mine you can fiddle with the little bleeder itself and bleed off the air. You might try it and see if the unit will start after you blend it. I just ordered one form my ancient Seas compressor.
Dale Bonertz
David,
I had a feeling you were south do to your email name. :) Looks like Hawaii. But one never knows for sure.
David, post the results when you find out what the problem is if you don't mind.
Dennis
Kevin Stanbary in McHenry, IL
I had a bad unloader on one of mine... it would start and run once, then once it shut off I had to empty the tank to get it to start again...
