Starting a chain saw with ether?
adrien
New Stihl Farm Boss chain saw is a bear to start.
Friend suggested spraying quick start ether on the air filter.
Is this a good idea? Or might it damage the engine?
Re: Starting a chain saw with ether?
Steven Antonucci
I wouldn't do it.
steven antonucci
I'd check the plug first, and then get new gas. The gasoline today won't store for more than a couple of weeks, and it makes my saw run like crap. I buy it 1/2G at a time.
S
Something to try
My brother-in-law just got a Stihl weed whacker, and we had the darndest time starting it. I don't know about the chainsaw, but the weed witch instructions call for gas without ethanol, in fact it voids the warranty. So that's one thing to double check. The other thing is that we were able to start it without choking the engine. Maybe we had flooded it prior to that, but watch for over-choking. I think that some tools call for only a few pulls at full choke, before backing off a bit.
Maybe helpful, maybe not.
Harry in Beautiful Downtown Kulpsville
We had a presentation by two reps from Stihl at our last club (Lehigh Valley Woodturners) meeting. These guys knew what they were talking about and had a weath of information to pass on.
First they said that gas only lasts a month. If you haven't used it by then, dispose of it. One way to get rid of it is to put it in your car. Maybe a tad smokey but should be OK. Gas without ethanol is difficult to find. My son recommends getting aviation fuel at a local airport.
Secondly, they indicated that the newer engines are harder to start. When starting from 'cold' with full choke, if the engine Pops after the second or third pull, take the choke off or you will flood the engine and have a really difficult time starting it.
Hope this helps!
Jorge Castaneda
Adrien, my saw is not a Shtill, it is a Husky, but it has a decompression knob on it, starting without pushing it in is a bear, you push it in and it is a breeze.
As soon as I buy gasoline and mix it with the oil, I add Stabil to it and the gas then last a long time and starts every time, summer or winter.
Keith Tompkins
Keith Tompkins
Some ether sprays have a lubricant, but they tend to wash the oil from the cylinder. Apply full choke, wide open throttle. The first time it pops, turn the choke off, leave it on full throttle. When it starts, blip the throttle to release from the full throttle position. Follow each time.
New Stihl's have a very specific starting
Ray - Middletown, In
procedure, make one extra pull and the engine will flood and be nearly impossible to start. Try to find a station that sells gas without ethanol, around here we have a chain called Country Mark that sells 90 octane without ethanol and with Stabil. It costs about $.25 more, but worth it and it lasts a fair amount of time.
Ray
Re: New Stihl's have a very specific starting
bill Crommett
My new Stihl is a dream to start. It is a spring loaded starter model. I use unleaded Premium in all my outdoor equipment and have no problem with bad gasoline.
Chuck Jones - West TN
It's not always the gas.
If it's a new Stihl I'd make a trip back to the dealer. Personally I think too many times we are labeling problems as "bad gas" when something else is wrong. No doubt ethanol, other contaminates, and gas age cause a lot of problems but not all of them.
I agree with releasing the choke after the pop. That's the only way to do it on my Husky. My Stihl starts best with the throttle wide open no matter where the choke is set.
I often use gas/oil mixtures that have been sitting around my shop for months without a problem in my Stihl, Husky, or Echo. I have a large gasoline storage tank that only gets refilled about twice a year. Granted it is ethanol free gasoline. It's delivered by the farmers COOP... which is owned by farmers... who are subsidized to grow corn for ethanol... aint that ironic?
Tony Shaftel
I assume I'll only be embarrassing myself by mentioning this, and not helping you, but FWIW the only time I've ever had trouble starting either of the two Stihls I've owned is when the air filter was way past cleaning time on the first one. I follow the starting procedure already outlined.
John Jordan
I keep gas for months and never have any trouble. A new saw should start easily.
Take it back.
John
Me too John
Dave Peebles Lyons, Ohio
I have gas that is a couple of months old... or older, and my Husqvarna always starts on the second or third pull.
I would like to call BS on Stihl on this one :) But the only Stihl I own is electric, and it does start on the first pull :)
David
"Wide open throttle"?
adrien
Keith, Isn't the throttle the trigger on the chain saw? It would be awkward to hold that and pull the starter at the same time....???
Don Orr
I think ether is a bit drastic. If it is a new saw, as others have said, get it back to the dealer to be checked out.
There is a new product available that is supposed to do something to the ethanol in modern gasoline. Neutralizes it or something. Blue liquid that costs about $10 for a 6 oz. bottle. Label says it also acts as a stabilizer. My dealer said it is a good product. I have noticed no difference yet. My Stihls-chainsaw and string trimmer-start and run fine on mid-grade gas mixed properly with the correct oil no matter how long I have had it.
Re: "Wide open throttle"?
Rick in Colgate, Wi
The starting/choke lever on your Stihl when pushed down to the starting/choke posistion will hold the throttle trigger in the wide open posistion for starting the saw.
This is neat! Lots of help. Thanks
adrien
Bob Lalonde
You could easily get seriously injured with ether. Get it tuned up.
John Jordan
Something else most people don't know. When starting a warm saw, or a cold one that has tried to start on choke, do this: Choke with the throttle locked, and then flip the choke off, but don't touch the throttle-this will hold the throttle open at maybe 1/8 throttle. That's how you give your saw some throttle without needing a third hand. Take your filter off and watch it. I had been through several saws and a couple of decades of sawing before I learned this from a Stihl mechanic. '
John
Keith Tompkins
Keith Tompkins
John, You are correct....that trick may help with a floodded saw as well.
Keith Tompkins
Keith Tompkins
Adrien, Pull the trigger, then apply the choke...it holds the throttle open. Release the choke....throttle stays open until you pull the trigger. Works perfectly.
