*** SURVEY: THE IDES OF MARCH *** *LINK*
Hi Folks,
Welcome to the 69th (!) bi-monthly "Ides" survey here on WoodCentral.com. Hmm, that would be about 11 1/2 years worth of surveys. Whew! I'm amazed that there are any questions left to ask, but sure enough....
This month's survey question is about a side of our craft that nobody wants to think about: Workshop accidents. I'm interested to know if you have had one (or more) accidents in your woodworking past and what you learned, generally or specifically, that might help other woodworkers to avoid similar mishaps.
As always, your responses will be sensitively edited and transmitted to Woodworker West magazine and will appear in their next issue, due out in April.
Thanks in advance for participating!
Ellis Walentine, Host
Woodworker West Magazine
Re: *** SURVEY: THE IDES OF MARCH *** *LINK*
Joe Herrmann
Fortunately, I've only had two "serious" accidents in my 40+ years as a woodworker. The first happened when I was helping student rip a long piece of plywood. I pushed the wood through the saw as you would and bent down to shut off the saw just as he pushed the wood back into the blade. It kicked back and caught me in the upper leg right where the nerves and major blood vessels split to go down to the foot. There was no permanent damage as the Doctors originally feared, but it was sore and I had a rainbow of colors from the bruise for several months.
The second happened as I was helping a student make octagon-shaped rods for a foosball game on the shaper. Just as I was transferring my hand from the infeed fence to the outfeed fence to complete the cut, another student jammed the thickness planer and it made a loud noise. I looked up to see what had happened, missed the fence and stuck my thumb into the 45 degree cutter. Fortunately, all that happened was the cutter removed a bit of meat from the edge of my thumb, but it took several months for it to heal completely.
The moral of both stories: PAY ATTENTION!
Jim in Burlington Ont.
Coffee Table Spill *LINK*
Jim in River Oaks, Ont.
Hi Ellis,
I have been wood working now for over 15 years and , knock on wood, have had only one serious accident. I was building the Norwaldo Coffee Table and working on some blind mortices with my Japanese chisels. I was supporting the work piece on my bench and working the opposite side of the table leg when the leg slipped as I applied a firm paring cut, as the leg slipped, a reflex kicked into support the moving leg and at that moment the blind mortice broke through and the chisel dove into my hand between my thumb and forefinger, deep.
I was trapped with my arm around the leg and the chisel in my hand. I pulled it out and drove my manual Honda to hospital where I received stitches, 8 internal and 7 at surface. The Dr's were very concerned with nerve damage, I nicked a bone deep and had tingling for many years after.
The lesson learnt here was to visualize my process more clearly and support my work better, you should see the scar, it reminds me about the pain every time I see it.
Take care,
Jim
I've been pretty darned careful in my shop but every now and then you do something stupid. One day I was cutting a 12x12 piece of plywood using the rip fence and pushing the wood with my right hand. The blade lifted the piece and it ran across the blade barely missing my thumb. I saved that piece and wrote "THINK" in big letters. I hung it above my table saw. That was the last time I ever pushed a piece of wood through the saw with my hands. Push sticks if designed right work everytime and save your fingers.
Later on I was cutting some 3x3x 3/4" pieces of pine. I know not to use the rip fence and miter gauge at the same time so I had a piece of 3/4" lumber fastened to the rip fence as a stop to set the depth. The wood would clear this auxilliary fence long before it got to the blade. What I didn't count on was the saw vibration. The cut off pieces were sitting on the table and vibrations made one of them rotate so that the diagonal of the piece got trapped between the blade and the fence. It through it back at me so hard it took my breath away and bruised my chest. Bear in mind this was a very light weight piece of pine. I now have 6" spacer block to use for those kinds of cuts.
The only serious injury I've had was while taking a chip carving class. She had told us not to put our hands under the carving. That worked fine for most of the day. However toward the end I did and the wood broke and I stuck the knife very deep in my hand. I wiggled all my fingers and everything seemed to work so I didn't go to the doctor. Big mistake. After it healed I found out that I could not move the last joint in my little finger. Being a guitar player this forced me to learn to play completely differently. I'm through being tough. next time I'll wimp out and go to the doctor.
matt overton
My fingers can tell many stories about many scars, but only one from woodworking. I was 30 years ago in college. I was working in a friend's shop, using a jointer, when I saw his dog move out of the corner of my eye. I turned my head... You guessed it my thumb slipped into the blade. I was extremely lucky, it just took a chunk of the skin off the end. After a couple months of tenderness, all was back to normal. THE MORAL...PAY ATTENTION. I love my dogs, but they are not allowed in the shop if I am working with any machines!!!!
Keith Tompkins
Re: Coffee Table Spill
keith tompkins
Hi Jim, I did the same thing..I was finishing a blind mortise for a cabinet shoe when the wood gave way, a 3/4" chisel entered my left palm and exited the side of my hand. Same thing; drove myself to the hospital. The ER nurse put my hand in a bowl to soak; I called her back when the bowl overflowed; I thought she was going to faint. I'm missing the tip of my left hand middle finger...table saw. Couldn't play guitar for over a year. Both when I was 18. None since, fortunately. I have seen some horrific accidents over the years.
A few years ago lightening hit an oak tree in my yard. I had heard stories about lightening doing strange things to wood, so I cut a piece and put it on my lathe. It had been a long day and I was tired, so I thought I would just turn it to a cylinder and see what it looked like before quitting for the night. I usually put my face shield on fist, but this time my left hand found the switch and BAM!, a 14" by about 7" chunk flew off and hit me right between the eyes about an inch high. Sunday night of course. A friend drove me to the hospital. 27 stitches later I was home. Three morals. Be sure the work is properly mounted and secure, and put the face shield on first, and don't work tired.
Recently I had a small metal backed brush resting on top of my fence on the table saw. Apparently I knocked it off and it flew back and hit my middle finger on my right had. Nothing more that a serious scratch, but it has been reluctant to heal and I am thrilled it did not hit me in the face. So, Stay alert, and keep the work space free of potential projectiles.
In almost every case where I have been hurt it was from inattention. It only takes a split second or a failure to notice the potential threat. Practice good work habits. Use the guards and safety gear. Stay alert.
Respect the bandsaw!!
Ed Moore in SW VA
I was rushing and pushed too hard while ripping some walnut. Even though I was standing to the side, the piece jammed and the wood rotated my right knuckle into the blade. My wife drove me to the ER where I was ushered to a table where I was examined by a doctor who immediately called in an orthopedic surgeon. I decided that I didn't want to watch, so I laid back and put a towel over my face. The surgeon came in and asked why the towel was over my face. I responded that a nurse had come in, asked me if I had OD'd on ugly pills and left, so I figured that if I wanted someone to look at my hand then I had better cover up. He worked on my hand and never realized that I was joking so he never saw what I looked like until I went back to have the stitches removed. A couple of nurses peeked to see who I was, but not the surgeon. He is known to be task oriented. My family doctor told me to expect the finger to take 18 months to feel almost normal. It was 18 months ago, and the doctor is correct.
Ed
Re: Respect the bandsaw!!
What a year you have had my friend... I am so glad you are past this and other things,
Take care,
Jim
George Taylor
Stay focused until it stops spinning
George Taylor
You can't start relaxing when you hit the off switch.
Be it blade or bit ... a table saw blade can still cut at half speed. ;)
Nice scar on the pad of my thumb.
George
Listen To Your Gut
George Guadiane
I was working on an identical Powermatic to the one I have, on the inside of a bowl with my friend's scraper. It was ground at a different angle from mine and he had set up his SHORT tool rest to do the work...
I was not comfortable with the tool OR the short rest, but I kept on turning...
The tool finally started cutting and went straight to a catch. The catch pulled my hand in between the rest and the spinning bowl.
I pulled it out VERY quickly and managed to spray blood on the bowl, the lathe and ceiling. I was VERY fortunate, I didn't break anything or cut any tendons or ligaments or arteries or the like, but I added insult to injury by not going to the emergency room to get the stitches I knew I needed.
It was an uncomfortable education but a GREAT one. Now, the moment I'm out of my safety zone, I stop and reassess. I don't care much for pain.
Joe Fleming
Joe Fleming
30+ years ago, I was cutting small pieces on a tablesaw for an inlaid coffee table. Pieces were assorted sizes, but all in the 1" x 1" range. I used a push stick in my right hand to push the pieces through the tablesaw blade and then I used my left thumb to flick the cut pieces into a coffee can behind the saw. One piece slid back into the blade and pulled my thumb with it. Since the inlay was 1/4" think, I received a 3/8" kerf through my thumb. A bunch a stitches were required.
Lessons learned I no longer plan the cut for safety. Instead, I plan the entire operation around the tool for safety including: where the wood will be before the machine is turned on, where all of the push sticks, jigs and supporting fixtures are located for the operation, and where the wood will be when the operation is complete. I plan for where accessories are to be placed before, during and after each operation so they do not interfere, and the same for all wood pieces so they do not vibrate into harm's or my way. All of this planning occurs before I begin. I have never had another injury since - knock on wood.
The coffee table turned out quite nice. I gave it to my girlfriend for her 18th birthday. She's been my wife, now for almost 27 years. I can still point to the bone chip in the table :-)
Respect the bandsaw!! And thanks ...
Ed Moore in SW VA
for your kind thoughts. I must still be reassessed for the bladder cancer, but the excellent doctors are optimistic that it is behind me. Now to regenerate some energy and get ready to teach "Ornaments" at John C Campbell Folk School in may.
I have been blessed with the prayers and kind thoughts of many wonderful friends. And I thank them all.
Ed
Chuck Jones - West TN
Eye damage
This didn't happen in my shop, but it was definitely woodwork related.
Three years ago I was removing porch railings that my youngest son had installed many years before. Like his dad he doesn't believe in making things that fall apart. He had screwed and plugged the rails so well I had to cut them with a reciprocating saw about an inch away from the posts. I was using a cold chisel and hammer to bust the end grain to get the remaining pieces off. One piece got stubborn and so did I and I hit the chisel perpendicularly which sent the piece spinning and it flew right into my right eye. Felt like a mule kick.
After three years of more office visits than I can count, a couple surgeries, an outstanding Ophthalmologist, a retina specialist, and twice daily (trauma induced) glaucoma medicine, I still have fairly good vision.
I have always been diligent about eye protection in my shop and with some of the equipment I operate around the farm, but I didn't have safety glasses handy on the porch that day. I do now. They are in my left shirt pocket. Specially made bifocal polycarbonate glasses that I can and do whip out in a heartbeat.
The glasses cost me about $300. I don't know what all the medical care has cost my insurance company because I haven't kept track of it, but I estimate easily 30 or 40 times that amount.
woodspinner
Just last month I cut the end of my little finger on my left hand.I was extremely lucky that it wasn't worse.
I was cutting green poplar into rounds for bowl blanks,I was using a reg.tooth blade on my 18" Rikon and the green wood loaded up in the blade gullets and grab the blank which caused my hand to get thrown into the blade. It cut the end of my little finger but mostly it pulled the inside out ,with no one home I had to put it back together and slap some band aids on it .Probably should have seen a Dr. but it healed ok.
Main mistake should have used a skip tooth blade with large gullets as I usually do with green wood.
charlie belden
"Four square" means edges of boards can - and will - cut you.
A mortising chisel stuck in a mortise WILL often come loose suddenly - and if you're chin is in its path . . .
Our instinct is to try and catch falling objects. If the falling object has a razor sharp cutting edge - it's hard to over ride that instinct. Despite the fact that the cutting edge is relatively small - it'll always beat those odds - and you WILL bleed.
If you're NOT wearing safety glasses - things WILL get into at least one eye.
Never try to brush off the "raggedies" on the edge of a piece of ply with your bare hand.
When things are spinning, especially if they're spinning very very fast - their outline can get blurry - or invisible. Even though you can't see them - they CAN and WILL bite you if you get careless.
A shaper spinning a 7" diameter cutter head with knives is stronger than you are. A power feeder of appropriate horsepower - set up right, on the other hand can control feeding the stock way better than you can. Unless you enjoy chasing your part down the driveway - or don't mind it sticking out of your stomach or chest - don't hand feed stock to a big shaper.
Stock control when using power tools can save you a lot of grief - and some blood or body part(s). So whenever possible, clamp the part down or use Hold Ins, Hold Downs and Push Sticks.
NEVER try and use a power miter saw, even if it's a sliding compound miter saw - to cut into end grain. Power miter saws ARE NOT to be used for a Rip Cut, even a short rip cut. That's what a table saw and rip fence are for.
The Tormek's wet wheel WILL abrade off you're finger tip(s) - and you won't notice it - 'til you start seeing blood on the end of the tool you are sharpening. Same goes for japanese water stones.
Tall boards leaning against a wall CAN, if accidently bumped, fall on you. The taller or thicker the board, the more it will injure you.
Check to make sure the band saw blade is tensioned BERORE turning the saw on.
When doing repetitious tasks, especially if a power tool is involved may be boring. And THAT's when you REALLY have to be careful. Complacency can easily lead to carelessness. You CAN'T be careless when working with sharp tool, hand powered or spun at ungodly rpms.
If you hear a "beat" when your band saw is on - it's probably either a bad weld or you've got a kink in the blade. That repetitious beat is a warning message that the band has a problem and may be about to snap. A 2 or 3 hp motor - will accordian 30" of blade into a 10" space. Getting it back out is a real hassle - even if you're wearing leather gloves. And the time lost changing your pants - and underwear - could have been better used ; )
NEVER try and use tools - hand or powered - when you're bleeding. Makes things slippery - and blood stains are REALLY hard to get out of wood.
Steven Antonucci
My two worst (not that bad, knock wood)
steven antonucci
The infamous "cut through cured CA glue" on the lathe to have the uncured glue under it flung into my eye. Instant searing agony. Drove to the hospital with one eye open. Chemical burn on my eye, chemical conjunctivitis for 2 days later. Pain in my actual eyeball... no fun.
Also, was just back from a West Coast trip and after a day of travelling, I was tired, but I decided to taper some legs on a project. The saw grabbed the leg and slammed it against my thumb nail, splitting it most of the way across. Hurt enough to make me nauseous. Took 6 months to grow out.
Steve
Dick Hines
Re: My two worst (not that bad, knock wood)
Dick Hines
After reading what has happened to others I count my self lucky that the worst thing that has happened to me in the shop is the loss of some skin and a little blood.
I was brought up in a wood shop and my father and grand father tought me well, it seems.
Joe Herrmann
Gosh Charlie, I certainly hope these are not all "experienced" related anecdotes!
Re: Respect the bandsaw!! And thanks ...
Phil Powell
Band saws scare me to death! I was cutting turning blanks that were possibly
to thick for safety and the blade broke. An end snapped around, hit my left hand
and cut off my little finger and cut deeply into my ring finger. A neighbor took
me to the hospital where an amazing surgeon put my hand back together. My
hand isn't 100% but closer then I had expected. I did learn my lesson.
David Walser
I've been fortunate. All my personal woodworking related injuries have been of the sort that can be properly dealt with with a band-aid or two. The most embarrassing of these is when I had filled a bucket with turning tools (sharp-side up, naturally). I placed the bucket next two my workbench as I gathered other items for use at a meeting of our local turning club. I dropped one of those items and, while facing away from the bucket, squatted to pick up the item from off the floor. As I squatted, I sat on top of the bucket - ruining a pair of brand new jeans and giving myself a couple of U-shaped puncture wounds from my freshly sharpened bowl gouges. Due to the location of the wounds, I needed my wife's assistance to cleanse and bandage them. She reminds me of my stupidity every so often and even claims I have a couple of U-shaped scars from the incident -- something I have to take her word for.
What did I learn? Sharp edges need to be covered. It protects both the edges and you.
Carole Valentine
I probably don't need to say that a face shield would have protected your eye from flying CA. ;)
David Walser
Years ago I managed a crew at a furniture mill. Our crew rough cut all the parts used by the other crews to make the mill's products. Since the parts would be cut to finish size later, the emphasis was on production rather than accuracy. I tried to balance that emphasis with an even greater emphasis on safety.
As part of my daily routine, I tried to spend a few minutes working with each member of my crew. While working with one of my men, I noticed that "Mike" consistently failed to use a push stick when working at the tablesaw. In addition, he had the habit of using his left hand to push the off-cut past the saw's blade -- no matter how small the off-cut was. I tried several methods to get Mike to adopt safer practices -- I told him how I'd once had to sift through the sawdust to find someone's severed finger so I could rush the finger to the hospital to be reunited with its owner. I painted a "danger zone" in red on the tablesaw and told Mike he HAD to use a push stick (or could not use his left hand) within the danger zone. Finally, I swore in my wrath I'd fire Mike the next time I saw him failing to abide the safety rules.
About a week after I threatened to fire Mike, I took a day off to attend to personal business. The next day, I resumed my usual practice of spending some time with each member of my crew. Whenever I tried to work with Mike, another member of the crew would come to me with something needing my immediate attention. Or, Mike would be in the lumber stacks pulling wood, or another crew member would strategically place a pallet of parts to block my view of Mike's work station.
I'm not the brightest guy in the world, but even I caught on after a couple hours of everyone pitching in to keep separated from Mike, so I called an impromptu team meeting on the shop floor. Mike was in the back of the group with several others standing in front of him. I called him forward and asked him to bring his left hand from behind his back. His hand was heavily bandaged and I asked for an explanation. (In violation of the rules,) he'd used to to push a small off-cut past the blade and, in the process, he'd sliced off the tip of his left thumb.
Everyone at once started pleading for his job. I silenced the group and asked Mike if he knew why I'd threatened to fire him if I caught him violating safety rules. He said he wasn't sure. I told him I'd have rathered fire him than see him injured. Firing him would have been my last resort to prevent his being injured. Since he had already been injured, firing him wouldn't serve any purpose -- unless he hadn't learned his lesson. He claimed he had learned and he had. I never again saw him use the tablesaw unsafely.
The lesson: Some of us know the safety rules but ignore them. If we are one of those, we will eventually learn through personal experience why the safety rules exist. Mike did. When I was promoted to run the cabinet mill, I recommended that Mike take over the parts crew from me. His crew had an impeccable safety record. I heard he'd fired someone for failure to follow the safety rules, so I asked him about it. He said he'd decided to teach each man the safety rules for each piece of equipment and each was warned he'd be fired the first time Mike caught him violating the rules. I smiled and raised an eyebrow. He replied, "I know you gave me a second chance -- several times, but you did that one time too many."
Steven Antonucci
Actually, changed another bad habit too
steven antonucci
I no longer use CA glue on the lathe. It's possible that you could have been standing near and not even turning and had this happen. So, I no longer use CA to glue small things to a waste block. My kids are often in the shop with me, and I can't take the risk.
Steve
Terry Scott
This may seem like I am an accident prone drongo
Many many years ago I did my time as an apprentice carpenter.
In those days we used to make all the joinery and the foreman was showing me how to cut miters on a bench saw .The architraves were 6 meters long .I was on the saw end he was supporting the end as I fed the piece into the 10 inch saw he stumbled casing the timber to jamb and hence throwing my hand into the saw cut 2 fingers off
One was a 4 hour op to sow back on the other is a stubb
I laugh know as I turned around swearing and kicked a block of 2x4 that was unbeknown to me ramseted to the floor
I broke and shattered my big toe.
Sure took the mind of the fingers
my fingers just dont want to stay attached as 6 months latter I took the tip of my left index finger with a buzzer ,a few years later got caught up in a log splitter having another finger glued back on
Oh and then there was the small toe cut off and glued back on
My wife says if I was to go under a light that shows scare tissue all my body would show a scar
The hardest thing to have done is to let your wife sow you up while cursing offshore (my wife a nurse) had to stitch me up when a block came off the deck in a storm and sliced me open up the leg like a tin opener
So to answer your question what have I learn t slow down
