Survey: How many of you have more than 1 lathe?
Mike Schwing from Md.
>I'm considering buying a "mini" for turning collars and what not so I don't have to remove work from the big lathe and set it up for small vs. large turnings. Of course I can manage with one big lathe, but I'm curious about how many of you have multiples, in use, for this sort of thing.
Danged that slope is slippery.
Re: Survey: How many of you have more than 1 lathe?
Joe Herrmann
>I had a small mini-lathe in addition to my old Conover. I never used the nini and eventually sold it in like new condition. I'm going to be in the market for a different lathe sometime in the near future and will probably keep the Conover too.
JanManuel
>I have 2....
First is an older Rockwell 12" lathe...
Second is a Delta 16" x 54" bed....
I use both of them all the time.......
chris rolke
>i have 3
#1 craftsman round tube
#2 jet 1236
#3 jet mini
love them all
2 wood, 1 metal
Fred in NC
Bob Hackett
>Conover for large spindles,Large bowl lathe,Shopsmith 10ER(because I can`t part with it) and hopefully Jorge will adopt the Record(which was a good transition lathe before the Conover).
I don`t see how anyone survives with just one lathe.;^)
Mainely,Bob
Have owned 3, never more than 1 at a time
steve antonucci in NW New Jersey
Count me in!
Dominic Greco at home in sunny Richboro, PA
I have a Delta Midi and the Jet JWL-1642. I use the Midi for small stuff like pens and bottle stoppers. But it's also useful to leave my buffing wheels in when I'm in "production mode".
See ya around
Dominic
TDaniel
>Mike, I make my living on my lathes so I keep 2 busy all the time and we have a mini for finials and such. My main lathe is a VB-36 where I work 90% of the time; then I have the big VL300 when I need a tailstock......I may replace it soon with a VB-36 with a tailstock but for now I think I have a pretty good combination. Could I make do with one lathe? No way. There are many times when I have the Kelton hollowing rig set up on the VL300 and the deep hollowing attachment on the VB. I will work a while on one lathe and then switch to the other, either for comfort or for better visibility. I have adapters for the VB that allow me to use the chucks from either the VL300 or the mini on the VB. Time is money and anything I can do to save a few minutes puts meat in the beans.
TD
Terry Quiram
>2 here. A Stubby 750 and a Jet VS mini.
Terry
Kevin Gerstenecker
>2 here as well. Delta 1642 VS and Jet VS Mini. I use both.........the Jet Mini is a solid little machine, and I enjoy turning small things on it just as much as the big boy.
General 26020 & JET mini
Jennifer@Indy.USA
Lathes: 3
Chuck Ludwigsen
>I guess technically I have 3.
1. Jet 1236. Got it in February and love it.
2. Shopsmith 510. Don't turn much on this anymore unloess I have someone over and we both get to turning.
3. Buffalo Lathe that was made in 1983. Not the sturdiest set of ways (1" bars) and only a single bearing headstock with a solid spindle (no morse taper). But heck, it has a 14" swing and only cost me $50 when I got it in 1997. Now it sets at my friend Ryan's house and he is turning some pretty cool stuff on it.
*4* I really want Jet mini or better yet a Vicmark for small turning and to travel around.
Chuck in Memphis, TN.
Mark Kauder. Phenix City, AL
>I have waited a long time to say this....TWO, TWO, I have TWO lathes. Vega 2400 and a Jet Mini. Since I have only had the Vega for a week, I can only assume that I will use both, though with my small shop, it will not be an everyday occurance.
Mark
Keith Tompkins
Keith Tompkins
>I have three, but plan on purchasing a mini for demos at schools, etc.
I could be a lathe collector...I want a PM 90 and a big Oliver....and a big old Delta and...
Keith Tompkins
oops, forgot
Keith Tompkins
>The reason I wanted to post, is with the General, I can turn outboard if I have the lathe set up for something else. Kinda like having an extra machine.
Lemme See?
Jim Shaver Oakville, Ont
>Hi Mike,
Own a General 160-1 and a Jet Mini, I love them both!!
Take care,
Jim
BubbaBob
>Jet 1442 and Jet 1014.
BubbaBob
We have 6
Phil Joines, Krum, Tx
>SWMBO uses a Delta industrial with risers, it's 17 1/2 x 48. My Nova 3k with 3 bed extentions. Jet mini, Carba Tech mini with 1 1/2hp motor :>). Home made bowl lathe, 94" swing, no bed, 3hp motor.
I just picked up an old wood/metal compo lathe that needs rebuilding. Doesn't have a feed screw so it can't do threads :>(.
Except for the combo we use them all depending on the project. We do a lot of turning.
Roly
>One 30 year old cast iron Delta, my main machine. Then there is the little Dihatsu with the 3/4 bolt thread, under powered mini. The third one is a Sears pipe-tube that is like new and smooth as glass. The 4th one I want is one my dad made when I was little, has wood ways, a pillow block head stock and washing machine motor. My brother has it now in his attic and I have to talk him out of it. That will make 4.
Roly, suffering through a suspended turning attempt in the shop, 5 hours so far, whew.
Do it Mike....
KurtK in Indy
>You can't go wrong with a mini. I have the PM3520 and a Jet Mini. I keep my buffing wheels on the Mini and turn the bowls on the big one. I also can take the mini with me if I go to a WW get together and want to have my own lathe available for use. It sure makes getting instruction from wandering experts easier...you won't have to wait on someone else's equipment.
They are also really affordable...almost a no brainer...BTW...the Jet is the cream of the mini's IMHO.
Kurt
Old Jet 1236 & Jet mini
Dave Smith, Longview, WA
Phil Lieberman
>I have HF 12 x 36 and the Delta 14 x 40
2 - Jet 1014, Nova Mercury. Use 'em both!
John Crissman
Jet 1642 and Jet 1236
Brian MacDonald - Olympia, Wa
