The A2 Steel Debate Going on Elsewhere
david weaver
Summary of it - David Charlesworth has brought up again that he sees nothing wrong with A2. I don't participate where the discussion occurs, but I'd like to suppose a couple of things.
1) the question was asked, why is A2 used at a higher cost if it's not better? The question is better for who. It's better for the maker because it's stable in heat treatment and doesn't warp much. I don't think makers wear an apron and hand-adjust everything anymore, and LN likes to finish their irons nicely. Whatever is flatter is going to win in their book.
2) what did LN use before A2. W1, not O1. They had trouble with the heat treatment and only hardened part of the iron. George Wilson asked them about that, and they said they didn't think anyone would use the whole iron (I guess they did get through the hardened area with a few at williamsburg. George suggested A2 to them as an alternative - something he's used longer than karl holtey, and i'm sure lots of small toolmakers did). They declined at the time. I didn't hear a reason why part of the W1 iron was hardened, but I'd bet at Lloyds that it was due to warping and cracking.
3) The surface is fine off of A2 - yes, it is, if you're scraping or sanding. Someone like Brian Holcombe who finishes furniture for sale off of the plane won't like it, because the tiny fracturing leaves little lines all over surfaces. Not big ones, just little ones
4) something not said - I found when I got my metallurgical microscope that A2 will give up chips just to the stone on washita stones. It's a one off issue, and not an issue at all for someone who doesn't use a washita. I do. Simply because either by itself or as a pair with a fine oilstone of some type and a grinder, nothing is faster for sharpening. And you can sharpen anything on stones like that in any direction (gouges, little knives, moulding plane irons.). Once you leave the simplistic world of taking off planer marks or four squaring a board, those things become important. You can use waterstones to do them, but it's less productive.
5) If you're trying to get finished surfaces, you will spend more time sharpening A2 irons. This wouldn't be the case if they were 59 hardness, but LN and LV are a few clicks above that. I'd venture to guess that if all O1 was 62 hardness, people would complain about sharpening. If it's left with little temper (O1), it can be as hard to sharpen as white steel and harder than typical A2.
6) A2 holds up better than O1 - well, sort of, but not really. Compared to O1 that's not as hard, it holds up better. If chisels are hardened to the same level, the edge retention is probably similar overall. The fine edge use is in favor of O1 (as in, if you want sharp chisels and are touching them up often). Plane irons made of really good O1 steel (hock's irons are not the best I've seen, so you can't use them as a comparison) seem to hold up in practical use as well as A2 does, except they take less chipping damage at the edge and the result is less sharpening time.
7) the wire edge is tougher on A2 - it is. The solution to that is to go finer and more aggressive abrasive. That's something that someone using a guide would do. Freehand sharpeners, especially who roll up their tool on the last few strokes, will appreciate a slower stone for more control.
What's better for beginners? I have no idea. When I was a beginner, I did like A2. I followed David C's sharpening method, but it is less productive once you're not a beginner, and it leaves you hamstrung when you want to sharpen complex things (whereas basic understanding of angles and trusting your hands and eyes doesn't.).
I could work only with a shop full of A2 tools, but what drove me away from them (and I don't think anyone is a bigger pig here in terms of wasting money on tools) was wanting to finish flat surfaces off the plane. A2 is marginally less pleasant to sharpen (in the way that mediocre red wine isn't quite as good as a good dry red wine). The reward for being less pleasant to sharpen is that it chips more easily and if you're finishing off the plane, it can occur on the first few passes. If you're sanding or scraping, that doesn't matter.
Bottom line, it's used because it's good for the maker. Comparing most O1 irons to LN's A2 (I have used irons and looked at them under microscopes - LN's irons have held up the best for fine work in the half dozen or so that I've looked at) for longevity and sharpening both the same way is not an apples to apples comparison. No makers that I'm aware of make an iron that holds up as well as Steve Knight's O1 does (it's pretty much even with A2, but leaves a better surface), but I have had success making similar quality irons with Starrett and Precision Presto O1 and leaving them around 62 hardness.
If anyone likes the tools they have, I don't think they should buy something else just to do it unless they're curious like I am. I have what I like now, but it was fun to look at all of the stuff.
I'm not sure why we use beginners' experience as the calibrator of everything. That's sort of like going to Vic at LV and asking him about the double iron.
I still think, too, that many people would be well served to get rid of the notion that you can't get anything done by hand with heavy work and do a project or two totally by hand. Their sawing and planing would advance leaps and bounds, and some of the things that warren and brian like would make more sense.
Re: The A2 Steel Debate Going on Elsewhere
Re: in all of this...
david weaver
..I don't think I could identify any set of tools that I've ever gotten that would affect what's made, other than the aggravation of finish planing with A2 when nothing sees the wood after that other than some shavings to burnish the surface a little bit.
I know this topic isn't that interesting to some. I used a stanley 4 and a common stanley bench chisels to make a cocobolo plane to see how much trouble it would actually be (stock iron on the stanley plane). After setting the cap iron on the plane, the hardness of the iron became less critical.
The stanley chisel didn't hold up that well mortising the plane body, but an adjustment of a couple of degrees more than a japanese chisel and it held up fine. In 30 minutes of mortising or so (probably less), I think I sharpened once at the first sign of significant damage, and after improving the angle on the edge (not the whole chisel, just at the edge), once more after that.
Use of the cap iron was a much greater differentiator than would be iron hardness or alloy type.
David often mentions how bad stanley stock irons are, but he only mentions using the worst stanley irons ever made (the alloy rounded top irons - those are pretty bad sometimes). When I put my bench together (ash), I smooth planed with one of those irons in a plane made in the 60s or 70s. it's a junk iron, but tolerable with the cap iron. On a full sized bench, I sharpened twice. Ash that's not oriented in any particular order can be pretty nasty without the cap iron.
Those irons are bad enough that using one on principle is pointless, so that's the only time I used it.
Richard Jones
I've been following it as well, and I believe it all stems from some Blue Spruce chisels that someone picked up fairly inexpensively. I'm not disagreeing with your findings on A2, especially about the plane irons, but I think it also depends upon the HT. The LV BU jack that I own seems to be head and shoulders above any other A2 that I have. Maybe it was marked incorrectly and is really O1!!!! I have found that just a small amount of stropping seems to increase cutting life, but that could just be me..................
Thanks for your comments and experience.
Rich
david weaver
It's probably A2 - if it's in a bevel up plane, it seems some of the angle-induced trouble is relieved in them, probably due to support closer to the edge of the iron, but I don't know what the cause is.
LV's O1 is generally closer to current sheffield spec, or some kind of ansi chisel spec (58/59). You'd notice much faster wear at that hardness.
It doesn't sound like much, but chisel performance at 58 hardness and plane iron performance at 58 hardness are much different than at 62 (especially in distanced planed with a smooth plane or use of chisels in anything other than softwoods).
The O1 quality thing that I mentioned is relevant, too. I drew the same conclusion as anyone else early on by using a hock A2 and O1 iron when i first started trying to dimension wood. The A2 hock iron is superior to the O1 that they use for some reason. After buying high quality domestic (US) stock and making my own O1 irons (and using two of steve knight's), something is wrong with hock's irons. They are good, but not as good as they could be. their a2 irons are good.
(things can change with A2 over time - my testing of A2 irons vs. each other, something I would never repeat due to being labor intensive) is LV/LN/Shepherd (terrible), Hock/IBC
Other than shepherd, all were good. edge life is determined in every single case by which chips the least.
As mentioned above, I don't expect all of this stuff to really matter much to anyone, other than I think that the myth of A2 superiority should go away. If it was 59 hardness instead of 62, we'd thinking nothing of it. It is very good for manufacturers, though, due to its stability and the perceived (on my part) lack of anything other than grinding tools to finish irons after hardening.
(as a side note, the O1 iron that I made for my skew infill shooting plane is the best shooting iron I've ever used. I may get flamed, but it's better (longer lasting) than the V11 iron that I used in the LV shooter that I bought to compare to it. I was able to leave the O1 iron very hard, and I'm guessing that's due to the quality of the steel. If it chipped, I would relax it.
Someone on the australian forum tested some v11 tools and found at least for those what I suspected (they are about 60 hardness). Should the V11 last longer in a shooting plane? probably. would it if both were chip free and 64 hardness? Probably. But my iron is much harder than the V11 iron was and will plane more feet of end grain because of it. At its hardness, it is not easy to sharpen, but that doesn't matter if it doesn't chip.
(v11 is good stuff, by the way. I don't know why it's 60 hardness in the tools tested when the A2 irons on the market tend to be a click or two harder, but I suspect that's on purpose to make it seem easy to sharpen).
My re-post from SMC
My experiments demonstrate that, when planing, a higher bed angle will be associated with more chipping on A2 steel than a low bed angle. Here the bevel angle is held constant.
My interpretation is that, if planing with a BD plane (with a bed of 45 degrees and higher), increase the bevel angle to about 35 degrees. This is what David Charlesworth recommends as well.
If you are using a BU plane (with a 12 degree bed), shooting end grain, then you can safely use a 25 degree bevel on your A2 blade. Obviously, higher bevel angles will simply beef up the edge further (this would be the case when planing face grain).
Research support for the above: http://www.inthewoodshop.com/ToolReviews/LVShootingPlane.html
Chisels with A2 steel can get sharp enough for any task with bevels at 30 degrees. Edge holding is better than O1, but A2 is not on the same planet as Koyamaichi white steel or PM-V11.
Research for the above: http://www.inthewoodshop.com/ToolReviews/FourChiselSteelsCompared.html
I might add this: during pre-production research for Lee Valley's mortice chisels, when comparing their A2 and PM-V11 steels, I gave up testing their limits as both just held an edge beyond the limits of the test situation. Secondary bevel angle here was 35 degrees.
Please note that these are my opinions based on my research, which is as objective as I could get. I stand behind these results and conclusions.
david weaver
(i'll freely admit that if someone else went into as much nuttiness as I have about this, I'd make fun of them and tell them to make something. )
Re: My re-post from SMC
david weaver
Years ago, I had a couple of the LN sash mortise chisels (a2) and the Ray Iles mortise chisels (D2).
Both held their edges well.
I've subsequently bought older chisels (only out of curiosity, and because they were cheaper). I. Sorby oval bolstered, and they are about as hard as the LN and RI chisels, and their edge holding is similar.
A quick rub of the edge on any of these after several mortises (like 30 seconds worth) and nothing more is needed for hundreds of mortises, so I've never had to do a significant reset on any of these chisels and can't really say what would happen if someone set them all to 25 degrees and drove them through a louisville slugger with a hydraulic press.
I like the I. Sorby chisels a little better in use, they don't form a wire edge. It's insignificant in this case, to say the least.
Bench chisel work at angles people would like to use here in the states once they're further along (mid to high 20s), the above would probably be different (and it's highly dependent on hardness and quality of the steel and heat treatment).
Shepherd's A2 iron was at least as hard as any of the other ones I had. It was the worst iron I have ever seen by a long shot. No clue why (bad stock? bad heat treat?). Things came out of it in gloms. I sold the plane because the cap iron that came with it didn't fit other vintage parallel irons, and at the same time, other cap irons didn't fit in the shepherd plane because they saw fit to make the adjuster cup much different in size and depth than any other infill I've ever seen - nothing compatible.
Figuratively a caterpillar bulldozer of a plane with a briggs and stratton motor that couldn't be changed out for a diesel.
Haha!
John in NM
The thought occurred to me, but I figured why start stirring?
Re: Haha!
Joe shelton
David, don't let John ruffle you. I'll follow you wherever you go.
Out of a mild sense of curiosity...
Brian Holcombe
I’d love it if they supplied Tsunesaburo blades made from pre-laminated steels. Seems like a dream but a lot of old Stanley’s had laminated blades that appear to be laminated through a manufacturing process.
I prefer this blade to the solid O-1 blades but the O-1 blade I have from
Hock is ok.
Warren in Lancaster, PA
In defending A2 steel, David Charlesworth bragged that when he trues up a 5"X20" board in an exercise with his students, the students always need to sharpen before he does. For myself I would do this amount of work entirely without sharpening, using 100 year old laminated irons.
"There is nothing wrong with A2 steel". Nothing that a good marketing campaign could not correct. I think Charlesworth knows where his bread is buttered.
Coupla random thoughts
Wiley Horne
1. I’m pretty sure I recall that Steve Knight cryo’ed his O1, and ended up not less than RC60. Maybe the cryo really mattered, in getting all the austenite converted to martensite.
2. The metallurgist John Verheuven, in Steel Metallurgy for Non-Metallurgists, shows quenching data that demonstrates the problem in through-hardening unalloyed high carbon, such as 1095 (same as W1), when the thickness gets above 0.09” (3/32”). When you get up toward 1/8” or 0.145”, it takes extremely fast quench times to avoid the formation of pearlite or bainite in preference to martensite. And the problem gets worse with finer-grain steel. Alloying allows longer quench times before the undesirable stuff begins to form. So LN would have been caught between the necessity of very rapid quench on the one-hand, and the consequences of very rapid quench on the other hand. All of which supports your thesis about heat treat being the issue with W1. I still have my W1 iron in a bronze LN4 and it’s a honey.
3. The most ideal steel I have seen is Tasai’s forgings blue steel forgings, for edge, edge-holding snd sharpenability. I think it is the harder tier of blue 2, which would mean about 1.2% carbon. That said, I just love steel, and think the carbon atom is the most amazing thing under the sun.
Over and out (as John A. says😀).
Wiley
That post was what I truly appreciate about David
John in NM
His own response to his own very long, detailed post is to acknowledge that taking him completely seriously is optional. That is the rarest commodity on the internet!
Joe shelton
You guys are just carrying me off on another tangent, exploring dusty nooks and solving conundrums, aren't you?
Could I just wait 'til y'all find the right answer, then order two or three?
Philip Duffy
Just to make your wonderful discussion even more complex, try to remember that the new steels being offered by the custom knife makers are extraordinary in they're performance and one of these days a plane maker will offer a blade of V-10 or some such and make our lives even more miserable!! Grrinnns to all! Philip
david weaver
yeah, we hit on that with the SGPS knife thing. (if the rest is TLDR - if someone had to have stainless, VG10 wouldn't be bad - more complicated would be - the 3V seems to do well, but it's one of the less complicated CPM steels from what I can tell).
Wiley had a friend who uses one of the SGPS knives in the field and loves that they take infinite abuse (I'm sure that's true - it's hard, it's stainless, and it resists most sharpening media more than most steels).
I bought one and subjected my new one (in my pocket today) to the microscope after various stones and it just wasn't having natural abrasives or even a lot of the synthetic setups. Chunking out pitting or small voids in the edge, there just wasn't any good way to convince the very edge to hold onto itself under an abrasive. There was a point where I was getting really frustrated with it, because I was comparing it to a 1095 tidioute knife, which is plain and wonderful, and not underhardened like a lot of 1095 knives.
Anyway, I have no faith that SGPS would make a good plane iron - it would yield its initial edge. I'd bet it would make a good die steel. What I have learned, though, is that it (the pocket knfe) will grind very quickly on a medium crystolon (you could waste it away unintentionally) even when other synthetic stones cut it slowly, you can consolidate the brash treatment from that stone with an india stone (but you can feel it ripping things out of the steel, and then.......
...the knife loves to be finished with a deburring wheel and a hard buff. Takes a fantastic edge off of that setup, even with a relatively coarse compound in the buffer wheel (5 microns is what I generally use).
Cliff stamp did an interesting look at the wondersteels in knives, because they tend to do well with blunt edged abuse, but they don't do that well against traditional tests in cutting (which is what we presumably do). Tidioute uses thin blades and hard 1095, and if you're not doing something outright abusive, their knives are a treat to use. If stainless is a necessity, Cliff found that in order for S30V and some other similar steels to match the more plain (boring, low cost, etc, like 420 and 440) stainless steels in edge holding and feet of materials cut (because of the way they give up their edges at lower angles), the edge angle has to be 50 degrees+. If the final bevel is not 50 degrees, the cheaper blades will slice further and longer (on top of being far easier to sharpen). It's not the conclusion a lot of buyers want.
(VG10 is a good quality plain stainless, of course. Probably not that different from PM V11 in some respects, as far as chemical composition)
One last boring bit (no pun intended after drill rod), I used to frequent a razor site. There are very few people on those sites who learn much about the metal - they're more like buying sites - people with a lot of dopamine really love everything they get and will look past something that's not that great and still love it. while I was there, I said something about steels like we're talking about here, and started getting PMs from professional razor honers who would get a knife maker's custom razor in S30V or some other ungodly die making steel that never should've been put in a razor (razor final bevel angles are generally 16-18 degrees). They couldn't get them sharp - 90% of the PMs that I got (so that nobody could see someone asking a question - professional honers don't like anyone to know they don't know something) were for steels like S30V, and the only thing I could tell them was:
* find the finest diamonds you can find, finish the edge on them on a relatively hard strop through a progression ending with those diamonds
* don't strop them briskly on linen and leather, the edge will come off of the razor, use a soft strop with the finest diamonds and wipe the edge just a little after finishing
* tell the buyer not to buy any more razors made of exotic steels, and tell them not to strop the razors with more than their own weight (if they just have to).
Some of these "razors" were $1,000 from custom knife makers. They were bulky, heavy, couldn't take a good edge, and then held whatever was there even less well because both the buyer and the seller refused to do any experimenting. I felt bad for them. The skill in razors is in making a neat, thin grind. The old cutlers were masters at it, and to do it in a production setting is a lifetime skill. Making a huge thick S30V "razor" takes no skill. When I first got into razors, I bothered George Wilson to make me one to see if I could goad him into it. He said "no, it would take too long to learn to make a good one".
that's not something he says often. In time, I've realized that the production razors from europe in the early 1900s and the same from japan in the 50s through 70s, are the best razors ever made. The skill in making them isn't in the cost of materials or lenghtening the text on the ad copy, it's in the grind and finishing with plain steels, and I guess that's not that sexy.
Charlie
I wonder if the L-N planes used during this build were loaded with A2 irons:
https://www.youtube.com/watch?v=F7otLVAZh0Y
Watch it to the end to see the finished piece.
Charlie
Egads, I think he may have used Marples Blue Chip chisels in part of this build, along with the aforementioned L-N planes:
https://www.youtube.com/watch?v=LH_gVEu2NX8
david weaver
Ghee...a piece of furniture.
Charlie
I know it. I miss the test boards and kit builds as much as anyone I can assure you.
David Weaver
You must make furniture for a living. Where's your portfolio? In the bottom of a wine glass?
Have another one. Your wife's got the bills covered.
David Weaver
All of it works well. I'm not sure there would be much recent negative sentiment about A2 if it hadn't been marketed as a superior blade steel. it's probably superior for a relatively automated maker, but not better for a user unless you're comparing it to a 1970s stanley iron (or shepherd...everything compares favorably to shepherd).
I watched the video last night. I think they just did the hand planing for show in the video, then they go back to using their expensive machinery. The impression I got was that they learned their planing techniques from watching videos of other guys who also just plane a board to "show you how it's done", then go back to their machinery. I would have expected you to have a more efficient routine yourself, Charlie.
We use straightedges and winding sticks for stock preparation. We don't use heavy high angle jack planes.
David Weaver
Their routine looked really deliberate and could be sped up by a factor of four, but the real accomplishment is that they've found customers who will pay enough for them to make that type of furniture.
As far as I recall, most of the work is done by machines and jigging, but not in a rush. If they did more of the underlying work by hand, they'd be faster with the smoothing. Doesn't detract from the fact that the furniture is beautifully done.
Charlie cannot be engaged in any kind of technical discussion, though, because he'll never show his own work, just criticize others and shift the subject rather than answering questions. Bpd? And sometimes come up with fanciful scenarios to a delusional level. He's convinced that the piece of wood that Ellis photographed in my article was secretly done by me in some strange nonsensical conspiracy, and that Lee valley works behind the scenes to get him banned from forums. It's sad to say that as a hobbyist, I've learned something from just about everyone on this board, but in two decades of oppositional posts from Charlie, I've literally learned nothing other than that he doesn't make a living on commissions. I am thankful for the presence of actual full time makers like you and George who respond with usable advice.
TomD
"Just to make your wonderful discussion even more complex, try to remember that the new steels being offered by the custom knife makers are extraordinary in they're performance and one of these days a plane maker will offer a blade of V-10 or some such and make our lives even more miserable!! Grrinnns to all! Philip"
Several things about that.
The knife makers have no serious means of measuring their edge retention. They have a series of tests that are interesting, and interesting to beat, but largely meaningless. I don't own a knife in order to cut hemp rope, for instance.
Most knife makers sharpen off their belt sander, for which there are incredible belts and evens strops available. Sharpening with a 3 HP slave open up all kinds of options Mr Hand Tools does not have.
A lot of knife users can't sharpen knives. And I am talking about knife nuts, not merely people who never give the subject a thought. A lot of them send their knives back to the factory to be sharpened. I couldn't believe that when I first heard it.
A lot of knives have to be made in stainless to gain traction.
I'm enough into knife making that I own the tools and dabble. I don't trust a word knife makers say about steel, only because it is such a weird market. I mean, it is dominated by non-users.
