Grinder wheel
Gary, a 6" grinder is fine. I used one before I purchased the 8" about 10 years ago. It just creates a deeper hollow. My preference is a shallow hollow, which is one of the reasons I liked the Tormek (but the T is soooo slow).
Do not get those horrid blue 3X wheels! Not unless you like to wear a mask and enjoy cleaning up grit. The wheels are very friable - to keep grinding cool - and they shed all over the show.
Look, it's a new world now. The white, pink and blue wheels are OUT. CBN is IN
There is a 6" version available for your grinder.
Many years ago, Joel wrote a wonderful article for FWW magazine on using a cambered wheel on the grinder. The aim was to reduce surface area and increase accuracy. It is still the method to use ... on a friable wheel. But the CBN does not need a cambered wheel. Get a FLAT CBN wheel with square edges (read my article why).
The advantage of the CBN wheel is that it is made of steel or hardened aluminium, and balanced at the factory. They run amzingly silently. The wheels are heavy and some machines may need a push to get the momentum going. My grinder is 1 hp. Once started, my wheels take 8 1/2 minutes to slow to a stop.
The wheels are electroplated with a layer of Cubic Boron Nitride. This is close to the hardness of diamond, but it does not wear (as diamond will do). The advantage here is that these wheels never need to be dressed. They never lose their size (and therefore all settings stay constant). And the wheels remain sharp ... well, they have been around some decades and early ones are still in daily use.
CBN has been used by turners for probably a decade. I am not sure why flat woodworkers have not heard of them. I discovered them about 2 1/2 years ago only, mentioned them on a couple of forums, and the responses came back indicating they were little known. Dave Weaver bought one after this, became a convert, and he will no doubt agree with what I write. Many are now turning onto these wheels. They are the future now.
The wheels are wideer than the vitreous wheels. About an 1 1/2" and straight/ flat. This allows one to present the blade to the wheel square on. There is very little heat created. You can burn an edge, but you need to be a real klutz to do so (I am half a klutz and have never burnt a blade).
A 180 grit wheel has the advantage of creating a smooth primary bevel. A vitreous wheel is best used at about 38 grit. Much higher than this and it creates too much heat. The smoother primary bevel reduces a step in honing - where often the first stone is use to straighten and smooth off the ragged edge. There are even finer grits available - up to 350 grit - however that will create heat and is really intended for turners with HSS chisels. I have a 80 grit wheel as well, but hardly use it.
Buy a CBN wheel, pay once, and then enjoy it for a very long time!
