Re: "What Are You Working On"
craigd
Thanks! Crisp is easy with nice wood (this QS elm is OK when dryish, the oak limbs I'm working on now are a royal pain). I'm using scratch stocks because I only have a couple of moulding planes and I can make complex cutter shapes pretty quickly. Two separate stocks + passes were used for this moulding.
These scratch stocks are from a saw plate, which is tapered, which isn't ideal (because it is hard[er] to hold in the handle), I have a bunch of 1095 sheet (saw plate/scraper stock) I can also use). These are 0.035" thick, which works fine but I wouldn't go thinner and would probably prefer thicker. To sharpen them, I hone the faces (just like the back of a plane iron) and scratch at a negative angle (ie if I'm pulling, the top of the stock is angled towards me or I can get chatter). A burr would be nice but I haven't felt like going to the effort to turn one).
My holders look like very wide (10" & 15") spoke shaves (with a fixed fence), very nice as they span the entire rail.
Layout - uhhh, what looks good. I have trouble going from positive space to negative space so, a lot of times, I draw shapes on the end of a board and work from there. I look at profiles on furniture, ones I like I either copy or mix with other bits of profiles. In this case, it is a mix of several profiles from the Joint Stool book. I try to use "standard" radius's so, depending on how nasty the wood is, I can use sandpaper on dowels to clean up or reshape post scrape.
Shaping - I use a sharpie to draw the outline and grind most of waste (taking care not to pull the temper) and then files: flat (with and without safe edges), triangular (for the vee grooves), round (chain saw files) for the beads. I have a PanaVise, which just about ideal for filing these.
Next, I'm going to layout a long profile on a slant because the profile looks much more pronounced when when it goes from zero to ~1/2 the board depth (over the width of the profile). For some reason, just clamping the stock at an angle in the holder just doesn't seem right.
