Re: Lee Valey hand plane fence
Wiley Horne--So. Calif.
Hi Eliot,
Putting a fence like that to work, especially with a heavy metal plane, requires using a lot of force from the side to hold the plane square to the work (see LV's instructions). So if you use dogs on top of the bench, you'll also need a supporting board clamped against the offside of the work to take the side loading.
You could use some variation of edge dogs, as Thom suggested, but there you'll need support clamped under the work, so the work doesn't slip from top loading.
In truth, the fence you bought has only specialized use--many everyday operations aren't suitable for it. If you're doing a bunch of long, wide, heavyish boards, which can be held in a vise, it could speed things up.
But to do everyday jointing task--like drawer bottoms, dust panels, jointing boards for a desktop or case side--all involved in making a piece of case goods, you really have two good options:
1. Learn to freehand edge join with the board held vertically, either in vise, or on the bench top pushed into a birds mouth (V shaped), or on the bench top against a plain stop (birds mouth is better for edge jointing IMO).
2. Do what John Pappas said twice: get the plane on its side and shoot the edge. Once you do this, you'll wonder how you ever got on without it! You can make a shooting board for this purpose. Or if you just want to try it, you can easily clamp a prototype setup to your bench top--sheet of plywood with a straight stick clamped on top to serve as a fence, with the work butted up against the straight stick and protruding over the edge of the plywood. Get your jointer on its side, and plane the work, letting the jointer just ride against the edge of the work. Plane from the middle of the work initially and gradually extend the length of the stroke to full length. This is like falling off a log, sets up and takes down quickly, and works on thins up to 4/4 or even thicker (just make sure your clamping is tight).
The most practical thing you can do right now is learn to shoot edges with the plane on its side. Then pick up freehand vertical edge jointing as you go--the basic technique of planing from the inside out is common to both methods.
Wiley
