Re: Working with leather Qs
Alan DuBoff
>Robin wrote:
If any of this is clear as mudd don't hesitate to ask more questions.
Ok, you asked for it. I did some experimenting just now, and see that the speedy stitcher is capable of pushing through the leather, if I use a twisting motion, on a bench.
I also found that if I rolled the leather around, it would make it more workable, quite a bit.
Lesson 1) Do not use a handsaw to cut leather. This is like amputation...I had a hand saw handy and thought I would, err..,no good, bad thinking...do not cut leather with a serrated edge, leather dust is no good...dead skin...:-/
Got me to thinking...my old smithy instructor had given me an old plow disc from an old plow around the farm where the smithy is located. I think I can forge a piece of that into a large rounded blade, to cut leather. I saw one online, it reminded me of the Asian type knife that has a wood handle along the top. I can see the advantage of being able to cut with a large arched "straight" edge.
Hmmm....this plow disc could work for that by slicing an arc off the circumference, do some light forging to shape it, and just cut a slot in a piece of hardwood. Maybe use a couple split-nuts..., and then make a sheath for it. I could probably get it done in a day of futzing around...ok, that will be later, in the meantime, I think I will use an exacto knife, to cut out my first sheath, for an unfinished patch knife I forged a while ago. I've already tempered it, but still need to stick it in the pickle juice or sand/file it clean. Maybe this will inspire me to do that. Anyway I think I can make a small sheath for it with the help info from both you and ThomD. I think my speedy stitch is ok for now, since I now see how to use it more effectively on a bench. However, I still need to try the vise as well, the pattern makers vise I installed recentely has a pretty narrow lip. Problem is that's a mess right now...:-/
Anyway, the one question that I'm wondering is that I saw that some of the v groove tools look like are used to cut a crease for a fold. I have a possible idea where I would need a fold. I am not sure I have a v type gouge, but might, with some small carving tools. Crease is from the inside of the leather, I suppose?
I think I have enough info to create a small sheath, but need to find something to cut with, I must have something with a sharp edge on it around here somewhere...LOL!
