The Incredibly Versatile Sweep Brace
Bob Smalser, Seabeck, WA
>[quote][b]Here's an article we�d like (for Gaff Rig)�how to use a brace with a long ship�s auger, for instance, to bore through a deep keel at a slight angle without the hole breaking through the side. For most of us, the problem is holding the brace and bit true so that our drilling is straight�a lot of folks would like to use hand tools, if only someone would show them how.[/b] Regards, Jim. [/quote]
My pleasure, Jim. I can�t think of a more multi-purpose tool than the ratcheting, reversible sweep brace, once present in almost every household�and because of that, nice ones are often under 10 dollars today complete with bits. Boring clean, accurate holes with ease, taper reaming those holes, screw driving and countersinking, cutting round tenons, and pointing spokes, the brace still holds a prominent place in the tool kits of chair makers and boatbuilders today because it still does some tasks much, much better than machines.
Braces came with different patented chuck designs and ratcheting mechanisms, and in different sizes and configurations. The most common sizes available have 6-inch sweeps, 8-inch, 10-inch, 12-inch and even 14-inch, the 10 being the most common. They are so inexpensive today, that there is no reason not to have two or more in play for a given task rather than bothering to change bits. In addition to an 8 or 10-inch, a larger 12 or 14-inch brace is handy for those occasions where more torque is required. So is the joist or right-angle brace for use in confined spaces.
Shown are some varieties of chucks commonly found, all of them with two spring-loaded jaws. The Stanley joist brace on the right has a chuck that comes off with a setscrew, but the others just screw off. The late model Miller Falls at center left is the beefiest design. The unmarked one to its right has lost its spring, and I�ve fabricated a replacement from music wire. The 2-jaw chucks are designed for 4-sided augers and accessories, but also work reasonably well with modern 8-sided screwdriver bits in longer lengths. Today, there are boatbuilder suppliers who carry magnetic bit extensions for the brace designed to hold those interchangeable, quarter-inch 8-sided bits.
The lead screw auger bit still has a place in modern shops. A low-friction design that pulls itself into its own hole, little pressure is required to bore even the deepest holes, and combined with the short joist brace offers options for tight spots not available elsewhere. It�s also the easiest tool to sharpen in the shop. A tapered auger file is used to put an edge on the inside (never the outside) lips that serve as nickers�
�and both main cutting edges of the bit.
I�d prefer to show Jim some examples of use in boatbuilding, but I don�t happen to have a boat in the shop this fall. I do have a custom concert stool of Bigleaf Maple I�m making for a choir director with a bad back, however, and if y�all don�t mind, it�ll demonstrate some capabilities of the brace even better.
Nothing out there bores an angled hole single-handedly as well as the brace, because it is slow enough to make corrections as you go and still result in a clean hole. Sure, I�ve also done plenty with long bell hanger�s bits in electric drills and a helper sighting from one side while I both drilled and sighted from the other, but like all conventional machine bits, there is always the risk of the bit wandering in inconsistent grain and the exit hole not being perfectly centered. That�s not as much of a problem with an auger, either used by hand or power�and the older, used Irwin and other maker�s bits designed for the brace and a bit extension are much easier on the wallet than a new ship�s auger. The bit extensions designed for the brace take some searching, as many antique tool dealers don�t know what they are�but because of that are equally inexpensive.
Here I�m using 8� and 12� bevel gages as indexes to bore a hole angled for 6 degrees of splay on one side and 11 degrees of rake on the other. I�m using the larger 12-inch brace for power. You can also see penciled sight lines based on the resultant angle of rake and splay� 5-dollar words that mean besides the bevels, I also align the centerline of the brace up with a separate line laid out on the work piece specifically for that purpose. You can do the same in other situations by tacking a batten or yardstick to the workpiece to serve as an index. I simply run the lead screw in my center-punched mark until the nicker lips bite, take my angles, and bore until the lead screw protrudes slightly from the opposite side of the work piece, sighting down my pencil line as I am boring and stopping occasionally to double check my accuracy using the bevels.
Then I flip the workpiece, circle my lead screw holes with a pencil so I don�t goof and begin in the wrong place, and counter bore using the bevels to achieve the same angles so as to make a perfectly clean hole with no chip out.
Next I use a tapered chair maker�s reamer to ream the holes for mating with the tapered, round, wedged tenons, using the same care to keep the angles correct as I used when boring the holes. These reamers generally have two identical cutting edges, and are used both clockwise and counter clockwise to even the wear on those cutting edges. These tapered and wedged round tenon joints are self tightening, allowing air-dried wood to be used for the legs so that cooked, dryer wood can be used for the stretchers�also self tightening as the air dried legs shrink when brought into central heating.
The tenon cutter acts as a rotary plane to quickly turn a spoke shaved stretcher end into a uniform round tenon that fits its bored mortise.
Continued�
Re: The Incredibly Versatile Sweep Brace
Sweep Brace Part II
I always cringe a bit when I see teachers like Norm running screws home in an important application using a power driver. Sure, I do that too in many instances in general carpentry, but never in a critical application like boat planking, furniture carcasses or hinges. The torque limiters on even my best electric drivers can never accommodate the minor changes in grain density that always result in a percentage of over-driven screws, causing crushed threads that lack full strength and rot more quickly. I certainly run them in using a power driver, but I always seat them home by hand twisting the last couple turns, either with my big Yankee or with the brace. Much as I like the North Brothers and later Stanley Yankee push drivers, it is impossible for me to seat more than a few dozen screws without carpal tunnel pain, and it�s on big jobs where the brace excels.
The brace is also the best tool by far to [i] remove [/i] those screws when the time comes, as it combines massive torque with the sensitivity required to break any rust bonding without stripping the slot. Carry along a separate, unmounted bit and 8oz hammer to give that rusted screw�s slot a good rap before trying the brace.
Here I�ve changed to the more sensitive 10-inch brace and a Phillips bit to seat the steel #16 screws mounting the stool back post in their epoxied mortises. I did bore the pilot holes using an electric drill and a tapered drill-countersink bit. Also shown are the wax I use to lube the screw threads before driving and the walnut bungs I�ll use later to fill the holes.
I have a surprisingly popular class I take to Grade Schools occasionally where I lay out and explain a selection of �old-time� hand tools and proceed to froe and plane a chunk of log into a board with the kids� help. Then the kids are broken into small groups and get to try all the tools under their teacher�s and my supervision. Their favorite tool? The brace and bit, of course. Mine too.
Oh�forgot�the purpose-built stool? Ain�t much, but it�ll fit the dais safely, blend with the tux, looks tippy but isn�t�and I suspect it will serve:
Darrell in Oakville
Re: Sweet Brace Part II
Darrell in Oakville
>Bob,
Excellent discourse on the Brace. It was this tool that pushed me over the edge and down the Slippery Slope.
I've also done some stuff with kids and braces. Cut out a bunch of Xmas tree shapes from cheap white pine and then show the kids how to cut the "trunk" using a hollow auger, and bore a hole in the base with an auger bit. They love it! Too bad I only had three hollow augers...
Glue the tree into the base, paint and decorate the tree and presto! one Gift For Mom.
Darrell
Wood Hoarder, Blade Sharpener, and Occasional Tool User
Does Anyone Really Need...
frank P. Meriweather
>online courses like this. It's great that you are so efficient with hand tools, but really who cares. If we want a class we'll take one. At least we can pick the topic
Re: Does Anyone Really Need...
>Someone forced you to open the thread, I guess?
The pages and pages of feedback I get indicate just the opposite, my friend.
Just add me to your "blocked posters" list.
No problem here Bob
Dennis
>Forget it Bob,some just don't get it and i for one say keep doing it, i enjoy what you post.
Dennis, who is sad over the passing of Bob Nelson
remove nospam for email
Todd Hughes
>Bob....I might not "Need" it but I enjoyed it and appreciate the work and thought you put into it and the help it gives to many and because of that I say THANKS and keep it up!.......Todd , who never ceases to be amazed by some people!
I learn from EVERY Bob Smalser thread
Angus Barclay, in New Zealand
>Q Do we need online courses like this?
A Yes, they are a valuable resource.
Q Who cares?
A I do, and I believe several (many?)other people here at WoodCentral care too.
Statement If we want a class we'll take one.
Response That isn't always an option. Bob's online tutorials are far better quality than many classes, they areeasily available anywhere in the world (not just your local home town in the US of A) and at the price Bob charges for them (free) you will NEVER get better value for money.
Statement At least we can pick the topic
Response And you can pick hundreds of topics to learn about here on WoodCentral too, with dozens of them benefiting from Bob's years of experience and knowledge.
Bob, please keep them coming. I keep links to all your articles and your article about teaching your son saw sharpening tipped me over the edge of that particular slope.
regards
Angus Barclay
Jack Guzman from Maine
Me for one
Keep 'em coming, Bob...
Rob Brophy Niagara Falls
>...I enjoy your articles and usually learn a thing or two...Rob who is also sad at the loss of Bob Nelson
I like Bob's posts plus a *Hijack* (sort of)
Christopher Fitch @ Memphis
>I like Bob's posts....even if I don't need them. His posts are informative and interesting.
Knowledge is good for the sake of knowledge alone and we all might learn something new since no-one can know it all. I have four books on finishing. Following your line of reasoning, Frank P. Meriweather, I should only have one book on finishing since multiple ones are a waste. After all, I only need to read one book on finishing once and then I should be an expert right?
Of course that's a load of crap. What's interesting is that even though these books all cover the same general area, they don't present the same data in the same way or even present information on some things at all. In many places, the techniques and data don't quite match or agree. All of this has spurred me on to finding out things for myself and trying new ideas to see what works for me. If I only read ONE book, I would not gain that benefit.
Further, seeing a number of different perspectives on the same areas helps as well because new ideas can come out and progress is made.
On a different but similar note, we have been "graced" with the presence of a few disruptive characters recently. I could list them but I find it more bothersome that these people seem intent on being asses or on causing disruption in our online board. The paranoid part of me wonders if something is at work behind the scenes.
Oh well, keep up the posts Bob!
My Biased opinion...
Re: Me for two
>Yup, I'll chime in to say my thanks to Bob for all his GREAT! articles. I always learn a thing or two and I certainly appreciate the efforts that Bob takes to pass on his knowledge.
Be patient Frank, one day Bob will post a "class" that you'll be thankful for.
I'm a bit behind the times as I was unaware that Bob Nelson has passed away. This is indeed sad news for all of us, and he will be sorely missed. :~( Does anybody have an address to send a card to his widow, or perhaps some type of WC collective flower arrrangement or something?
Todd O.
Bob Hackett
>The answer is a resounding YES!We need more of these tutorials and more people like Bob,folks who unselfishly share what they know with the rest of the WWing world.
What we really DON`T need is trolls.I trust you get my rather broad hint.
Mainely,Bob
Ron Smith
>Frank . . . . You must have had a really bad day. Or perhaps you are one of the very few given to frivolous, impolite criticism. Mr. Smalser is an extremely knowledgeable craftsman. He is an excellent writer. I for one feel we are extremely fortunate to have the opportunity to learn from him.
I am sure that when you feel better, and after a bit of introspection you will realize how wrong, and inappropriate your comment was. Further, unless you are as stubborn - as you are wrong - you will probably offer an apology.
I am banking on you Frank,
Ron
fmutchler@adelphia.net
>"Does anyone really need online courses like this."
It's a rare post on this forum that anyone would presume to know what "anyone" other than themselves needs or doesn't need.
"It's great that you are so efficient with hand tools, but really who cares."
There is rarely a post that expresses an opinion as rudely as you do in this statement.
"If we want a class we'll take one. At least we can pick the topic"
Who is the 'we' you are referring to? Please don't include me in your egalitarian pronouncements. Common courtesy would suggest that you limit statements like this to the first person singular.
I don't recall reading previous posts from you frank (lower case 'f' as you have signed yourself--not sarcasm) and I did a quick search to check....sorry if I missed some. If you decide to hang around you will eventually get a sense of the decency and mutual respect that permeates this community. If you do that, you will find that Bob Smalser is a highly respected and very warmly regarded member of this community.
Woodcentral is a rare jewel in the midst of a sea of online forums. We all try to treat each other with common courtesy and sort of practice that old rule about treating others as we would like to be treated.
Frank Mutchler....who is getting off the soap box now....
Take it or leave it
Sam Simpson
>Hi Y'all,
Frank, imagine there was no Internet! Back in the day when Bob, me and maybe you, grew up, the only way to be exposed to the level of diversity and knowledge, in a non committal way, was to go out at night and take a walk around the town and see what we might turn up.
There would be folks playing dominoes in front of the local store and kids playing in the park. Some old folks sitting chewing the cud on the corner and a few cliquey types getting involved in various activities at the club house. A skilled peruser could walk around and see if he wanted to participate in whatever was on offer. A game of dominoes, a chat with the boys. And if you where a popular guy you might get into one of the cliquey activities. You might be more of an ethereal chap and decide to walk the halls of the local library. Taking books from the shelves, you thumb the pages, and read without a chance of ever asking the author for extra input.
All in all a tedious evening out. Here at WoodCentral we are not as demanding on your time or your energy. You come and go as you please, whatever time of day. There are no cliques. There are some real brains chewing the cud in the pages. Alas we cannot all write essays of epic technical dialogue, nor can we answer every question asked. And best of all, you won't get shushed, like in the library.
We need your input Frank. But we want to know what you know, not how you are tired of what Bob knows.
Regards Sam Simpson.
Re: Illegitimus non carborundum
>Just keep on keepin' on doing what you do very well.
I don't always heap effusive praise on your tutorials, but you can be sure I read and study every one of them, and often save them, because I have learned that every one has much useful, applicable, readily comprehensible information, the vast majority of it that I didn't already know. Also, I appreciate that I don't have to filter out any hogwash.
Tom Price
>Good post Bob and the photos are excellent as usual. Always interesting to compare technique and see how others approach a project.
As to heckling from the nickle seats, pay it no never mind.
- Tom
YES!!!.....
A. J, Byrd
>some people (myself included) do need articles like this. I live in and area of the country where "Old School" hand tool users are few and far between and the ones I do encounter are usualy more skilled at carpentry than furniture or boat building. As far as taking a course is concerned I barely have enough time to skim the messages boards and even if I had the time to take a course the closest place is 80 miles away and power tool based. I am glad that Bob Smalser takes the time to write his very detailed, well thought out, and easy to understand articles and then share them with all of us. I buy from one to four Woodworking magazines a month and most of the articles in those magazines pale in comparison to the ones Bob writes. So to Mr. Bob Smalser I say THANK YOU!!! Your contributions and the contributions of others like you are what keep me coming back to this website.
I will now get off of my soap box and walk away calmly :-)
Well Said, Frank! My Sentiments Exactly!
Bob Hutchins in central Texas
Quite Frankly
Frank D. in Montreal
>Bob's a living legend to me. I devour anything that he posts because I know I won't get the same info anywhere else. Keep it up Bob!
is it possible to block these kind of people?
Mike in Mystic
Paul Warnock
>I guess what Frank is illustrating is just another facet to the FWW argument. Other than not voicing his complaint in the first person, Frank voiced his dismay at what he saw as a pointless posting. Many of the people on this forum were just as vocal regarding the recent content shift within the pages of FWW. Were they rude for doing so? I don't believe they were. I don't believe Frank's intention was to insult Bob, just expressing his frustrations. His delivery may not have been apropriate, but his opinion is still valid. For me,I loved the design of the stool, but was apathetic regarding proper brace use. No disrespect to anyone, especialy Bob.
>Frank, Paul et. al.
I've no hard feelings at all and am the type who loves a good, well-thought out argument. (And one of these days, I might just hear one.)
But I'd think it to be obvious that my postings here are oriented to younger folks who've not been exposed to the fine details of hand tools in what has become a blatantly consumerist hobby driven more by the tool companies and a few rag writer and TV personality shills than tradesmen these days.
As more experienced hands, I wouldn't expect y'all to get much out of brace ABC's, except I can't think of a time when I didn't take something positive away from watching another experienced hand work.
But in fact...these weren't...and aren't...really for the forums at all. They are chapters of a book I'm doing for my sons and their descendants for when I'm gone. My mentors are long gone and didn't have the writing skills to do that for me. I found about a year or so ago that posting them on various forums provide me with superb feedback for clarity revisions, as 40+ years is too long for me to remember what it was like starting from a blank page. If others benefit from them....well...all the better...I certainly do enjoy helping, especially if I can save a young family from buying tools they don't need or at costs they can do much better at.
Many, like this one, are based on specific requests...and I've another list of them some publishers want me to expand and send to them for wider dissemination. (There ain't enuf money in it to cover the costs of plussing them up, tho...so I'm reluctant.)
Accordingly...how could I improve this one to benefit you?
The final article will include the differences 'tween Jennings and Irwin bits and lead screw pitch differences, spoon bit use, and the boatbuilders want a lot more on driving and removing screws, to include modifying bits to fit odd slots, heating bits to break frozen screws, removing the taper on bits so as to not bugger up bung installation, and the advantages and disadvantages of Phillips, Reed&Prince, Square-drive and conventional slots.
Want to contribute, gents? Either provide useful feedback or post some detailed techniques of your own for us to learn from. Your names aren't old familiar ones from the articles section I refer youngsters to.
Skip in Falls Church
>I think Bob's posts are great. I can't understand why anyone would object to them. After all, this is a place to share information - and it is obvious that Bob has a lot of information to share. I think it's great that he's willing to take the time to share the informaton that he has. Just my opinion.
Skip
