refinishing vintage Shuffleboard table
Edward S
Well i bought a nice vintage 1970 American shuffleboard, playing surface is 11' x 16". Whoever finished the board previously contaminated it with i guess the wrong wood putty. Anyway i sanded whole thing down, applied sanding sealer , vinyl #'s and lines, and 2 coats of oil based poly. Well it doesnt look too good, lots of seperation and bubbles.
Now i am thinking i might want it stripped, sanded , and sprayed with lacquer.
Im looking for expert near me in Gilbertsville, Pa. 19525 to do this job!
Re: refinishing vintage Shuffleboard table
I don't know what "separation" means but the bubbles are easily cured by thinning this finish before application. To meet EAP regulations this stuff is sold too thick for ease of application. Thin it until it flows easily, something in the range of 1 part mineral spirits to 3 parts varnish.
Lacquer may not be hard enough for this application.
Silicone contamination?
Dick Coers
Highly unlikely putty would be the trouble. I'd guess someone used a polish to make it more slippery. Maybe it was in the grain and cracks, or you didn't get it off the wood, doesn't matter. Now it is contaminated, your sander is contaminated, and maybe even horizontal shop surfaces. There are additives that you can add to eliminate fish eye, but they are part silicone as well. You really have to clean the gun after using it, or get a cheap gun and throw it away after. Lacquer will likely be hard enough, but getting your finish off, and working with fish eye eliminator is likely not going to be welcomed by another shop.
Re: Silicone contamination?
Edward S
I dont have a shop, im a diy'er doing this in my dining room with a can on Minwax oil based poly. You are right though, i am certain it is silicone contamination. When i was sanding in between coats i was using a vacuum with brush and cleaning along the gutters, which are probably full of silicone sprayed on the top. That is used to help the pucks glide better!
Anyway i sanded down again, i could see the contamination disappear, it looked like wet spots all over. I sanded pretty good with 220 grit. I wiped with paint thinner and paper towel, looks good now. I'll eat dinner and wait for it to dry and try again!
Does anyone know what i can put all around the board to act as a barrier? I bought that Duck brand blue tape, but who knows that might be a problem also!
Edward S
Ok, this application went better, i thinned with paint thinner about 3-.5 and all the craters were gone. Just now seems like alot of dust or bubbles? But definitely looks better than last app. I used a cheap foam applicator, i was scared to use nice Purdy brush i bought.
no fear
I use a 4" $40 brush for polyurethane on floors.
Anyway, after it cures enough to get somewhat hard grind the coat flat with 320, 360 or 400 grit paper (what ever you can find) then recoat. When done you can again grind out any dust, then bring the luster back with 4/0 wool and wax or if you want a shine, polishing compound from the auto body refinishing store.
Paper: you can use stearated paper (has a white coating) or wet or dry silicon carbide (black paper) with water as a lubricant.
Re: no fear
Edward S
Bill, i dont know about the silicon sandpaper, im scared to use it just because of the silicon thing! I have to go get more tomorrow, i bought 3 sheets of Gator 220 today, which was just awful quality! I went through all 3 sheets sanding the previous application down!
Any suggestions on brand and where to buy?
I probably have to apply at least 3 or 4 more coats of poly to be plenty high enough above the vinyl #'s and lines i put on.
When doing final coat i have read people use ascending grits like 400, 600,800,1200, then rub out with wax or compound?
I really dont know proper way to do the final coat, heard contradictions.
But so far you guys here have been great! Im lucky to have found this forum, i almost gave up on the project, but i think i have saved it thanks to you all here, thank you!!
question
What are you scared of? Don't understand what you are talking about.
After the first coat you do not want to sand the coats with anything more coarse than 320 or you may see the scratches when you recoat. I use anything in the range of 320 to 400 depending on what I have most recently bought. So the process is coat, lightly sand the dust bumps, recoat.
Will provide suggestions for final rub out when you tell me what the "silicon thing" is all about.
Re: question
Larry Barrett
I am just reading between the lines, but think Edward read the word silicon in this line and that is what he is referring to as this 'silicon thing'.
Re: question
Edward S
yea that is it, i must of read something about silicone sandpaper, not to use! after hrs. of research my brain is fried i guess?
silicon -vs- silicone
Pete in Holland MI
Silicon (said with a short ''o'' sound) is a hard mineral.
Silicone (said with a long ''o'' sound) is a processed material used as a lubricant, among other things.
Two different animals that are often confused by the use of the wrong ''o''.
Silicon grit will not affect your finish bonding.
Pete
Re: silicon -vs- silicone
Edward S
ahh, ok silicon is a hard mineral.
and this plague silicone is driving me crazy!! Now i have about 5 coats on, the last being very heavy. Im so stupid i thought i was gonna try to cover them up with thicker coat! It did look good for about 15 minutes, but then hundreds of tiny ones appeared.
Anyway i guess i will buy fisheye remover tomorrow and try that.
Is it too late for me to buy a silicon/degreaser and rub down?
Removing silicones
To be precise silicon is element number 14, silica is a mineral composed of silicon and oxygen (quartz), and the dreaded silicone is a synthetic chemical made from silicon, carbon and hydrogen. It is similar to grease except the carbon in grease is replaced by silicon.
Personally, I have never had any success removing all the traces of a silicone wax from wood. Fish eye remover was necessary to mitigate its effects.
If your coats are thick enough you can still grind it flat with wet/dry silicon carbide paper and water lubricant, or stearated paper. You may need to start coarser than 320 to get on with the task. But be cautious as the abrasive removes coating fast and you don't want to cut through.
Re: Removing silicones
Edward S
thanks guys, a nice fellow came over said i do not have fish eye, it is solvent pop! He actually said it looks good and nothing to worry much about. He stated to sand again, cleanup with alcohol. Then use tack cloth just before application.
He said another big problem for me was no ventilation. So this time i will open a window with exhaust fan blowing out, and door cracked.
Hoping this will solve my problems!
what?
"said i do not have fish eye, it is solvent pop!" What in the world is solvent pop? If you don' t have silicone contamination thinned urethane varnish will level glass smooth. Your only problem will be roughness from dust settling onto the surface before it dries.
He said another big problem for me was no ventilation. ...;.I don't understand this one either. The fan is going to blow dust around and that is not good. I strive to keep the air as quiet as possible until the finish dries dust-free.
Given these "insights" I question the wisdom of your visitor.
Re: what?
Edward S
he said solvent pop, and lots of dust nibs, so i dont know?
is he right about using alcohol and tack rag?
i was just using thinner?
Re: what?
Grant in Iowa
Edward,
I'll let Bill guide your finishing process, as he knows his stuff. I do want to address the sanding method though.
On a shuffleboard, you need as flat a surface as you can achieve. Random orbital flat is not flat enough for serious play. If this is how you sanded it, you may need to start over. To that end, I'd consider making a large "sanding block" of something very flat , such as a piece of 3/4" MDF (Medium Density Fiberboard). Cut a piece of MDF as wide as your sandpaper sheets, and maybe twice as long. Alternatively, you can buy 12"x12" pieces of stone tile (not ceramic, as they aren't flat) at a home center. Then glue your sandpaper to the surface using 3m spray adhesive such as 3m 77 spray or rubber cement so the paper can be replaced without destroying your sanding block. Wrap the leading and trailing edge up around the edges of the sanding block to help keep it in place. You might find it will go easier with cheap hardware store handles affixed to the back of the MDF platen. If you try this, you will almost immediately find that what you thought was flat is NOT. Far better to discover this now than after you have invited friends over for a game.
So you will then need to do a good bit of sanding to get the surface flat. Buy the big pack of sandpaper, and in several grits from about 80 through 220 or so. Don't skip a grit, as that just wastes time and finish quality. One additional note is that a good shuffleboard has adjusters on the underside of the board. These serve to help control the crown on the board, which is the left to right flatness as one looks at the board from one end. I would release any pressure on these prior to flattening the board. Once you get it flat, acclimated to the space in which it will live, then re-tension these to achieve the final left/ right flatness desired.
Once you get it flat, and go back to applying a finish, let the finish sluff over the edges slightly, as this can easily be fixed after the final coat by using a sanding block along the edge. Waiting until after the final coat will help keep the edge square. Otherwise it will tend to develop a rounded lower area along each edge. Your finish will also need flattened, depending on how much you apply. Some boards have up to 1/4" of finish applied to them. As Bill said, use fine paper such as 280 or 320 grit for flattening the finish. Maybe do something like 500 grit after the final coat and then apply a paste wax before you sprinkle on the dance wax for play.
Good luck on your project.
Grant in Iowa
Re: what?
Thinner will be a better solvent for silicone. Silicone is more "greasy" than grease. So it takes something similar to dissolve it and that would be a petroleum based material, not alcohol. I would not be surprised to find that alcohol doesn't even mix with silicone. That said, I was never successful dissolving away silicone. The tiniest amount will cause problems. Ihave had it remain even after strong chemical stripping followed by sanding. Had to use fish eye mitigator.
The problem is surface tension. Few things have the surface tension of a silicone and it additionally has the property of migrating to surfaces. Once there the finish won't wet it and a cavity results.
Re: what?
Edward S
i am hearing so many contradicting views from everyone its really giving me a headache.
i specifically asked the guy about paste wax .
he stated do not use paste wax until i use a rubbing compound on the poly after final sanding.
i am not stripping again, i am way past that point, the board looks pretty good besides the little dust particles.
yes it does have climatic adjusters underneath, i did not loosen them when finishing.
i bought a tack cloth, he may be right, we will see!
Re: what?
Edward S
check out this thread, states alcohol is good to remove the silicone
http://www.penturners.org/forum/f28/removing-silicone-lubricants-4184/
agree with all
An auto body place may have a sand paper holding device for sanding something flat and they will assuredly have the wet or dry silicon carbide black paper in grits down to 2000.
I don't think you need something as large as a 12 x 12 backing for the paper and in any case you won't find paper that big without a special ordering.
lots of things are stated.......
and many are contradictory and clearly there are few chemists in the crowd.
The best response I found in that thread is quoted below as it agrees with my experience
"1) So far as I've researched, which is quite extensively, silicone contamination CANNOT be removed. It's like removing dried wood stain from carpet (don't ask me about that one[B)]). If you don't believe me, read the story below.
Experimental results
I just happen to have some silicon oil on hand and some denatured alcohol, which in fact has a high percentage of methanol. Methanol is about as close to water in dissolving properties as one can get and that is about as far from what is needed to dissolve a silicone as one can get.
Indeed, silicon oil is insoluble in denatured alcohol. If it won't dissolve it, it won't remove it. But then I doubt anything will completely remove it.
It can be chemically destroyed. I like the "flame it" suggestion. A flame will chemically alter it some to make it wetable by finish. And something strongly basic will destroy it. Strong ammonia might. Lye will.
A drop of fish eye remover seems a more simple and reliable solution.
Re: Experimental results
Edward S
thanks Bill, this guy has some fisheye remover, hes gonna give me a few ounces.
Ounces!
As I recall two drops in a spray cup was the recipe. Do check. What you are adding is a surface tension modifier. You don't want any more than what it takes to coat the surface of the finish film with a molecular layer of this stuff.
