Re: I have the Delta DC33 Planer
Robby Wright in San Marcos, CA
Charlie - I bought it soon after it was released and have had it ever since. It uses 13 inch knives and the bed measures 13 inches (I just checked). It is a good planer. It leaves a very good finish on the wood - The knives leave almost no marks. The rollers are all metal, so you don't have to worry about changing them due to wear. If you remember to lock the head, the amount of snipe is minimal to invisible. I would buy one in a blink. I do have to admit that I haven't used a Dewalt, so I can't compare.
The DC33 was made in Brazil, but has an American motor. The motor is a 2 HP total enclosed motor and doesn't bog with a full depth, full width cut on hard maple or oak. I run mine on 220V. The rest of the planer is solid cast iron and steel, with an oil filled gear box. There was an eight year period that I didn't use my planer. When I needed it again, I just dug it out, cleaned off the light rust, waxed the table, turned it one and started cutting. It is a beast and weighs quite a bit - it is a two man lift with a lot of grunting. You aren't going to hide it under a bench and casually put it out. It needs a stand and wheels unless you have room to leave it in place. The wheels will need to be good or you will have troubles moving it around. Did I say it was heavy cast iron?
It does have it quirks. The metal infeed roller is fluted steel. If you try to take a really shallow cut, you will end up with imprints on the wood from the roller. The planer is loud. 13 inches of straight knives makes a great siren. It works best with a DC. Without one, some of the chips will end up on the board and get pressed in by the outfeed roller. Unfortunately, I didn't buy the stand, infeed/outfeed tables or the dust chute. (Hey, I was young and pinching pennies!) I wish I had. The tables would have made working with long boards easier, but I get by without them. I made a plywood dust chute and it works quite well. Total cost: $4 for the 4" hose adapter, although I think I am going to remake it so the hose exits to the side and doesn't get caught by the exiting wood.
I have had this planer for over 20 years now and it has held up well. I don't use it that often as rough lumber isn't easy to get around here. I use it to make thicknesses I don't have and to clean up after resawing. It will plane down below an eighth of an inch. Makes great tongue depressors!
Changing the knives isn't hard if you have the magic installer dodad that comes with the planer. Remove the old knives, put the new knife in place and press down with the alignment tool. Tighten the gibs. Repeat two more time and reinstall the dust shield.
There is a gadget on the infeed side that will prevent you from taking too deep a cut. It will hit the top of the board if you try to take off too much. The height gauge is a bit hard to read, but it is accurate and reasonably repeatable once you set it. Once you put a board in and the safety pawls engage, you cannot remove the board and there is no way that a board will ever shoot back out the opening. If something gets stuck, you hit the feed disengage lever and shut the planer off. Loosen the head clamps, raise the head and get your wood out. You will quickly learn to think ahead as far as how much you are going to take off. That input gauge can be a pain if you are feeding a tapered board. You learn to check ahead of time and set the planer for the right cut off the thickest part of the board, but I would imagine you would have this with any planer.
I paid $950 for my planer years ago and it was a good investment. My kids will probably enjoy this planer after I am gone - it will last like all of the old Delta gear. $550 would be a good price in my book. Hope this helps.
Robby Wright in San Marcos, Ca
