We value your privacy.
I have a 14" BS with Riser Block. I have done some resawing on it with pretty good success, using cheap 3 tpi hooked tooth blades.
I am trying to screw up my courage and buy an excellent resaw blade. As much as I hate changing the blades I visualize only using the blade for resawing and changing it off the machine when not in use. The saw has a 1 hp motor on it.
I am struggling to justify a carbide tipped blade.
What do you recommend? Any Idea how many linear feet of resawing I might get from it. Can it be resharpend? Anything new and fabulous out there?
I have a Woodslicer non carbide resaw blade and I'm happy with it. I priced out the carbide blades and I just couldn't justify the cost.
I have used my friend Mike's Timberwolf blade (Suffolk Machinery) and that worked pretty well also.
I have seen a big bandsaw equipped with a Lenox blade - but I couldn't justify the bucks for myself (~$160). It did cut very nice and would probably cut anything.
From my experience with a carbide-tipped bandsaw blade they aren't worth the money. I bought an expensive 1" resaw special from Laguna tools for use in my 2.5HP 16" saw and, while it works, it does no better than the much less expensive Woodslicer blade. Maybe if I was doing a lot of sawing of highly-abrasive woods the carbide might come into its own but my saw inevitably has the Woodslicer on it and it is changed out only when I have to do more traditional curved cutting with a narrower blade. I understand that the Woodslicer is being offered in 3/4" width now (can't remember where I saw that mentioned) and that might be better for heavy resawing than the 1/2" so the next time I buy a replacement I may try one of them.
My bandsaw is a Delta 14" without the riser block and with a 1 hp motor. I have two resaw blades, a Lenox Trimaster carbide and a Highland Wood Slicer. The Lenox is very expensive, costing about $135 that I got 5-6 years ago, maybe more. This blade has a fairly wide kerf and thus will do a fairly good job of cutting curves. I got lazy and kept it on the saw full-time. It is very tough, but it bit the dust when it encountered a hidden drywall screw. Those hardened screws will take out a lot of blades, so that's no knock on the Lenox. After a long time of searching I finally found a saw service that will resharpen it, although Lenox does not and doesn't recommend it.
I recently acquired a 1/2" Wood Slicer, and IMHO it is a superb blade. I can't recommend it highly enough. It tracks exceedingly well. I use it only for resawing, since the kerf is very narrow and sawing curves and circles is very difficult. It's the best resaw blade I've used when used only for that purpose.
I get 3/4" x 141" 3/4" x 3tpi blades for about $11 from my local saw shop. An equivalent carbide is $250. For the amount of resawing I will ever do there is no economic justification to go carbide. However, carbide leaves a smoother cut, if that is essential. If you were sawing expensive veneers then it could pay.
Begin by asking what about your current situation you want to improve?
I would like to be able to walk over to the saw, set the fence at a 1/16 or a 1/10" and saw off a slice.
Would rather not use a single point fence. I find the "steering" of the piece to be confusing. I have dyslexia or dysgraphia or dis-something And I get befuddled trying to make the saw go to the line when its the piece of wood that moves but not the saw. Probably second nature to most people but for me it is different on different days.
What I really need is a dedicated saw for resawing, but I can't justify it. Only resaw occasionally, don't have the room, or the money. Table Saw, you just change the blade, make the cuts and move on, Bandsaw, you change the blade and fiddle with the saw while the rest of your hair turns grey.
Have not found a good local saw shop. Saw and article that recommended a blade that had 1 1/2 or 2 tpi for roughing bowl blanks. Called a local saw shop and discussed it with them. "Yep, we got that, Lennox steel bands, we'll weld you up a couple." Went to get them and they were 3 tpi. Their explanation was, "Never heard of what ever it was you said, them's what everbody buys."
i havent read the other posts yet . Here is the one i use right now it is a 1/2" i belive 3tpi and it cut's and cuts i was using the wood slicer blade but i use this one now and it out cut's the wood slicer blade. I have the old delta with 6" riser on it with a 1 1/2 hp motor and it dowsn't know it is cutting wood i have cut 10" and it walk's right thro. iIt is from this co. http://www.supercutbandsaw.com/ Not a bad price my self i wouldn't go for a carbide blade. I have cut lot's of wood for 6mo now and it is as sharp as the first cut.
I posted already . Do you set your fence up for blade drift??? If not the wood will not track with any blade. You need to set the drift up with each blade to be right on. I can just push my wood one handed and the wood will lay on the fence with having to push had on the back side. Now if you have push hard on the back side the fence isn't set right. If just in case you don't know about blade drift. check back and i am sure me or some one else will tell you how. In case you don't know. I have use the wood slicer from highland hardware for a couple yrs. But the blade from this co will out cut the wood slicer tho. http://www.supercutbandsaw.com/
Some one mentiuoned that wood slicer blades can be resharpened and I suppose they could be done by hand, but due to their unique variable tooth spacing and variable tooth set I dont see how they could be sharpened on a traditional band sharpener.
I leave one on my saw all the time and resawing is only a small fraction of what I do. It is true that it cuts a narrower kerf but it is also a thinner blade so it still has plenty of room for making curved cuts. The minimum radius it will cut is only slightly larger than a more traditional 1/2 blade. it tracks so well and is so easy to hold to a line that I find it easier to curves with than a traditional blade. I suppose that I should add that even though most all of my work incorperates curves, I rarely cut curves with less than a 12" radius.
It is one of the new breed of blades that has impulse hardened teeth so the blade life is much longer than traditional blades and because it requires less blade tension it will suffer a bit less work hardening and last long enough for you to utilize the extra tooth life.
And as others have said the cut quality is superb. With a properly set up saw and fence the cut off the saw will be so smooth you will be tempted to finish the surface with a ROS.
let me put it this way: the blades require less tension, they have less flutter, run quiter, and last onger. so why don't you already have one?
Barry If you get a chancelook at the site Del is pushing. I found this place marbe 6 months and I`m very pleased with them. They have blades that are carbide coated on the teeth and they don`t cost more. You should at least take a look. I don`t reallly see myself buying any other blade and I used the woodslicer for a few years and thought alot of it till I found this place. Larry
Fence sawing: Either the saw wheels need to be adjusted (assuming they are crowned) so that the blade tacks to accommodate your fence alignment or the fence needs to be aligned to accommodate what direction the blade is oriented. This is the only way you will be able to set the fence for some thickness of cut and cut it. The balde has nothing to do with this aspect of resawing. I never use a "point" fence.
Diddling with the saw: It is a fact of life. Any time you change either the thickness and/or the width of the blade the guides need to be optimally adjusted for the new blade thickness and width. If you are having unsatisfactory performance it may be that these adjustments are not properly made for the blade in place.
A new blade will not change any of these facts of band saw life.
The variable tooth blades will provide a smoother cut if that is important. It may be the difference in removing 0.010" of material to smooth the resawed piece vs 0.015" is important enough to justify the more expensive blade. For 20 times the price a carbide blade will provide an even smoother cut. I find that how I feed the material to be sawed is way more important in producing a smooth cut than the blade.
Bill When I first found them I ordered their catalog and they had the prices in there at that time. I don`t know if they changed it since and took out the prices or not. I just looked at their on line catalog and they didn`t have them in there. I hate it when people don`t put prices in their catalogs, it makes me think they are trying to hide something. But I`ll still go there fist when I need blades again. Larry
i am just posting because you put it on here a few mo. ago and i bought one. It cuts and cuts. I am like you i have been using the wood slicer for a couple yrs. I won't be ordering and more of the slicer. This blade hasn't even slowed down. Now it leve's more or the saw marks than the slicer but i sand them down any way. I want the wood cut . I belive the 1 hp motor will do just fine with this blade. thanks for posting a while back Bill. del
Or you guys are buying Supercut's premium blades. Shop I worked for used their carbon steel blades for years and I didn't think much of them, just your average bandsaw blade that leads one to head to the table saw if they want smooth. Certainly wouldn't leave a woodslicer in the dust, but still better than those I solder up myself.
Now this was about 15 years ago, and the boss always bought the absolute cheapest blade he could find so take my comments for what they are worth.
when you cut wood into their will be saw mark's. Now those are planed off or sanded ?? I know the wood slicer get better saw mark's but i sand them off or plane the wood when it is resawed so the marks don't make that much different. Not you will not get a glue up board off of eather blade. I just want the blade to cut the wood into smaller board's so i don't care about the saw mark's. Just like the ruff sawed board's . I plane them down to a smooth side and than resaw. Now if i am doing a box i sand the smooth side than dovetale so that the sawed side is out. Now the dovetales are prowed any way when you sand them down you are getting rid of the saw mark's so all is ok. just my 3 cents inflation you know
The woodslicer is a vastly better finished cut than any other blade I've used. I have one I save for times when I want that good cut. Most of the time, I do as you do and sand or plane off the saw marks. At $30 a blade, I tend to conserve them though.
My regular use blades come in 100' rolls from Victor Machinery in NYC and I cut them to length and silver solder them together (with hard solder, not plumbers solder). The cut quality is not as good as a commercial blade on the whole, but they are fantasitically cheap to make this way, about $5 per blade the last time I bought 2 rolls.
The other thing I've found is that if you're just cutting thin stuff flatwise, blades seem to last forever. If you do a bunch of resawing, you start finding that the otherwise good blade is actually rather dull. If you have to push hard and the blade tends to wander all over, it's time for a nice sharp one.
I too got frustrated by the lack of prices in the on-line/downloadable catalog. I called them at about 10:00am and got voice mail. Tried the standard line and the 800 line again and got voice mail everywhere.
Placed the Oder with Highland Hardware. Hours later the Supercut people called me back. Turns out their Premium Gold Carbide impregnated Blade with variable spacing on the teeth is about $26 and the Wood Slicer form Highland is $30. (also has variable tooth spacing. Everyone claims this improves the cut.)
If they had answered the phone or posted a price and if they had a blade similar to Highlands bowl blank blade I would have bought from them. I even went on line to to double check their time zone and they are in the same one I am and claimed they were open from 8 to 5. You gots to answer the phone or you are not in bidness.
I also am frustrated when a potential vendor does not have pricing online. Unless the company is a one or two person operation I would agree that someone should be answering the phone during published operating hours.
