We value your privacy.
For the past 3 months I have been pulling my few hairs out trying to get MS or HP to solve this problem: my desktop PC locks up (system unresponsive). In Jan I had to install a new Hard Drive due to a failure of some internal component. The replacement process and recovery disks have all been monitored by an HP super-tech. All was well for a few days and now the system is back to locking up - - nothing works, the little blue circle goes around and the screen/desktop turns white. A few seconds later all is normal. A few seconds - -or 3 minutes later, it locks up again. I have exhausted all known alternatives, save junking the HP entirely. Win& Home Delux
Anyone have an idea/protocol to suggest? Thanks, Phil
My dad was an aerospace engineer, a EE. His simple yet effective approach to electronics was to use an open palm and slap the side of the box(TV etc) with firmness. While it seldom worked for me, his method was very successful when applied, not only to the electronics but also to myself.
My theory is to let the smoke out and buy something that is more functional, fixing these things has become something of the past, PC's aren't Hip any more, or so my HS student tells me.
Take care,
Jim
Still thinking my dad's process might work in certain applied situations
I would start by looking at what processes are running in the background. Open task manager and see if something is hogging cpu time and eliminate that process. if its an HP branded computer I would remove all HP programs to start and see what that does. Its a process of elimination.
We have a heavy-duty commercial duty HP at work and it does this, too. HP says it's a defective MB. They've also replaced said MB once, so that one must've been defective, too. It's off being replaced again.
If yes, please try this simple remedy. It may or may not fix the problem, but it costs only an hour of you time.
Open up the PC, use a vacuum cleaner to suck all the dust out. Remove the memory modules and clean the contacts with a pencil eraser, then put them back firmly. Do the same for all expansion boards.
Plug and unplug (several times to make sure the contacts are clean) all the electrical connectors, one at a time, making sure the connectors are fully seated.
Thank you for all the good suggestions and comments. I like the idea of deep cleaning and removing HP's pgms. Its the pgms with strange company origins that make me most suspicious so I may start with them. OTOH, I could call HP again and see just what in the name of peanut butter and jelly they think they have for a QA program these days!!! If I ever solve this problem, without buying an Apple, I will post the results. Thanks again. Phil
instal this program. It will remove lot's of junk and i mean lot's of junk. Also do you do the scan disk and defreg from safe mode. That is where it should be done.
Are your fans running OK? Cheap fans are used in all PCs and I seen many slow or stopped fans. The one on the CPU is the most critical but I have seen computer lockup problems by stopped fans in the power supply too. I have a fix that has worked for me for stuck fans but I don't necessarily recommend it to anyone else. Most fans have a metallic sticker on one end. If you peal it off, you will see a rubber plug. Remove it and you will see the end of the fan shaft. I shoot a tiny bit of WD-40 or sometimes a little lightweight camera lubricant in around the shaft and then try to turn the fan blades with my fingers. Once I get it to where it will turn, I use the vacuum hose to turn it really fast - probably a lot faster then it should be turning I then replace the plug, clean all lubricant off the the end around the plug, and put the sticker back on. I have fixed 15 or 20 fans this way.
I don't think removing the HP programs is going to help. Have you been keeping your antivirus up to date?
Wouldn't it take someone who really knows computers to determine which is junk and which is not? For instance, the temp folder might be junk or it might not. Also I think there might be registry folders in there that could be junk.
you could try loading ubuntu operating system and see if the problems persist. Just make sure you have everything to reload windows afterwards though....the OS disk and serial number.
- ensure your anti-virus software is up to date and run a full system scan.
- download the spybot program someone suggested and run it to clean up any crap that may be running in the back ground
- clean the inside of your computer and make sure all fans are running properly - very important
- defrag your computer after you have done everything else
(Depending on how old the computer is) if the problem still occurs:
1) throw it away and buy a new system that doesn't have all the extra crap companies like HP put in them. Dell makes nice systems.
Everyone I know who buys a Mac loves them and they rarely have virus problems. I'm a PC man myself, but that's just cause I'm chicken to switch. It all depends on what you are going to do with it. They also cost more that a PC
2) If you don't want to buy new and you can't find a solution something that will definately work is to go to (again) computer store that works on computers and have them install a fresh copy of Windows XP or Windows 7 depending on what your computer can run. Stay away from Vista, it's crap. Have them transfer all your files and you can reinstall any programs you want/need after that. Make sure you let them know what programs you will be using so they can transfer all your data for them.
The bottom line is this. As we use computers they can get clogged up with crap that slows them down. CNew computers are Cheap if you aren't in need of massive power and functionality. If you are running large programs that require heavy video and computing power you can buy a nice mid-range computer for under $700.00 or as low as $400 that will do email, write letters, run spreadhseets, watch videos, etc. No need to spend more than that. If you do get a new PC get one with Windows 7 and download and install Windows Security Essentials - it's free and will keep 99.99% of all viruses and internet crap out of your computer.
I meant to say - If you are Not running massive programs that require huge video and computing power you can buy a solid system for under $700.00!
You can check out NewEgg.com, they have excellent prices on a variety of systems. If you buy localls, have the store transfer your data over for you and make sure everything works.
Finally - The easiest way to recover from a major problem is to have a back up of your computer. Most people have external harddrives set to automatically back up your system on a regular schedule. I prefer to run a second harddrive on my system and clone it every couple of weeks. Basically, copoy my main harddrive onto my back up - this allows me to simply switch a single cable in the box and bingo! I have my computer back minus whatever I have done since I last cloned it. Ususally just recent email and a few internet links.
Look in the Windows Event Viewer and see if there is anything reported around the time of the last lock up. Also look at system events at the boot up time to see if there is any disk problems and the like reported.
Reseat all disk cables particularly the SATA cables - they are more problematic than the old IDE cables.
Windows 7, if you have it, has a memory test program but I don't know how good it is. You can download a free one, Memtest86+, from www.memtest.org and burn it to CD. Boot the PC with the CD and let the test run a long time, overnight is best. Computers, unless they are high-end server class machines, do not do any error checking of RAM contents so a bad location can cause all sorts of problems. You should have no errors reported.
Thanks for all the suggestions! Just now, the system failed and the power went off. I re-started in the Safe mode, ran the diagnostics and they all passed. Then, during the re-start the screen went black and stayed that way. So, I started all over, did the same checks, same results, and just abandoned it. About 20 minutes later, Win7 started!! SHocked me to say the least. I called HP and they are having some bigshot TS guy call me tomorrow. We will see and the saga continues. Bottom line, I need to clean the fans, the connections, the insides and buy a MAC! phil
Over the years, I have had two different HP desktop computers. (Because they came through work) Both of them had proprietary hardware and software installed with very limited or no driver choices and ended up being a royal pain for me to keep running. They had no upgrade path and strange interfaces. After that, I have made it a point to stay away from HP computers. I have had luck with printers and other items, but I will never buy another HP computer.
I should note that this is for desktop computers. I have no experience with HP laptops. All laptops are a bit weird and the HP's may be no worse than the others.
I've been using nothing but HP business model computers here since I stopped building my own years ago. My desktop unit has HP programs on it that I never use but they're there. I can say from experience working on several Dells and Gateways that they also are loaded with their own proprietary software.
I'm not buying the bit about the HP programs being the culprit. It sounds more like some kind of hardware issue and the first thing I'd check are the cooling fans.
I'm still picking HP over Dell and the rest because I think they're still better. However, as I've mentioned in the past, I think it's not beyond the realm of possibility that my next system could be a Mac. The iMac my son has is well beyond anything I've seen from any other PC maker running any version of Windows.
I agree with David. Almost ALL pc companies load their systems up with software you do not need (Dell included). It is unlikely that software and more likely something like the fans. Someone earlier in the thread suggested vacuuming out the system and reseating the ram--good idea (carefully). I have seen fans and heat sinks clogged with dust and once clean, run fine. I have also replaced a lot of system fans (usually stick out the back). If that fan isn't running or working properly, the system will overheat and shut itself down or freeze up.
It could be some spyware, although I thought you said you put in a new hard drive and reinstalled system. If you did that from scratch and did not recopy old infected data, and it still freezed up, then it probably isn't spyware. Go to Malwarebytes.org and get the free version of antimalware to check this stuff (it catches almost everything).
No problem. Perhaps the business ones are better. I can only go by my experience. Both of the ones I had were, according to HP, not upgradable. I wanted to go to the next generation of Windows on them and HP specifically said no drivers were available to do it. (on board audio and video) That was just my experience. I had nothing but problems with both machines and have never had anywhere near that much since dumping them. Others have good experiences, and I do not know about the business versions or laptops. These were both consumer grade machines that were a good price through work.
For me, it was not the software that was the issue. I can fix that. (most of the time, I fix it by installing linux as soon as I get the machine home ) It was non-standard, non-upgradable hardware that bothered me.
As I said, just my experience, but I will stick with what works for me for now
Joanne I went to the malware site and read through the buisness and it said in one place "Free 30 day trial" is that what it is a 30 trial and then you have to start buying it? That isn`t what I would exactly call free or am I missing something like I usally do? Thank you Larry
David and Joanne Thanks a lot, that did it. Of courseit was me, I just didn`t see what I was suppose to see. It found 4 things that I knew was there but I didn`t know how to get to it and forgot about. It seems like the computer is running better. Thanks Again Larry
I always build my own computers, (since I replaced our Commodore 64) but have worked on many others - my oldest son is the County IT for the entire system and my youngest son has worked in a computer shop. I (and they agree with me) found HP to be the worst systems as they almost always used proprietary drivers for the video, audio etc. Often people would find new software was not compatible and their were no updated drivers available. I have never recommended HP as a purchase for anyone. Dell did have some similar problems but I rarely ran into that with Gateway and almost never with custom built units. This may have changed in the last 3 or four years as I haven't been very active on other computers for a while - but I doubt much. As Dan said this applies to the Desktops only - Laptops are another animal.
