Re: need advice
Re: need advice
Re: need advice
Bill, for a magic wand you can take stick about 3/4" square and grind a taper on one end that will fit into the shaft if the head stock.  Only need about an inch of taper.  Insert into the head stock and hit the end with a hammer to seat it.  Bring up the tailstock to support it.  (assuming a No 2 Morse taper.)  When nearly finished you can take away the tailstock and finish up the point.
Haven't made a bracelet/bangle in a long time but I think the hole size is about 2 5/8".  Drill a hole in a scrap and see what she can slip her hand through.  Assuming you don't have a chuck.  Mount a scrap on a faceplate and turn a matching stub.  Bandsaw a ring around the hole that fits and use the stub as a jamb chuck.  Gently turn the outside of the bangle.  You may have to turn it around to clean up the inside edge.  You can also turn a groove in a scrap and jamb the bracelet into the groove to clean up the edges.  For a slender more delicate looking bangle you and make some "plywood" blanks or just turn one out of Baltic Birch.
If the turning bug bites, there is madness.  I used to spend part of everyday hunting for turning stock while my son turned it into shavings.
On a smaller scale, lets bring back wooden rings.
Re: Re: need advice
Classic Starter
would be a honey dipper
Re: Re: need advice
Re: Classic Starter
I turned a few spindles, and went straight to bowls. Not the easiest thing to do for starting. Ask her what is interesting to her.
Re: Re: need advice
Re: Classic Starter
Honey dipper followed by Christmas tree ornament in the shape of a Christmas tree using the honey-dipper technique for lightness between the "branches". A 1/16" thick, flat-blade parting tool makes both a lot easier.
Re: Re: need advice
refrigerator magnets......
Re: Re: need advice
Re: need advice
Fun things to make would be spinning tops. And even more fun for both of you would be for you to fashion for for her a simple chatter tool. Then she could turn all kinds of chatter designs that she can instantly color just by lightly holding a colored felt tip pen to the chatter design while it's turning pretty fast on the lathe.
