Noticed new NOVA sharpening device
Joe shelton
Has anyone used one of these? It looks sturdy and competent in photos, and I'm not skillful at grinding my tools.
Joe shelton
Re: Noticed new NOVA sharpening device *LINK*
Dick Coers
I see a little improvement over the Wolverine Vari-Grind being able to grind larger diameter gouges, but that has no advantage for me since I don't have huge gouges. My concern would be on the fit of the sliding table in the base. The base is just stamped steel, no machining, so it may fit a bit loose.
Just a caution. Even with these jigs, it still takes some skill to use them correctly. Nothing a little practice won't help. Just don't expect to become a master sharpener the day more jigs show up.
https://www.youtube.com/watch?v=yQgr6rZ4X7k
Don Stephan
There was a steep learning curve for freehand grinding, because there is so little discussion of cutting edges, but the Robo Rest is so much faster than any jig that I no longer put off touching up the edge of spindle gouges, bowl gouges, and scrapers, especially when I am switching back and forth between tools and tip angles.
