Tool sets I recommend
OK these aren't sets you can buy as a set but these are the tools I recommend and will describe why below. I have well over 100 tools and use them all from time to time because I turn a little bit of everything. However 90 percent of my turning is done with this set. Top to bottom. A Thompson parting tool, Thompson 1/2" bowl gouge, 3/4" spindle roughing gouge, Thompson 3/8" detail gouge, Thompson skew, Thompson scraper tool blank ground to a round negative rake scraper, and John Jordan Shear scraper. With this set of tools I can turn virtually everything except hollowing and I do hollow bowls and boxes but not anything through a small hole. This set should work extremely well for just about anyone.
The set I recommend for bowl turning is a Thompson parting tool, A 1/2" thompson bowl gouge, and Thompson round nose scraper and John Jordan shear scraper. With those tools you can turn just about any bowl. You may have to regrind the bowl gouge to do the bottom of steep sided bowls or buy a second gouge and grind it accordingly.
Carbide tool set. With this set I can turn just about any bowl including steep sided bowls, I can turn boxes, platters, Pens, spindles (although you might want a skew for just a few cuts like V cuts for spindles) A thompson parting tool, A Hunter #5 carbide tool for doing steep sided bowls and the bottom of boxes, and a Hunter Osprey. With those 3 tools I can turn an awful lot of stuff. If you turn larger bowls a Hunter Hercules would be easier for roughing, than the Osprey.
I do probably 90 percent of all the work I do with the tools pictured above. The only other tools I use are hollowing tools for doing larger vessels and Christmas ornaments.
Re: Tool sets I recommend
good choices, John
GaryG in MD
I can remember that one of my first "big" questions when I joined my first woodturning club was "what is the (minimum) set of tools that I absolutely have to have to get a good start in general turning. That was 16 years ago, and tools have changed since then, but I started with a pair of 5/8" (American) bowl gouges (one ground at about 75º and one ground at about 40º, a 3/8" spindle gouge, a 3/4" SRG, a heavy-duty 1-1/2" round-nose scraper (which I have now ground to a negative rake), a 3/16" parting/beading tool, a 1/16" parting tool, and a 1" skew. There's not much you can't make with those. How many tools do I have now? Hey, he who dies with the most tools wins. I may not win (certainly not with you around), but it doesn't stop me from trying. But for beginners, that's a very good start.
And, yes (!), I'm a huge fan of Doug Thompson's and Mike Hunter's tools and have many of both and now could not turn without them. I have to admit that one of my "go to" tools is the black-handle Elsworth Signature 5/8" (American) bowl gouge. My shortest tool, and you know what that means, is the Henry Taylor 3/8" spindle gouge. THAT is clearly my GO TO tool, first, if it is close to what I need for the cut. And my first choice is always to cut, not scrape, although a well-done shear scrape is a very important cut. I find myself more and more comfortable for subtle clean up with the negative-rake bowl scraper (left side cut quite long) � la Stuart Batty, although mine is made by Rudy Lopez from a Doug Thompson skew blank. ...GG
One more choice
IN my haste to put together the tool recommendations I forgot one. The clewes tool will do bowls and platters from roughing to finishing cuts as well as steep sided bowls. You can't use it as a bevel rubbing tool like you can the #5 and Osprey but if you take light cuts for the last few passes it will leave a very good sandable finish. It would be very hard to get a catch with this tool and virtyually no learning curve. Just stick it in the wood and go.
Joe Fleming
Joe Fleming
The top photo is the set I recommend too. Except the Jordan scraper. I consider it more of a luxury tool.
Before John started marketing his own scraper, he had a homemade version that use used in demos. So I made one for myself.
Joe I used a regular flat scraper for many years. After getting John's I recommend it because it is so much better. It's double ended with a the opposite angle on the other end of the blade. It just flat cuts great and is easy to establish a new burr.
Joe Fleming
Joe Fleming
I ground both ends too. One to the left and one to the right. Interchangeable - just like the master - but not as pretty.
Which side up for JJ scraper?
david
I keep forgetting which side should be up. Bevel up or bevel down? Perhaps I keep forgetting is because I don't use the tool enough--am usually satisfied with shear scraping with the gouge in a closed position for the outside and with a teardrop scraper on the inside of my bowls.
Re: Which side up for JJ scraper?
I call it short point up or bevel down. In other words the sharp point should be on top. I think it just holds a burr better than my straight HSS scraper. I also like that the edge is so long. I start the cut in the middle of the blade and if I take light cuts I can get away with going above the middle and certainly below the middle. This gives me a lot longer usage between establishing a new burr. The total length of the edge is almost twice what my flat scraper is. Yours may vary of course.
