Turning green blanks
cameron
As I am moving down my turning journey (just got my lathe in the fall) I have ended up with a driveway full of very large oak pieces from some local trees that have been cut down (some with diameters >5 feet.) I've already roughed out 3 bowls to ~1" thick in the range of 15-18" diameter, ~10" deep (HEAVY). I learned a few things already like I'll take a beating when roughing out blanks, related, my crown roughing gouge was apparently not for this job as I noticed the ferrule is now cracked, everything in the area is going to get soaked... I put some shavings in the bowl, wrapped the outside in cling wrap and taped a paperbag across the top. After a week of sitting, no cracks or mold so far...
I have a couple questions that I'm hoping I can get some advice on as I'd hate to rough out a bunch of bowls only to find them useless down the road:
1. What type of surface quality do I need to shoot for in the green stage? With the wood being so soft I have a bunch of tear out. Since these things are over-sized and will be re-turned, can I just ignore the surface quality at this stage?
2. So far I've been making recessed bottoms to expand my chuck, been straight forward but sacrifices a lot of material (my titan jaws are bigger on the expansion side than on the compression.) I swapped to a tenon last night but similar to item #1, the surface quality I can get is pretty bad, lot of torn fibers. I assume I can clamp this up and crush the whole thing down without too much risk of the thing flying off the lathe. Is this normal or do you guys normally get a nice clean tenon? Do you prefer a tenon or a recess? Do you guys bottom out the jaw ends or the chuck body when mounting a piece, does it matter?
3. Any suggestions on keeping my bed fromturing into a pile of rust? I've been wiping it down, blowing it off with air and sprayed some WD40 on it but it doesn't seem to be enough...
Thanks
