200+ woodworking book reviews
sanding disks
sanding disks
sanding disks
eliot feldman
There's a brand of sanding disk the name of which escapes me. I remember that it comes from Canada, it has a brownish color, and the abrasives are not set randomly but rather in a regular matrix pattern. I'll recognize the name as soon as I see it written down. Can anyone help me out with the name?
Re: sanding disks
Mirka, Abranet, klingspor. flint, Aluminum Oxide
Re: sanding disks
Re: sanding disks
GaryG in MD
Eliot,
It sounds to me like you're talking about Abranet.
It's a mesh material with grit bonded on it.
The sanding residue goes right through the holes rather than clogging.
I like it, but it's expensive, and I have found them to be rather fragile -- perhaps better used by hand rather than power sanding.
...GG
Re: sanding disks
Re: sanding disks
robo hippy
Astradot. Got some once, didn't like it at all. Very slow cutting in the coarser grits. The blue discs from Vince are much better.
robo hippy
Re: sanding disks
I love Vince's blue discs
Re: sanding disks
Re: sanding disks
eliot feldman
HI Garry. Actually, it's Astrodot. But Robo Hippy doesn't like them. I always did. But I'll look into what Robo says.
Re: sanding disks
Re: sanding disks
eliot feldman
Apparently you and John prefer Vince. Is that a brand , or is Vince someone you know so I can get in touch with him?
Re: sanding disks
Re: sanding disks
I guess we should have been more clear. It is Vinceswoodnwonders.com as George put up the links. His blue discs just keep on sanding. I use a crepe rubber bar to clean the disc after using and it's amazing how much life I get out of them.
Re: sanding disks
Re: blue sanding disks
david
What I like about the blue discs is the film backing and ability to use dry or wet. I usually use the finer grits for wet sanding.
Re: sanding disks
Vince Welch
Hi Elliot,
Here is the link folks have been referring too. http://vinceswoodnwonders.com/blue-flex-discs/
Let me know how I can help you.
877.284.8969
Vince
