large carving
large carving
large carving
I haven't had much time to do any turning lately. Well actually I made 8 segmented ornaments. maybe I'll have time to photograph them later. I've been spending a lot of time with my largest carver. It all started with a Dremel and then a Foredom. Then I got a 2" arbortec with angle grinder. Then a 4" Lancelot cutter with angle grinder. Then I got a 7" angle grinder with 36 grit paper. All of that was fun but I decided I needed a really big carver. So I bought this monster. 18HP, 12 1/2" carbide teeth on a 14" disc. Now it removes wood.
I have about 15 or more stumps to remove and started to rent a stump grinder. Definitely would have been faster than this manual version but 3 days rental was going to be 0ver $700. I found this for $630 and it cost me $54 to put new cutters on it. It's a bear to use. It's very much like turning hollow vessels. You can't see the cutter so you have to do it by feel. I found if you cut and leave steps just like I do when hollowing, you can feel those steps and know how deep to make the next pass.
The right wheel has a brake so you lock it and use it as the pivot point. Then you have to muscle it left and right and up and down. quite a workout.
Re: large carving
Re: large carving
Greg Haugen
Yeah, I bet that is a beast to run. I wish we were closer. We have a 3 ft radius stump grinder and have access to a 6 ft radius grinder. Hang on to that thing. Wow.
Re: large carving
You need to hitch up a younger horse!
Dick Coers
A neighbor just had two stumps ground out. A huge remote control, diesel Vermeer machine was in the yard for what seemed like less than 15 minutes to take out a 30" soft maple. All you need is money!
Re: large carving
Re: You need to hitch up a younger horse!
John C Lucas
I had one ground away in an emergency to build my garage. It was $124. I have 15 of various sizes plus a bunch of roots that need to be ground down. I could rent the big ones but looked like it would take 3 days minimum. This isnt bad. This was a very large and still green stump. Ive worked on it about 3 hours. Have another hour to go probably. I cut the last 5 in about an hour or less each. only have 2 large stumps left. Then i have about 5 that are flush with the ground that i want to cut below ground. Those should all go pretty quickly. Between that and a couple of flat wood projects its been hard to get much turning done
Re: large carving
Re: large carving
Joe Mohnike
Winter is comming on, looks like a great place for a fire pit to me.
Re: large carving
Re: large carving
Bob Macgregor
Maybe you could rig up a very long extension handle to gain more leverage?
Re: large carving
We have a fire pit.
Re: large carving
Im thinking a large captured bar system
John C Lucas
Then rig up a video monitor like the Trent Bosh system. Oh while im at it why not add servos so i can do it all grom my computer while i monitor woodcengral
Re: large carving
You need an app for that....
Re: large carving
I'm app to hurt myself
Re: large carving
Mike Stafford
Re: large carving
Mike Stafford
When I was a teenager we lost several large oaks to a hurricane but, of course the stumps remained in the ground.
My dad gave me the job of using a brace and bit to bore hundreds of holes into those stumps as deeply as I could. Have you ever tried drilling 1" holes into green oak end grain? I am still sore from it.
Once all the holes were drilled to my father's satisfaction he poured kerosene into them and let it soak in. He kept pouring in the kerosene until that stump was saturated.
Then he set them afire. I think those stumps burned for a month. I know there was smoke coming out of the ground for a long time. Us kids were told to stay away from where the stumps were because the ground could collapse under us and we could fall into the the smoldering root system.
We didn't even get to roast marshmallows on the fire because it was a stinking kerosene fire.
Re: large carving
Re: large carving
Mike I tried to burn out a black locust stump using sort of the same method. It stunk for weeks and all the neighbors complained.
Re: large carving
Re: Im thinking a large captured bar system
Bob Macgregor
Our local university has a steep bank behind their stadium that they mow with a remote-controlled lawn mower, so I don't see why you couldn't do it with the stump grinder.
Re: large carving
My wife is the remote control and I'm the motor
Re: large carving
Chuck Jones - West TN
Have you priced kerosene lately?
Re: large carving
Brad Vietje
Innoculate with Mushroom Spores and Harvest Food.
Brad Vietje
I have no passion for mowing lawns, so this work just wouldn't rise to "must-do" status for me.
You could have whacked them each a few times with an axe, dumped on a few shovels of dirt, and let Mother Nature turn 'em into compost. Not very fast, but a sure bet if you wait long enough. AND, you could even grow 'shrooms for the time it takes for them to break down. Sure -- you'd have some ugly lumps to mow around, but meh -- no big deal. No way would I spend hundreds of dollars to remove stumps -- just not very important to me.
That's just one fella's 2 cents, and perhaps not even worth that!
Safe spinning,
Brad Vietje
Newbury, VT
(where men are men, and lawns are -- apparently -- "stumpy")
Re: large carving
Dennis in Southern Oregon
Re: large carving
Mike, I can commiserate with you regarding the boring. When I was a teenager, I got the task of wiring our 60 year old oak-framed farm house when REA electricity finally came to to SW Missouri. I too had only a brace and some well used bits to bore many tens of holes.
Re: large carving
Re: large carving
mikeee12345
Good thing that you had that "Cordless" Brace & Bit drill to use for that job.
Yikes!, that had to be no fun at all!
Re: large carving
SWMBO Rules!
