sand and snow
Since East Tennessee is basically snowed in with 4" here on the farm, and I've already fed and watered the animals, AND it is freezing cold and dark which makes me lazy....
I thought I'd share a couple of little sanding things. Feel free to critique, belittle, expound, improve, go off on a tangent, or simply ignore.
SOFT SANDING BLOCKS
There are lots of ways to hold sandpaper for use while turning or with the lathe off. This is one of my favorites for things larger than small spindles. I'm putting it here because when I showed it to someone recently they said "what a great idea!" You can judge.
It's simply sandpaper stretched tight around a flexible eraser. The original Magic Rub erasers work well as do the much cheaper ones from the Dollar Store.
I can control the paper far better than just holding it with my fingers for both the outside and inside of a form or bowl (if it's large enough), plates, platters, etc. With this I can get more pressure spread evenly over a larger area than I can ever get holding it in my fingers, even when folded several times. The eraser is flexible enough to conform to broad curves. I know you can buy flexible pads with sanding surface attached but they cost too much for my frugal side.
I also use these on carvings and chip carvings, small flat work, metals, etc. As a bonus there is always something handy to erase pencil marks!
BTW, I don't do this to keep my fingers from getting hot - if sanding when the lathe is turning it is turning at a very slow speed.
RIGID SANDING BLOCKS
And everyone uses rigid sanding blocks and has good ways to make them. This is what I like. Four pieces of 1/2" plywood cut 2" by about 8-10" long can hold 8 grits cut from the 2" rolls of cloth-backed Klingspor Gold. Spray adhesive holds them on. I find this size perfect to fit my hand for flattening surfaces, square edges, good control for rounding over edges and corners, etc.
ROLLS AT THE LATHE
This is how I keep the rolls of sandpaper on the wall behind the lathe. Dowel, brackets, and separators made from disks of thin plywood to minimize tangles.
Small bins underneath hold the strips of finer paper.
FAVORITE FINE SANDPAPER
The Klingspor Gold in rolls is my favorite coarser paper. My favorite fine grit in 600+ is Rhynowet. I've tried all kinds and nothing is better (for me). The backing is flexible, strong, and thicker than many wet/dry papers, it can be folded repeatedly to a sharp edge, and doesn't seem to load up as easily as some. They claim "synthetic resins on waterproof anti-slip latex paper." If it does load up I clean it. I cut this into strips about 1" wide by 3" long for all lathe use. I use more 600 grit than any other grit of any kind of paper.
Years ago I bought a life-time supply (from Highland Hardware, I think) but maybe I'm living too long. Time to reorder some.
http://www.supergrit.com/products/RedlineRedFlexSheets
BTW, I probably do as much or more sanding with the lathe turned off than spinning, sanding sometimes with the grain, across the grain, but especially with the figure. I think I get better results by hand. (I also use little scrapers instead of coarse paper but that's a different topic. I haven't done any power sanding for years.)
Nothing amazing, particularly innovative, or earth-shaking here....
Anyone have comments or tips related to sanding? (or snow?)
