OT, another use for the CBN wheel
I occasionally grind off the point of a hypodermic syringe needle to make a precision oiler. This is a pain with a file, a mess with a grinding wheel that is too coarse, and trouble to get out the Dremel with a fine cut-off wheel. Regardless, it would then be out with the diamond hone or stone to smooth the tip.
Today I tried the CBN wheel for this - wow, about 10 seconds and it was done, clean and smooth with no burrs.
This one is loaded with TriFlow with teflon.
If you work with miniature mechanical things or just need to get a tiny drop of oil in a tight spot and haven't used a syringe for this it might be worth a try.
Note, certain oils may eventually degrade the rubber plunger tip in disposable syringes which is why the better oilers I use have a glass body and plunger. I'll throw this one away after a bit. There are hundreds more on my syringe shelf!
