Lamp loaders
Lamp loaders
Lamp loaders
Gary clarke
I want to make a segmented floor lamp and am looking for suggestions on the best way to attach a loader to the base. Thanks in advance.
Re: Lamp loaders
Re: Lamp loaders
Stuart Johnson
I don't know your design but you could turn a base and silicone the loader in place. Sort of like an upside down bowl with a flat lid that sits on the floor with the loader inside. You might want to attach three small feet or knobs so it will sit flat.
Re: Lamp loaders
Re: Lamp loaders
I've repaired a fair number of lamps for people and if I remember correctly the loaders are simply held on by the nut that goes in the bottom to hold the whole lamp together. When I make my lamps I don't put lamp rod all the way through. I drill a 3/8" hole in the bottom column and then sort of force thread a short piece of lamp rod in the hole. I cover it with epoxy so that it sort of glues it self to the new threads. Then I can place washers, the lamp stand and if needed a lamp loader on the rod before screwing a nut and washer in place.
I also use short pieces of lamp rod in the top of the lamp screwed in the same way. This makes it challenging to get the wire through the lamp because it hits the short pieces of lamp rod. What I do is attach string to the wire. Then I suck the string through the lamp with a shop vac. Pull the string and wire through and your ready for some assembly.
Re: Lamp loaders
Re: Lamp loaders
AlanSweet
Is it possible to put the string through the rod before attaching it?
Re: Lamp loaders
Re: Lamp loaders
Brian Roberts
Sorry.....not understanding.........loader?
Re: Lamp loaders
Re: Lamp loaders
I suppose you could but the vacuum cleaner method works so well.
Re: Lamp loaders
Re: Lamp loaders
Do a google search for lamp loaders and you'll see all the photos you need plus places to buy them. I've never actually used them in my lamps but I've only built one floor lamp. I had a drawer full of really large washers I bought at a yard sale for a $1 so I simply epoxied them into the bottom of that lamp and then covered it with wood.
Re: Lamp loaders
Roger in MO
Re: Lamp loaders
Roger in MO
Learned something new today. On my only floor lamp (40 years ago) I turned a dovetail in the bottom of the base and poured molten lead in it. Probably not too smart :( but it worked :) . Lamp is still being used.
Re: Lamp loaders
Re: Lamp loaders
Like using a shop vac to pull a cord through electrical conduit.
