Russ Fairfield heir apparent
John Cahall
While I know Russ could never be replaced I would like to know who on this forum has become the "go to guy" when it comes to finishing questions? Russ was one that I own his videos and often asked for and received answers and advice from. I miss very much his wisdom and willingness to share it with others. My specific question now is what product would be Reccomended to replace Deft clear wood finish as an undercoating to Russ's tung oil, blo, and turpentine "home brew?" I am having difficulty finding it locally and want suggestions on an alternative. Thanks in advance.
Re: Russ Fairfield heir apparent
John Cahall
Correction Russ's home brew is turpentine, tung oil, and varnish.
Doug Turner
Shelac is a great undercoat for almost any finish, and cheaper than Deft
Hard act to follow, but...
Russ's extensive experience and willngness to share his knowledge were unique. The closest thing to an heir apparent is the collective and diverse experiences of the large group of accomplished woodworkers that frequent our forum, many of whom are familiar with Russ's techniques as well as those of other highly-regarded finishing experts. It has always been my contention that there is great value in this diversity. Instead of relying on one person's opinion, we can synthesize our own conclusions from the varied answers and approaches expresssed by the group. Sometimes there are several valid approaches to a woodworking or finishing question, and often you can gain valuable insights that you might not have gotten from a single source. Traditions are usually reliable, but there are many different ones out there, and many means to an end.
Toss out a question and see what happens.
Ellis Walentine, Host
Deft alternative
John Cahall
Russ knew exactly what was in every commercial finish. Haven't found anyone quite like him. Anyone know of a product similar to the content of Deft Clear Wood Finish? Thanks.
Re: Deft alternative
Brian Roberts
Deft Clear Wood Finish....in the "blue" can is just good old nitrocellulose lacquer.
Google Nitrocellulose lacquer and you will find multiple sources....both in spray cans and quarts, etc..
jim breeden
As I look at numerous wood type sites, I wonder if the Deft problem is only in some areas of the U.S.? Here in Albuquerque, we can find Deft at any of the big box stores, and ACE Hardware. Strange.
Well said, Ellis!!
buy commercial grade lacquer locally
I use Lacquer thinned about 50/50 with lacquer thinner for much of my finishing. I have been buying from a local commercial lacquer company locally. The stuff I buy from them is far superior to Deft in my opinion. I always had trouble with Deft burning through when I buff with the Beal system. I had to let the stuff harden for at least 3 days before buffing. The lacquer I buy from my local dealer is not only much less expensive it cures to the point you can buff it in about an hour or two.
Check around and see if there are any commercial dealers in your area. I doubt the place I buy it will ship since it's a hazardous material. I buy a gallon for about the price of 2 quarts of Deft.
Mike Jones
As an "undercoating", Deft* brand Sanding Sealer is very popular among wood finishers. It is a high solids nitrocellulose lacquer that fills minute scratches and pores. "Mylands" brand is very similar. These clear "primers" will work just fine under an oil/varnish topcoat. Lacquer-based sanding sealers contain stearates which makes the lacquer softer and easier to sand and helps to prevent clogging of sandpaper.
Other finish (topcoat) clear lacquers do not contain the stearates that improve the sanding, and generally speaking, are sold in two different grades. (1) An inexpensive clear lacquer sold primarily for finishing interior doors and trim. It is relatively hard and scratch-resistant when cured. (2) A more expensive nitrocellulose lacquer sold primarily for furniture builders. It is the hardest and most scratch resistant of this family of finishes.
Deft* brand finishing lacquers are "brushing lacquers", which means that a retarder has been added to slow the drying. Deft* brushing lacquers can be sprayed, but building up coats can cause some difficulies because of the retardants.
Geoff Whaling
I use, but not sure if you can get Wattyl "Rediseal" sealer plus "Stylwood" pre-catalysed nitro cellulose lacquer in the USA. It is available in a range of gloss / satin and is marketed as 10 to 95% gloss level and only comes in 4 lt (1 gal) 20 lt (5 gal) & 200 lt (44 gal) containers.
Unfortunately environmental & other legislation is making it harder to source products with high VOC content.
I thought Deft had a bunch of retarder in it
Dick Coers
So it could be used as a brushing lacquer. Or are there more than one kind of Deft?
Brand?
Brian Roberts
What is the brand ...and any other info?
Thanks!
Sherwin Williams, M L Cambells
Dick Coers
You might like acrylic modified lacquer as compared to traditional nitrocellulose. Also ask about different drying rate thinners. Depends on the humidity and temps, but you can get thinner with retarder added so it won't blush in high humidity conditions. It's that time of year in Central Illinois.
Keith Tompkins
Keith Tompkins
Hello John, While I'm no Russ Fairfield, I've never been a fan of using any kind of lacquer or sealer under an oil finish. In my humble opinion, the idea of Russ's formula is that the turpentine will carry the tung oil or linseed oil into the wood. Any lacquer will effectively block this action, and the oil mixture will simply dry on the surface of the lacquer. Sure, the finish will build more quickly, but do you really have an oil finish? Plus, any thin spots in the lacquer will allow oil to penetrate, resulting in a blotchy finish wherever the oil soaked through.
Re: Brand? *LINK*
I am using the J1 Pro lacquer thinner and the M74 or M75 Pre cat Gloss or semi gloss lacquer.
http://www.bencosales.com/
Keith I don't use oil on my bowls when I use lacquer. If I'm going to use an oil it's Walnut oil. I have played with some the oil and finish mixtures. They worked OK. Not sure why I quit using them. Well actually I am. I started using lacquer on my mirrors because it was a tougher, repairable finish and I guess it just carried over to bowls and vessels.
Re: Brand?
Brian Roberts
Thanks John.....
I wondered if you were using a pre-cat finish.
No finish (that I know of) that depends on solvent evaporation will be buff-able in the short time you spoke of.
One major advantage....IMHO... to nitrocellulose is the ease of repair....subsequent coats dissolve the previuos coats resulting in one thicker layer.
Sanding between coats is not necessary for bonding....although may be desired for leveling.
During my stint in a cabinet shop we used exclusively pre-cat lacquer.
It was great for putting a quick and very tough finish on cabinets.
We made VERY sure we would not have any reason to go back later and do any sanding for leveling....it was way too easy to sand thru a layer of the pre-cat........the ghost rings were impossible to eliminate.
It was a pita for clean-up and smelled far worse....thankfully we had a good spray booth.
For my (home shop) purposes pre-cat finish doesn't make sense.
My experience with guitar manufacturing involved dealing with many different finishes and mixtures of those finishes. An amazing amount of testing and research went into trying to develop the "perfect" formula for nitrocellulose lacquer. Varying the formulas to increase hardness, decrease dry time, improve flow-out, etc, etc.. A change made to improve one quality almost invariably had a negative effect on another.
Several guitar companies, working with the top finish companies, worked on it for years.....and probably continue to I am quite sure.
Taylor Guitars was the forerunner in developing a UV cured system of finishing for musical instruments. The change to UV cured finish became a necessity....to solve the huge bottleneck that was caused by the long cure times for the "old" finishes. I believe the banning of nitro finishes in California was, at that time, "just around the corner".....which was further impetus for change.
The company I worked for switched to a UV cured "system".....which definitely came with a "learning curve"....and touch-up was......well......a very real PITA....
I guess the bottom line is that there is no perfect finish....for all applications.
John Cahall
Thank you all for your inputs. I use the "home brew" exclusively on my peppermills and it has performed extremely well on the one we use daily. A quick buff every 2 or 3 months and looks great. If I could get by with no sealer as Keith mentioned above it would save a few steps. Any comments about sealing/no sealing? Also would shellac do as well? I sure do miss Russ. Thanks again.
Dennis in Southern Oregon
John, I am with Keith on this point. I only use the varnish, oil, thinner mixture when I want a penetrating oil-like finish that is more durable than plain oil. Note that there is a trade-off here. This mixture is effectively a thinned spar varnish. The resulting finish will be less scratch resistant than plain varnish but more resistant to chipping and cracking.
Deft supplier found, Porter Paints
John Cahall
If you are looking for a supplier of Deft Clear Wood Finish I found it at a Porter Paints store. The fellow there said that they purchased the Deft company and now have it in all Porter Paints stores. That took care of my problem finding it.
Re: Deft supplier found, Porter Paints
Brian Roberts
Isn't Porter Paints a PPG company?
And Deft is made by PPG....is it not?
Hard to keep up with all the corporate dancing............
John Cahall
Yes Brian, it is a PPG company.
Dick Hines
Dick Hines
Ace hardware in my area has it. Wood Craft has some the last time I was there. Their can look different though.
