To: Bill Howatt, would a picture help you to understand what I'm talking about. I'm sure my being a novice and not knowing the proper terminology doesn't make it easy to understand what I'm talking about. Thanks for the response. I did look at the One Way device you suggested & I think that might be the answer but I still would like you to look at a picture of my tailstock so you can see what I'm dealing with.
By all means post a picture and if it doesn't help me understand it may well help somebody else give you the info. You can give the model of your lathe and what task you need the adapter for which might help with getting you a solution.
You really should have posted this under your original thread to keep it all together.
Did you see John Lucas' post in your original thread?
I looked. Bestwoodtools doesn't have a 3/4x10 to morse #2 adaptor. They do sell 1"x8 and 1 1/4x8 to #2 morse adaptors at $64 and $74. Vic could make you one but I'm sure it would run about that price.
I don't know if the Powermatic live center would be any less expensive than the Oneway but that is a good way to go. If you want it not to rotate simply put something in the hole that is designed for that purpose. I use a Cotter pin. I often do this when I want to put the live center in the headstock and turn something attached to the 3/4x10 threads to make custom adaptors for the live center.
Posted this at the original thread, but I think this would do the trick -- made for mounting a small faceplate, it has the #2MT, the 3/4"x10 threads, and it's threaded for a draw bar. Still available?
Thanks to Ken Vaughan, Bill Howatt, John Lucas & Brad Vietje for their great suggestions. I know I will be able to find a solution to my problem with these answers. How do you include a picture with your text?
Just above the text box where I'm typing my response is a little blue circle (button with a "?" inside) where it reads: " Upload embedded file: ", and a rectangular button that reads "Browse".
It looks like this:
Just push the Browse button, and locate the file you want to insert. File size must be no bigger than 100 kB. Most camera photos are much bigger than that, so I open them and resize in Photoshop, but there are other programs that can be used to do this.
Give a shout out if you have trouble, and someone here who knows lots more about computers than I do will surely be able to help. Clicking on the little blue button also brings up more info.
Brad, I don't seem to get the same page as you showed w/ the 'BROUSE' selection on it. All I get is a line for an 'Optional Image URL:' w/ 'http://' inside the box.
Hey Dave -- this may be an Ellis issue. When I click on Reply, I get the stuff I posted on the top, and the following boxes nearer the bottom:
Optional Link URL:
Optional Link Title:
Optional Image URL:
The Optional Image URL: box is to include an image that's already hosted on the web somewhere. The Upload embedded file: "Browse" button is up above the box where I'm typing, and it is used for images that are on your computer drive, but not found elsewhere on the web (at least, that's how I use them), so you are browsing your own computer to find the image files.
When you click on Reply to this post (or any post) are you seeing the little yellow smiley face "emoticons" at the left side, below where it reads Your Name: etc...? If not, then the issue is in your preference settings, under Set Preferences up in the pale blue shaded box at the top, I think. If your profile settings are correct, you should see this stuff:
If you don't see those options for text size and color, and the little sniley face emoticons, check with Ellis about changing your settings, or explore them by clicking the Set Preferences text in blue up at the top.
My reply page looks nothing like what you are showing me. Could it be because I'm using a MAC. Also how do I get in touch w/ Ellis to solve this problem? Thanks for dealing with me on this issue.
Ellis is reached via e-mail here: ellis@woodcentral.com. I wrote to him and requested that he have a look at this thread and see if he could assist you, so you may want to hang tight for a day or so to give him time to check into this.
Dave, you need to create a profile for yourself. Then you need to reduce the size of your image to less than 100 Kb, then you can post it in your message. All this is explained in the FAQ file, linked from the gray navigation bar above the forum title ( and at the bottom of the page).
Let me know if you have any trouble. In a pinch, if you don't reduce your own photos, you can send them to me and I'll put them in your post for you, but please register yourself and have a whack at it.
Brad I will be making another adaptor as soon as I get my shop back up and running. I purchased some 3" thick plastic rod that I'm going to make cones for turning spheres. My wooden ones wear out and sometimes change shape so it doesn't fit the sphere as well as I like. I purchased the rod just before I had to move and it came after I packed up the shop. I stare at it frequently wishing I had my lathe.
Here is the second pic showing the tailstock fully assembled. I need an adapter piece that will thread into the tailstock mount and have a male MT (1 or 2) that will accept other devices that have a female MT (1 or 2) so I can have more devices that will attach to my tailstock to expand my capabilities.
I hope this clears up my problem to those who have been trying so hard to figure out what it is I need. I thank all of you who have been replying to my inquiries.
You may be out of luck. It appears that the threaded tailstock quil is solid. If I remember correctly you said the threads were 3/4x10. You could feasibly have someone drill and cut a #1 morse taper but it would probably be quite expensive.
It also looks like you have a live center (cup center) that will fit that tailstock quil. That's all you need for 90% percent of the things you will do on the lathe.
I have turned wooden adaptors that fit over a Cup center like that for certain projects many years ago when that was the only live center I had for my lathe.
The bad news: I've seen a lot of lathes, but never one with a tailstock like that! What is the make & model of the lathe? Swing over bed/ways? Like John says, you can do almost everything with a simple revolving center like what you have -- as long as it works and doesn't wear out. Once the bearings are shot, you'd be stuck.
You might have an easier time using/adapting a tail center from another lathe model that is the same swing as yours, if you can find one. If not, you might also try a rugged one from a smaller lathe, and making up an adapter from metal or a very dense wood to make it fit your ways.
Dave, is the threaded portion hollow at the other end? If so you may have a morse taper arbor stuck in it already. If so then all you'll need is some lubricant and a steel rod/punch that you can hammer it out with.
Interesting idea -- a solid(?) threaded ram with a #1 MT that's stuck in there backwards ? Hmmmm.... that would 'splian it! Hard to imaging a female MT w/out a hole to knock out the male taper, but there are still a few details lacking.
Well the pictures sure help a lot. If your quill is truly solid and there is not just a stuck male taper in there, your next option is to have something made at a local machine shop. MT #2 female socket with female 3/4"-10 tpi threads on the other end seems like a simple job for a decent machinist. You will lose some length between centers to achieve this though.
Thanks for the reply. I was thinking the same thing, but I also thought there might be a MT 1 or 2 shaft w/ a threaded male on the other end that would fit the threads I have. I'll contact some machine shops here to see if they can do something like that. My table is quite long so I won't loose to much with an adapter that take up space. My lathe is a Buffalo. They don't make them any more and you can't get parts for them anywhere. I'm trying to adapt it so I can start using up to date stuff.
