Wish List for Vacuum Chucking
david
I find that I am using my vacuum chucking system less and less. Major problem I have is am able to pull a strong enough vacuum on soft woods like Norfolk and Cook pine, which I turn a lot. Most of these are turned end grain also. On other woods I should be drawing a higher vacuum but I feel the seating of the wood on the vacuum gasket is not good enough. I have two of the smaller Oneway vacuum chucks, outfitted with an after market pink molded plastic "gasket" that I feel is too firm and not moldable/conforming to reversed bowl shapes. Have used the Oneway foam rubber "doughnut discs" that Oneway sells. Does anyone make/sell a soft gasket out of silicone? I don't know what the Shore hardness would be, but cured silicone still has softness to it. I once saw an article in the AAW magazine where someone had details on what he made from silicone, but it seemed to complicated to attempt. I like the idea of using PVC pipe to make various sized vacuum chucks but the gasket to reversed piece (wood) seal is what I think is lacking.
