Black Locust
Black Locust
Black Locust
Kelly M. Robison
Hi Fellow wood turners,
I live in the Pacific Northwest and a friend of mine was clearing some lots for another friend and ran into about a dozen trees that he had never seen before. The owner of the property told him that her father brought some seedlings with him from North Carolina about 50 years ago and that these trees were Black Locust. Now my question; I have never turned any wood of this sort; does anybody have any experience with this wood??? He is going to give me a 6 foot chunk from a tree that has been down about 2 years. Of course I am going to check it with a moisture meter and more than likely cut it into 24 inch rounds for working later. I did some research on the internet and found out a little about it; but it's always nice to get some input from all of you fellow wood workers.
Thanks,
Kelly in Port Orchard
Re: Black Locust
Re: Black Locust
Ralph Lindberg
Kelly
Yes, both my wife (Ellen) and I turn Black Locust. It's a little splintering, but it doesn't turn badly
Do you know about the local club? Meets at the 7th Day Adventist School in Bremerton on the LAST (not FOURTH) Wed of almost every month at 6:30PM.
This month's program will be by Molly Winton.
Re: Black Locust
Re: Black Locust
Rum
Limited experience and that was from before I had my lathe so I only attempted some flat work with it.
It cut up ok when wet with the table and hand saws, got some decent little slabs out of it. And that's about where the fun ended.
This was the only piece I've run into so it might have been worse than average, yadda yadda but anyway.. it was the most cantankerous wood I've worked with in a long time. Trying to carve or plane it meant very frequent visits to the sharpening station (every few dozen strokes the edge was just shot on my hand plane - which was an old stanley at the time - increased the bevel some which helped but was still horrid). I carved one large spoon out of it using (mostly - rough out anyway) an angle grinder powered carbide carving tool, which went ok.
It seems that it had a very high silica content. Was relatively dense (some pores but they were small). The grain went hither and yon as it chose (partially due to it being a solo yard tree - I'm imagining a stand tree would have straighter grain).
Still have one pretty good sized chunk of it left, no idea what the heck I'll do with it.
Re: Black Locust
Chuck Jones - West TN
Re: Black Locust
We have a fair amount of black locust (and honey locust) around here. I have turned a few pieces of it and it's okay. Not one I rush right out to get, but like all species it can surprise either way.
I have several limbs and a couple saw logs that have been piled aside for a few years. Recently a friend wanted to know what BL looks like so I sawed a few pieces off for him. The sapwood is punky, but the heart wood is still solid. Just for kicks I turned this little bowl from a limb piece.
Re: Black Locust
Brad Vietje
Re: Black Locust
Brad Vietje
I've used a fair amount -- turning only -- and I like it. It is exceedingly rot resistant, and quite hard. Sapwood will rot, but the heartwood won't rot in your lifetime. Used for pins and cleats on sailboats. Ancient Greek sailing vessels and war ships have been found at the bottom of the Mediterranean, and the only wooden parts surviving were the Black Locust cleats, which were almost as good as new. Turns well green, pretty well when dry, though a bit more brittle, and takes a high polish.
It has a nice, yellow-ish color when cut fresh, but tends to turn an odd, slightly green hue when it is fully seasoned. I'm convinced it would be a much more popular turning wood if not for this greenish cast.
Because it's so rot resistant, it's great for outdoor or garden implements. If you sell at a craft shop or farmers market, make up a batch of "Garden Dibbers" for planting bulbs, or stakes for marking garden crops, and it works very well for this.
Garden Dibber from on-line (not mine, but mighty similar):
I've turned bowls, vases, hollow forms, and loads of tops from Bl. Locust, and I may be in a small crowd that likes it quite a bit. Thin pieces might make great wind chimes -- seems to have a high pitch when pinged like a bell. If you have access to logs, and have the tools to cut it into planks & boards, you can make garden furniture that will never need replacement ;)
Another thing to keep in mind with any rot resistant wood is that there has to be a reason bugs don't eat it, so there's something toxic in there -- at least to bugs -- so it may cause allergic reactions.
Safe spinning,
Brad Vietje
Newbury, VT
Re: Black Locust
Black Locust???
Brad I would never have guessed that to be black locust. Must be a regional thing. That looks closer to, but still not quite like, honey locust.
Re: Black Locust
Jesper, Denmark
Re: Black Locust
Jesper, Denmark
Hard and tough and cantankerous when sawing into boards due to internal stresses. Turns well and takes a beautiful polished surface. The greenish cast disappears after some light exposure.
Totally rot resistant. You can leave logs outside for years and except for some end checks, nothing happens to it. The bark, which is toxic, rots away, but the wood inside stays fresh forever.
Re: Black Locust
Re: Black Locust
john Veerkamp
The only wood more rot resistant for fence posts than Black Locust is Osage Orange.
Re: Black Locust
Re: Black Locust???
Bill Turpin in WNC mountains
Black locust pictures for sure. Black locust can be pretty tough! I have seen it throw sparks from professional tree trimmer's chain saws. Green cuts fairly easy. Dry it gets harder and harder. Blk locust is a legume that sends out surface runners to propagate more trees. There are fence posts on our place that were installed in 1907. They were split from trees of about 12" diameter. A nail driven into green locust that then dries CAN'T be pulled. I can turn it, but wife gets sick if she turns it. The first bowl I ever sold was black locust. Watch the thorns, much shorter than honey locust. The 3/4" thorns kinda hide in the bark. Always wear thick leather gloves when handling wood. Common scrub trees growing on cleared land in Eastern Tennessee are red cedars. Same trees in Western North Carolina are black locust. Road cuts initially fill in with about 95% BL. Hardwoods come thirty years later. Squirrel's planting acorns are much slower. A few airborne seeds....then the runners. They are self fertilizing! They quickly take over and get about 3' apart. Our land was totally cleared in 1979, we have 20" diameter X 40' tall blk locusts all over our place. A brush with a hurricane about 10 years ago took down 24 trees on about two acres. You can't tell that any are missing!
Re: Black Locust
Re: Black  vrs Honey
Ralph Lindberg
Black Locust is Robinia pseudoacacia
Honey Locust is Gleditsia triacanthos
Both are native to the US, but they are really not closely related
Re: Black Locust
Re: Black Locust
George Hurlburt
I just recently turned some Honey locust, I think. Came from our local golf course. I slabbed some a few years ago and put it under the lathe to dry. I decided it was ready so last month I made some segmented bowls. They were an orange mixed color
Re: Black Locust
Mike Stafford
Which one is this?
Mike Stafford
I was told it was honey locust but someone else said it was black locust. I don't really know.
Re: Black Locust
Re: Which one is this?
John Jordan
That one is honey locust, Mike. It really doesn't change color over time and will keep those rusty and orange colors. One of my favorites.
John
Re: Black Locust
Mike Stafford
Thanks John!
Mike Stafford
That is what I was told originally. And you are right the colors have not changed.
Re: Black Locust
Re: Black Locust
robo hippy
Black locust is nice to turn, but because it is so hard, you have to go more slowly. The Honey Locust is a beautiful wood as well. I was used to the wild stuff that grows in the midwest and has thorns that grow up to 12 inches long, and I never saw any that grew more than about 30 feet tall and maybe 12 inch diameter trunks. The tame stuff, some times called moraine locust doesn't have the thorns. Both have long seed pods, and the seeds look like milk duds the candy. Some can react to the black locust, which is a type of legume. I have one friend that reacts to it when it is green, but not when it is dry.
A black locust fence post will wear out one fence post hole. Osage will wear out two...
robo hippy
Re: Black Locust
Re: Black Locust
john Veerkamp
A neighbor removed a honey locust from his pasture that was 60' or so tall and 42" diameter. I turned some lovely platters from cross sections from the center to the pith about 16" dis.
BTW an easy to remember way to distinguish apart. Black--big leaves little thorns. Honey--little leaves big thorns. Old boy scout days.
Re: Black Locust
Keith Tompkins
Re: Black Locust
Keith Tompkins
There is a HUGE honey locust in the city of Poughkeepsie NY that must be a record holder of some sort, covered with burls.
I saw a guitar made from black locust last year at woodsworkers showcase in Saratoga, NY, the maker claims it has similar sonic properties to rosewood.
Re: Black Locust
Re: Black Locust
Hugh Buttrum
Fresh cut Black Locust.....great stuff. Turn a bowl to finish - wet sand to about 220 - then dry slowly. It will move a little, but not too much. Makes a great rolling pin. Makes for a great carving mallet too. Something that has been down for 2 years might be too cracked by now.
I was told that way back when they made wooden ships - the pins in the corners were made from Black Locust. Hard stuff.
Powder Post beetles like the sap wood.
John Jordan shows the bottom of a Honey Locust vessel in his DVD.......beautiful....almost better than the top view.
Great firewood too. Lots of BTUs.
Hugh
Re: Black Locust
Re: Black Locust
Very hot firewood!. Locust makes two to three times as much ash as red or white oak. I do not know why.
Re: Black Locust
Re: Black Locust
Jeff Smith
The black locust I've turned machines beautifully green, but tends to move a lot on drying. I like it. It also responds nicely to fuming with ammonia - a deep, rich black with a slightly green undertone.
Re: Black Locust
Re: Black Locust
George Guadiane
Rosewood and Black Locust are related (fabaceae) so they may well have similar tone qualities.
Re: Black Locust
Re: Black Locust
robo hippy
Hmm, I may have to ask my guitar guy about that. They use rose wood for fret boards too.
With black locust fire wood, it seems to take 2 years for it to try enough to want to burn. It also is supposed to glow under black lights.
robo hippy
Re: Black Locust
Re: Black Locust
George Guadiane
Let me know what you find out.
G
Re: Black Locust
Re: Black Locust
Don in Central Illinois
Thanks Reed. I have a locust in my yard and could never determine if it was bkack or honey because it doesn't have thorns. Never heard of moraine locust. Will have to look this up, but at least I think I know what it is now.
Re: Black Locust
Re: Black Locust
john Veerkamp
Most ornamental locusts are hybridized to be thornless.
