Re: Drive centers
Bill Jacksonville, NC
Which way to mount wood on a lathe safely and give greater ability to achieve that design you have in your mind or let you design as you turn? Simple inexpensive MT-2 two-prong/spur drive center!
Before we mount a piece of wood on lathe (method used) have to think about WASTE ALLOWANCE.” Your waste allowance addresses both safety and design options! Waste allowance simply amount of wood you cannot turn or damage to wood you address before finishing the piece. Simple two prong/spur drive center affords both safety & design options with least amount of waste!
Own two different prong/spur centers one with adjustable point & one without. Bought years ago to replace crappy OEM four prong/spur centers and have served me well. Use the fixed two prong/spur center on dry wood spindle turning and adjustable point center on heavy wet wood. Only real adjustment can make is loosen hex screw to remove point from drive center to straighten or sharpen.
My favorite two prong drive center bought from Craft Supplies before they had the Precision Machine 2-Prong Drive Center.
