200+ woodworking book reviews
Old Maple Bowl
Old Maple Bowl
Chuck Jones - West TN
Old Maple Bowl
Today my wife and I somehow ended up rummaging through the loft of an old building on our farm. Amongst tons of other useless things from our past, we found this 15" bowl. We remember buying the bowl somewhere in Vermont while we were living in New Jersey. That makes the bowl between 34 and 41 years old.
It was quite dirty and moldy so I took it to the shop and cleaned it with warm water and 4-ought steel wool. I then noticed these unusual tool marks, very fine lines, almost imperceptible to the eye or touch, radiating from the center bottom to the rim, both inside and outside. They are too consistent to be hand made, or made using a hand held power tool.
So my question is, How did they do it?
Any one have an idea?
The bowl appears to be hard maple, so it's unlikely they imported these bowls from the Caribbean or such.
I can envision a contraption holding and rotating the blank into a huge circular saw blade to hollow the bowl. But what about the outside?
There are straight marks across the bottom where a flat spot was created for the foot.
Re: Old Maple Bowl
Re: Old Maple Bowl
wow don't know how that was made. I cleaned an old bowl for my mother that was her grandmothers and it had very fine lines from tool marks but they were in the normal direction turned while the bowl was spinning and probably by machine. Your bowl has me perplexed.
Re: Old Maple Bowl
Mike Stafford
Re: Old Maple Bowl *LINK*
Mike Stafford
I can only speculate that the marks you are seeing are sanding marks created with a belt sander. This link to a video on YouTube shows a mass manufacturer of wooden bowls sanding using a belt sander to sand the exterior and interior. This sanding occurs at about 3:45 in the video.
I could envision an older bowl such as yours which was sanded in the manner shown in the video but not sanded as finely having scratch patterns similar to those you are seeing in your bowl.
Then again I could be entirely wrong.
Factory Bowl Turning
Re: Old Maple Bowl
What Mike said.
Re: Old Maple Bowl
Belt sander!
Jorge
Chuck,
I could not find it now, but I've seen a video of an ancient bowl mill (1700"s) where first they core huge blanks, then after letting them dry they sand them with the mother of all sandbelts. Amazing that they are still operating.
Re: Old Maple Bowl
Re: Old Maple Bowl
walta
I think the marks are from a saw blade or fly cutter.
Look at this bowl my father in law picked up in his travels
It has the same marks but the form is too complex for a sander.
There is no finish work straight from the lathe to retail.
Walta
Re: Old Maple Bowl
Entirely plausible
After watching he video this morning I figure this is an example of how the speed of one's internet service affects one's knowledge. I'm impressed that some of you saw, remembered, and in Mike's case was able to retrieve a link. (Probably cost me an additional $10 on this month's Verizon bill.) >(
Thanks for the feedback. It really had me puzzled.
Now. I'm not feeling so good about the existence of such an operation. I've spent about twenty hours over the last week processing, rough turning, and storing a half dozen large bowls. Darn, I could have had a set up like this. :D
Re: Old Maple Bowl
Re: What Mike and Don said.
Mike Foster
I've seen mills here in VT where they did this. Only one bowl mill running in VT these days.
Re: Old Maple Bowl
Brad Vietje
Re: Old Maple Bowl
Brad Vietje
I think Mike has the right process, but if the bowl came from VT it was very likely produced at the Granville Bowl Mill (www.bowlmill.com), which is still in operation, or the Weston Bowl Mill, which closed in 1996.
I've seen a video of the process at the Granville Mill, but wasn't able to find it just now in a quick YouTube search, but the sanding process is just like the Holland Bowl Mill in the linked video.
Safe spinning,
Brad Vietje
Newbury, VT
Re: Old Maple Bowl
terrifying
Rum
The way he mounts that blank. Yikes!
The log->blank cutting setup is pretty sweet though, heck of a lot faster than my chainsaw work!
Re: Old Maple Bowl
Re: Old Maple Bowl
Barry L Elder
Velly Intellesting! ;)
Re: Old Maple Bowl
Re: Old Maple Bowl
Doug Trembath
Chuck, there is a bowl making family in New Brunswick CA that uses bicycle wheels and tires with sanding belts to sand the bowls for finishing. That, or something similar could well be the process used in your bowl. The scratch pattern seems to be consistent with something like that.
They make a lot of really nice kitchen bowls, and the finish was much finer than yours shows..
Doug Trembath
