Re: Thin Turning Advice
Craig Daymon
I have a bowl that was turned by a turner, Mike Kutterbach (I might not have the spelling right), that is about 1/16" thick. (I might even have a bit of a video showing him making one, but can't get to it right now.)
As others have mentioned, sharp tools are essential. If you are seeing chatter, that will likely prove challenging to get past now that it is relatively thin, but not impossible.
If you are turning the inside, I frequently support the outside with my hand to reduce vibration/chatter. Going thin does require working in much the same way as creating a hollowform, reducing the inside to final thickness in steps. The thinner you plan to go, the smaller the steps.
The turner I mentioned would start by shaping the outside, then getting a smooth curve on the inside, matching the outside. He would then create a jam chuck, reverse the bowl, taping the (thicker) lip to the jam chuck. (I forget if he ran a light through the headstock to light the inside, which would be helpful. LED being best for this.) He would then finess the outside with a cabinet scraper to bring it to final thickness. OUTSIDE ONLY for the cabinet scraper, as the scar on my wrist can attest!
You might also keep a spray bottle of distilled water near to wet the surface as you work, especially if using a light to illuminate it.
Hope some of this is helpful.
