I had bought this marking knife kit from Czeck Edge at the last WIA,the wood is white and black ebony. I used my old Jet mini,I bought it back when the color changed to white from blue. It was a fun quick project. The other knife is for perspective.
Most serious woodworkers use a marking knife to scribe a line on the wood instead of using a pencil. The line is thinner and makes your marks more accurate.
Isn't language grand? I took a test in high school shop that was to name a hundred tools. I was one of the few that did well because I thought some of the names were quaint and arcane. Did you know that the drill bits in a typical index are "straight shank twist drill bits" and the ones that have the reduced shafts on them so they will all fit a 1/4" drill are "straight shank twist drill bits, constant diameter". Wish I remembered something more useful.
Odd that Mark bought a kit for a marking knife and ended up with a striking knife.
