Chainsaw and bowl blank prep
robo hippy
Another clip from me, and I should have another up on bandsaw blank prep soon.
https://www.youtube.com/watch?v=F3s6aN9REIY
robo hippy
Re: Chainsaw and bowl blank prep
Phillip Medghalchi
Thank you Reed, it was very informative. Nicely done.
Lee Tourtelotte
Robo -- Very Good Job on the Video!
FYI --
Log Processing Center project -- Our Minnesota Woodturners Association club recently had a project making "LPC's" for our members to purchase at cost. What is an “LPC”? It is a “Log Processing Center” for “safely” preparing bowl blanks for the lathe. It is a waist high stand that holds the log securely while comfortably cutting it in half, along the log’s length, with a chain saw. The unit was recently demoed to the club with the offer that volunteers would make them in kit form, available to the club members at cost, if there was interest. We immediately received orders for 30 units and our members paid $30 each -- which included all the self-tapping screws and complete assembly instructions.
The LPC "safely holds" any size log so that the chain saw can both cut the log across the grain to length, if needed, and then longitudinally, cut the log in half. It eliminates the inefficient struggle of trying to cut the log down through the end grain.
Our MWA “LPC” is a variation of one that Emmett Manley of Lakeland, Tennessee originally designed, built and described in the June 2010 AAW magazine. Our version has a few improvements that allow for a wider range of varying sized logs for processing bowl blanks safely. (Emmett has since advised that he has incorporated these improved features into his LPC.)
The reason the device works so well is that when cutting the log in half, as the chain saw bar passes through the center of the log, the kerf behind the bar begins to close, keeping the chain saw from binding as it finishes the cut. In addition, the saw drops free of the log into the gap between the vertical side boards so the saw never hits the ground or other wood as it finishes.
An “optional” trim shelf can be added, which allows the cut bowl blank to be positioned securely in a simple pop up cradle for trimming the blank's corners at 45 degrees with the chain saw.
Pictures and plans are found on our club website for anyone interested.
Lee Tourtelotte
www.mnwoodturners.com
Sergio
Lee, I would be very interested in the plans of the saw horse you mentioned but could not find it in the internet address you posted. Any other way to see it?
Thanks
Lee Tourtelotte
Sergio - Send me an email and I can send you pictures, description, plans, etc.
my email address is: leetourtelotte@msn.com
(I tried , but wasn't able to post my LPC pictures on Wood Central.) -- Lee
Jim Pugh
What kind of chain are you using?? Would that be a ripping chain?
robo hippy
I am not positive Jim. I think they called it a skip tooth chain. I have seen others that have probably twice as many teeth, and if chainsaw chains are anything like table saw blades, then I have a ripping chain. It does cross cut with no problem.
robo hippy
Bill Jacksonville, NC
Totally enjoyed your video!
With little research will find angle ground on teeth separate cross cut from ripping chain blade. Ripping chains more for chainsaw mill, than regular handheld cross cut chainsaw; see link;
http://www.oregonproducts.com/pro/products/chain/ripping_95R.htm
For the amount of ripping woodturners do with electric/gas chainsaws OEM chain works well.
When conversation turns to building and using “LPC’S,” aka SAWBUCK, nonsense getting too deep for me!Can make sawbuck simple or elaborate as you want just search google images for ideas!
barry rockwell
Re: Lee Tourtelotte's LPC
Barry Rockwell
I assure you, Lee's LPC is anything but a "sawbuck" and makes cutting logs MUCH safer and easier than you can imagine. I use it constantly and everyone who has seen mine has built one for themselves. I added a handle and wheels to mine because it is quite heavy. I'm surprised that the plans haven't been published in "American Woodturner" or some other publication yet Maybe I'll ask Lee if he would let me submit it for publication because it is good enough that every woodturner should have one.
My problem ripping...
Bill Howatt
I find the biggest problem with ripping is the long "shavings" get around the drive sprocket and jam up tight between it and the guard.
Is there a simple solution to this?
Bill
Steven Antonucci
What I do
steven antonucci
Set the brake
Pull out shavings by hand from underneath
If the chain is frozen, undo brake and then use the log to run the chain backwards around the saw until it moves. Usually only takes about 3-4"
Finally, run the chain to clear the rest.
Whole process takes about 15 seconds
Re: My problem ripping...
George Van Beynen
Bill, when possible I try to cut at an angle closer to 45 degrees than parallel to the grain when ripping. This method produces shorter shavings and prevents the problem you mentioned.
robo hippy
My little electric saw jams up almost instantly when I rip, no matter the angle. The Husky I am using, generally keeps going, even if I am dead on parallel to the grain. The only time it clogs up is when the pile of shavings on the ground piles up to the level of the ejection port on the back of the saw. If you increase the angle, say 30 to 45 degrees, this is much less of a problem. The bigger more powerful saws seem to have more inside clearance, and the added power just pushes stuff through. Like Steve said, set the chain brake, then pull the jammed shavings out.
robo hippy
Lee Tourtelotte
Barry -- Thanks for your much appreciated "reassurance" of the LPC's worth, and the picture you posted of it for all to see. I just emailed out the plans to four more woodturners who responded today from Wood Central and requested them. We have now probably shared our MN Woodturners LPC design with over 100 woodturners nationwide, all who are motivated towards cutting bowl blanks safely. If you want to submit the device for any future magazine publication, please feel free to do so, with my best regards, -- Lee.
modify the cover
Dick Coers
My Stihl is worse than the big Husky for plugging up with ripping curls. I clipped off the back corner of the cover on the Stihl to get a more direct path for the curls to get out, and it increased the opening size as well. Everything is still covered. It is definitely an improvement.
Simple Sawbucks  *LINK*
Doc Green
In the following article I describe much simpler sawbucks that may be appropriate for someone who has limited space. The simplest version consists of two stakes driven into the ground with a board to keep your saw out of the dirt.
http://www.docgreenwoodturner.com/sawbucks.html
Sawbucks
Steven Antonucci
great tip!
Barry & Lee, do I see nails or screws used in the top in the picture of your LPC? At the web site photos of log stand hard to tell. Never found plans, most of my sawbuck similar to those shown in Doc’s link/article.
While have no problem with design, would have if using nails or screws anywhere chainsaw can come in contact with metal!
Have built and used many simple & elaborate sawbuck models over the years never used any metal fasteners anywhere. Through my own stupidity or weather exposure none lasted more than a year or two.
So a simple stump and some boards like Reed uses in his bowl blank prep demo work for me.
Brad Vietje
Brad Vietje
Nice video, Reed, but not the way I would have cut it.
I look to find the shortest distance from pith to edge, mark that, and make my cuts at 90 degrees to that line. That way, the pith and the growth rings are most centered on the blanks. In other words, when cutting close by the pith, those early growth rings are pretty close to the center of the cut face.
It may be a more boring look, but I like the symmetry and the "H" shape at the bottom of the bowl, as well as having a balanced profile for natural edged bowls.
There are many ways to skin a cat, and I remember seeing Richard Raffan cut logs in all sort of odd ways and get some fine looking pieces out of them, so I am certain that my way is not the only "correct" way to do it!
Safe spinning,
Brad Vietje
Newbury, VT
Phillip Medghalchi
Brad, it all depends on where the cat is from. :D Persian cat are fearce and long haired so you have to fenesse with it.
Keith Tompkins
Keith Tompkins
Brad, there is certainly more than one way to skin a cat but.....any way you do it, don't expect him to like you. :D
Thanks
Bill Howatt
Thanks for the ideas. I'm going to have a look at the cover and see if I can modify it as a first step.
Bill
