Hanging flexshaft motor carrier
david
Just got my new flexshaft motor with a hanging mount and am looking for ideas for how others have devised portable carrier mounts. Looks like an IV pole would do the trick, but how about something handcrafted?
Thanks in advance for your solutions.
Re: Hanging flexshaft motor carrier
I made an X shaped stand out of 2x4 withe a central column that stood up about 3 feet. The. Stick a piece of 1" conduit on that. I put a 1x2 cross bar on that. I have bent nails that hold 2 flex shaft machines and 2 or 3 Dremels depending on what I'm doing.
My biggest problem has always been how to get the dust collector hose close enough to the carving to collect the dust. Rotary carving and sanding produces huge amounts of dust. I often wear a mask especially when I'm power sanding the carvings
Josh Bowman
I bought an after market pole with socket that screwed to my workbench. Then turned down some aluminum so the pole would fit in my banjo as well, so I can use it at the lathe.
Now that's a good idea. It would not be hard to fit an adaptor onto my conduit so that it would fit in my Banjo and also the Bestwoodtools articulated carving tool base that fits on my workbench. Then I would have my rotary tool carving hanger just about anywhere in the shop.
I've used the rolling base of office......
JamieDonaldson
...chairs for several such applications. They are cheap at recycle stores and usually heavy enough to support a tall center load on a piece of conduit.
Thanks for your input on this matter...
