My girl friend and I picked up a bunch of walnuts today. The only way I know to hull them is lay them in the driveway and run over them for a while. Of course my driveways didnt matter. Hers is gravel but very nice. I don't think she wants that mess. Anyone have another option.
I just lost a detailed plan for hulling walnuts. It is out in cyberspace somewhere, but here is a synopsis:
Make a trough out of 2 X 10s. Back your vehicle into the garage and jack up the wheel to go into the trough
And be sure to block the front wheels.! !
Lower the wheel to give it a little less clearance than the diameter of the walnuts and slowly pour the walnuts into the trough in front of the tire and watch the mostly hulled nuts fly out into a big box (like appliances come in) and all over the place.
This works best if the engine is running and the wheel is turning slowly.
We found it best to have a shield to protect the nut pourer from bounced back nuts.
This system makes a big mess, but it is a FAST mess and we could husk two bushels of walnuts in 30 minutes.
Many years ago back in the hills of Tennessee, I used two different methods. The first is the direct approach - lay the walnut on a fairly big rock and then hit it with another smaller rock to split the hull. Then pull the hull apart and pull out the nut. With a little practice you can get pretty good at judging how hard to hit a particular walnut so you split the hull on the first lick but do not smash the nut.
The second method required a board 2 or 3 feet long with a hole or two bored near the middle. Size the holes to the sizes of the nuts. Lay the board horizontally across two supports. Place the green walnut over the hole you judge to be the right size, and then hit it with a hammer to drive the nut through the hole. Most of the hull will remain on top of the board. Again, it takes a little practice to get good at it.
And you know that you have to spread them out to dry after you get them hulled. If you just put them in a bag, bucket, or box, they will go bad and all your work will have been in vain.
The walnut cake at Christmas made it all worthwhile. Those were the days!
John, When I was a kid, some 70 yrs ago, my bro and I bagged up 15 burlap bags of nut, dragged them to the horse drawn wagon, unloaded them in the barn and ran them thru the hand-crancked corn cob machine. We ended up with all those nuts clean as a whistle and $9 and thought we were rich! P.
My grandfather used a cement mixer. Couple scoop shovels of rock, walnuts and water. Pretty sure he let the water run and the hulls floated out. Bad nuts floated as well and washed away.
The husk of an English (Persian) walnut (the kind you buy in a grocery store) naturally dihisces when it is ripe/dry, but I don't think that is true of black walnuts or butternuts.
Turn on the water and throw one in. When it stops growling and starts ticking, it's done. Turn it off, pull out the cleaned nut, turn it back on and throw in the next one. On a lot of them you get lucky, and the disposal spits them back out into the sink when they're clean. If you're quick, you grab them in midair before they fall back into the sink or onto the floor. I don't do it that way any more because I'm not hooked up to city sewage. It's kind of slow, and it works better if you have a small fist, but there's no mess. Do it alone. A helper might get excited and turn it on at a very inopportune time.
Did the same thing in college except I'd put 7 (I think) at a time. Like William said they came out clean. Sure beat using the old corn-sheller.
Only problem - a shell would chip & the chip would get caught under the blades sometimes. Make sure you have the wrench/key thingie to get it going again.
