ADVERTISE HERE - FREE TRIAL
Trend faceshield battery
Don in Central Illinois
Where can I purchase another battery for my Trend airshield? I looked on Packard but I onky saw a newer style.
Re: Trend faceshield battery
R THOMAS
Don I had to rebuild mine I will try to find the battery vendor info and get it to you if I remember it takes2 -1.2v -5000mah battries you will have to soider each wire to each end works better than the one that came with it .
phillip Medghalchi
Don, we have Batteries Plus store here in San Antonio, TX that they rebuild battery packs and then new ones they put in has more amperage which is supposed to hold up longer and better, look them up or loo up for Battery repacking or restoring around you. If yo live close to any major cities I am sure you guys should have an outfit like that, if worse comes to worse, you can send it to me and Ill be glad to have them repack it for you if the casing or the model is the problem to come by. I have to take lots of my Dewalt and craftsman battery pack and have them rebuild it for me let me know soon so, I can tell them you are sending me yours. they offer multiple repacking discount that I can share it with you just have to tell them how many are coming so they know how much discount to offer. Like for my Dewalt I am giving them 4 battery pack and so they take two and reapck it quickly, but then when all 4 or all of the batteries I have are repacked then I get the total discount.
phillip Medghalchi
BTW, I am considering to buy this trend air shield face mask, is this problem common with them. this qsn. is towards all of you turners who own this unit.
Would you still buy it or would you suggest a different Air filtered mask.
Please reply before Aug. 21 st so when I go to SWAT I'll know ahead of time.
I bought mine used and would buy it again. I just want a backup whenever one runs down and I don' t want to wait for it to recharge. Patience is not one of my virtues.
Dwight Rutherford
Don,
Sent a PM
phillip Medghalchi
Don besides your patient, how long is the run time of one of these guys that you can not wait to charge? Are you a production turner that you can run one of these guys down in a day?
Darryl
Don do you have the pro or the older style? If you have the pro there is a simple charger that you can get that will charge it up in about 2 hours and turns off unlike the trend charger. If you have the pro let me know and I'll send you the info. Cost about $20 or less.
Darryl
Don I just went down to the shop. If you have the Trend Pro that has the flat black unit that charges in the helmet or in a charger this will work. It is made by Tenergy. It is their "Universal Battery Pack Charger 2.4V-3.2V with current Selection and temperature Sensor". I think I found mine on Amazon. I made a simple wooden box like structure with the leads soldered to a spring like clip. I slide the battery into slots in the wood sides and that's it. Simple to make and as I said will fully charge your battery in less than 2 hours and then shuts off. I can probably send you a picture if needed.
wherever I got the idea also gave an explanation of how to rebuild the battery pack. I can probably find the reference if that would be useful. As far as buying a new one I have not been able to find a source other than Trend. I guess you could make a case and use the rebuild instructions.
Air-Wear-America  *LINK*
link
It doesn't seem to last but about six hours, but I haven't really timed it. Just seems to wear out before I do.
The older style where I have to unplug it from thr helmet and plug it into the charger.
Re: Air-Wear-America
phillip Medghalchi
Ralph is this the newer version? Or the other one which is little bulkier?
Stuart Johnson
Depending on your work habit and shop layout why not buy a transformer with the same output as the battery. Wire it direct and skip the battery? It could be clipped to your belt with a plug for when you need to go to a different part of the shop.
bulky??
Darryl
Depends on what you consider bulky. I've had both and prefer the pro. It is a different fit and better filtration.
that is not the pro version
Darryl
there is a place that rebuilds the batteries. I did it when I had the older version. Cost darn near as much as the Trend but had more amps so lasted longer. I don't believe the Tenergy that I suggested will work but I can't remember the fittings for the other version. I have a hunch that there is a charger that would be better and faste might give Tenergy a buzz they have a bunch of different chargers.
The root problem is the charger
Chuck Jones - West Tennessee
I think others have touched on this, the usual reason the Trend Pro batteries go bad is that the cheap a$$ed charger they supply does not shut off after the battery is fully charged. I rebuilt my batteries and bought the Tenergy charger and have had happy sailing ever since. Cost was less than reasonable. It's a little cumbersome but worth the hour or two it takes. There are detailed instructions on Sawmill Creek but they are hard to find. I have copies on my other computer and will find them when I have a chance. My wife has the other computer tied up and will bite my hand if I try to take it.
Ralph Lindberg
I take it you didn't go and look
That page is all for the original one, not the Pro.
We won two originals, four batteries and two chargers.
Chuck Jones - West TN
Link to Ketell Thread *LINK*
I'm unable to find my copies of the articles but here is a link that with a little hunting will get you to the same information I worked from.
I simplified the battery charging base. I already had the Trend extra battery and standalone charger base. I simply cut the wires and tied it into the Tenergy charger.
Greg Ketell Thread
phillip Medghalchi
i did check it out, I a not getting you said" We won two originals, four batteries and two chargers" ? What do you mean you won? you entered some kind of contest, and you won all them gadgets? YOu are lucky.
Thanms Ralph. The A4 is what I need abd the price is reasonable. Thanks to everyone that offered suggestions.
try these people
Darryl
Don I had a 3M battery rebuilt by these folks. The price was about right and the amps much higher in the rebuilt. Primacell Gunard Associates Inc ph 814-623-7000 www. primecell.com
Re: try these people
phillip Medghalchi
OK, guys, do you suggest me buying this thing or what should I ask the vendor, or you don't think they remedied the problem yet and still the same.
