I'm playing with Cold Bend hardwoods. This comes from the factory wet and compressed. You bend it without heat or steam, just bend it around a form or even without a form if you want. I built a form for this. When I finished with it and it was dry the curve wasn't quite what I wanted so I heat bent it using a hair curling iron. So this is a combination of cold bending and heat bending.
It's Walnut. I turned a bowl and base from some of my regular walnut. The bowl was a twice turned bowl. It's held together with Brass rivets. The bowl is about 8".
Don't know for sure but it comes wrapped in plastic wrap and they talk like it will store for a while if you put it back in the wrap after cutting it a piece off. Its not sopping wet but I would think there is a possibility of mold if stored for months. I will find out because I won't have time to use all of it before starting my cancer treatments so it will sit for a while.
