I need a reliable remote controlled on/off switch that will work on my Jet 1100 dust blower? I have burned out two X-10 Pro controllers that were supposed to be rated for a heavy duty motors. I have a new one the supplier sent as a replacement, but no sense in putting it on. The others have lasted only a few weeks.
The blower motor is 1 1/2 hp, 230 volts, 5.5 amps.
Found one at PSI called "Long Ranger" that's supposed to work. $120 which is way more than I paid for the X-10's. Anyone know whether the Long Ranger is any good? Any other options?
I have the Long Ranger version that uses the micro switches on the blast gates. Specifically sold as rated for a 1 1/2 hp motor. First controller failed during the warranty period. The replacement failed promptly but outside the warranty. Took it apart and found the actual controller was rated for a 1 hp motor. I went to a local used industrial tool dealer and bought a heavy duty controller and put it in line to control the motor. So, the light weight original controller controls the heavy duty one and its been going fine for years. The used controller cost ten bucks.
chuck I've been using the 220v lone ranger on my Grizzly 2300 cfm dust collector for about 4 months now. I used the 110 version on my old collector for about 8 years. Must have dropped the remote a gazillion times and it still worked every time. I would recommend it.
I use an x10 220 volt appliance module. The first one stopped working, the replacement works fine about 95 percent of the time. When it misbehaves, I find I usually just have to keep the remote button depressed for a few seconds before it will kick in. On rare occasion, unplugging then replugging the module at the dust collector does the trick. Odd, but it works for my system.
I have been using the Lone Ranger for over 10 years on my 3 hp Oneida system. Only problem I had was losing one switch in the shavings. I now have 2 switches, and the one in the turning room stays on a clip rather than on the bench or in my turning smock. I did have an electrician install it.
I've had the Long Ranger III since February and it's done what it's suppose to do. It's on a 2hp 220V Grizzly + Oneida SDD. Bought it on Amazon for $76.99 + free ship with Prime but was shipped from PSI.
I have the iVac Pro with a separate switch for each machine (110 and 220) that switches the collector on when the machine comes on and switches off an adjustable time after the machine shuts off. I also have a pocket remote. They are connected to an Oneida 3hp 220 collector. They are not inexpensive, but they seem to just work after two and a half years. I am quite pleased with the results.
Which is NOT to be read that my shop is EVER clean ... sigh. Cutting frames from MDF on a router table is beyond the capability of any dust collector - or at least mine. I made nine of them roughly 30 X 25 yesterday and have a coating of tan talcum powder on everything. It did make nice frames though.
I have had a long ranger for going on 11 years on my 1200cfm 220v Delta dust collector. I've been using the Woodcraft basically the same thing for my Vac 110v for 9 years no problems with ether.
When I redid my shop I put my dust collector in a room away from me. I wired a switch on the wall right next to the lathe.All I have to do is reach over and turn the collector on.
I appreciate your help very much. I remember the Lone Ranger, and Tonto, and Silver, but I had not heard of the Long Ranger. Kinda funny how many folks typed it wrong in these responses.
