Re: *** SURVEY: THE IDES OF JULY ***
kvaughan
I have been on a 15 year journey with arthritis in the ankles. Arthritis and corrosion never sleep.
My turning methods have migrated with loss of ankle joints to the point that I do almost all my lathe work perched on a swivel stool. That has meant that most lathe technique based on use of legs, and body movement cannot be done. The techniques of turning with only upper body movement are very different and I suspect each of us caught in that environment is learning for ourselves.
Most literature I see is of normally able trying to use a "sit down" lathe. Kind of like watching some one who walks try to play basketball while in a wheelchair. You can tell that nothing works well and the flow is not there.
Turning while seated is a slower process for me. Sitting out of the line-of-fire presents different approaches. Tool handle lengths need to be shorter, and shorter effective tool length helps. I have migrated to interchanagable handles so I can slide more tool into the handle as an example. Cuts need to be lighter. Smooth flows of movements have to be translated into a different sequence.
"Carbide is for us cripples" makes real practical sense when walking to the grinder is no longer a casual practice that takes just seconds.
I am driving a Stubby most of the year and a shorter bed is good for turning from a stool. The Jet 1014 I use while "snowbirding" works well from a stool also.
Perhaps more discussions about limitations in mobility, adaptive techniques, and different techniques focused on upper body movements will be coming in the future.
