Attached is the cutting diagram that I intend to use for the thinner half of the pair. I believe that the figure will be best maintained when the face you see is the bottom of the bowl. This of course makes them both natural edge. The other half is thicker and may offer the oportunity for a hollow form as Lyle suggested.
Looks great. You would not have to make a natural edged piece, but you certainly could. There's no reason you couldn't make a pair of shallow platters/plates with a raised rim facing away from the cut surface shown. If deep enough, that would run into sapwood and/or the live edge, but if kept shallow, you might have a very different look.
I'm partial to both sapwood and natural edges, but that can make some items harder to sell or to use. Also, fresh-cut Walnut has a really nice contrast between dark heartwood and almost white sapwood, but if it has been sitting too long, the sapwood turns a muddy brownish-grey. Walnut bark also tends to be thick and fragile, so like Lyle mentioned earlier (pretty sure it was Lyle), you can remove the bark and still get a very nice bark-less natural edge.
Black Walnut also has really cool-looking bark, with lots of interesting dark/light banding and a fibrous inner layer, so sometimes I do leave it on, but these become purely decorative items for display only -- just too easy to start knocking off chunks of the bark if used much.
Agree that the face you see should be at the bottom of the piece, but I would attempt the largest piece I could achieve and try keep the rim as low as possible, because the further you go from center (in this case the bottom), the feather figure will be gone. I have even opted for a portion of the rim missing in going larger, because the void in the round perimeter can be an interesting aspect. Your piece, your choice, of course.
Steve, I agree. I have allready cut off the "waste" and saved it. I know I can get at least one real nice high aspect hollow form, some pepper mills, or bottle stoppers, etc. Some of it appears to have some nice figure. Thanks. Ron.
Ron, Thanks for keeping us informed on your progress. The diagram is very helpful in understanding how to position the bowls/platers and miss the pith.
Walnut responds really well with the use of lemon juice to keep the heartwood/sapwood contrast. It will not stay white white but lemon juice on the finished surface will keep it from getting as dark as left alone.
Thanks for the Lemon juice info, Lyle; I have not tried it on Walnut.
As for the shape that preserves and features the most and best of this figured wood, the flatter the better.
To make a natural edge bowl, it seems there are two options:
1. Curve the outer profile (away from the figured wood) to make an attractive shape, or...
2. keep the bottom as flat as possible and as wide as possible, then turn upward to reach the bark edge.
The first option results in a nice profile and attractive bowl, but with a much smaller area of figured wood across the bottom, while the second option will probably result in a very ugly shape, like a figured, natural edge dog dish.
Third, Much Better Option: If the log is thick enough (appears to indicate 7"+ at one end?), I would carefully consider a 3rd option: cut a slab for a beautiful figured (nearly flat) platter -- maybe 6/4 to 8/4 or a little more, and then make a beautifully shaped natural edge bowl with the remaining bark-on piece. If you get some feather/crotch figure in the bowl, that's a bonus; the platter will be spectacular.
I have followed Lyles advice and took the route of smaller and better. Brad, yesterday I did exactly as you suggested on the smaller (ca 9" piece) and got a real nice highly figured bowl about 8.25 dia and about 2" deep. The figure went all the way across the bottom and up both sides. You are right in that it was about 7.25 " thick at the start. After I cut the grass I will do the "upper" NE bowl and see what comes of it. I will post a pic after it dries and I get some lacquer on it. Thanks for the continued counsel. Ron.
If you blow out the free water in the sapwood after you are finished turning, the sapwood will stay white-the moisture supports fungal growth and you will get fungal staining over night.
The lemon juice will remove the black/blue stains that come from the iron in your tools reacting to the tannic acid in your wood. If you keep you hands off the piece while you are turning, you won't get these stains. It wont remove the gray stain from fungal growth.
If you let it sit around with the sapwood wet, you will get the fungal staining which will not go away, even with bleach. Better get that turned.
