Disaster Barely Avoided
Stuart Johnson
Yesterday I was trying to fix an outside faucet. It was a little hard to unscrew but after some extended slow pressure it started to turn. After a bit it was seemed to be unscrewed when I pulled it out I found I had not unscrewed the fitting. I had twisted the copper pipe right in half. This lead to opening the wall (utility room so not bad) only to find the interior pipes had been twisted and bent in order to make up for a three inch offset. Off to the local hardware store only to find out they were out of 1/2 inch couplers so I had to make an 20 mile round trip to the borg.
A semi disaster happened when I was sweating the fittings. Somehow I caught the layer between the brick and frame on fire. A squirt from the fire extinguisher and all appeared well. I turned on the water and had a major leak so I decided to just cap and tackle it today.
After dinner I was just getting ready to sign into the chat room when my wife told me she still smelled smoke and did I think it was just left over smell. I went to check and could not see any smoke or embers but part of the backing did feel hot. I poked around an broke off a piece and sure enough it was smoldering on the inside even though the outside was wet. I was able to set down everything and then cut several inch out back away from the hot spot.
I hate to think what might have happened if she hadn't notice the smoke smell. Needless to say I didn't make the chat session and neither of us got a lot of sleep because of checking on it every so often.
The plumbing part of the job is now finished after I used Shark Bite connections. No more soldering in walls for me.
