I was out doing yard work yesterday and saw a maple limb that we took down about a month ago.
Thought it might make an interesting bowl, have to thank you guys for looking at it as something to turn instead of burn. Here are some pics of the finished bowl, it's sanded and ready to finish once it dries.
Excellent use of that chunk of wood! Nice crotch figure across the bottom -- inside and out.
It may decide to crack along the pith that runs along the bowl for a short stretch, so you could try a little CA in there, being careful to avoid staining the wood to either side.
I was going to suggest the same thing as Brad - spray some lacquer over the area to be glued first, apply the CA, let dry, and then sand away the lacquer. This helps to avoid bleeding of the CA glue into the surrounding wood and eliminates the undesired staining from the glue.
Forgot to recommend writing the species of wood along with your name, date, and serial number on the bottom. Many people routinely ask for the "kind" of wood if it has not been included.
Just got in from my spring yard work, after reading your replies I checked the bowl and a small hairline crack was starting. I took it down to the shop and CA glued it. I'll let you know in a couple of days if we saved it.
I suggest you take any turned green wood bowl and put it in a paper bag sealed by folding shut and putting clothespins on it. Leave it in there for 2 - 4 weeks. The paper bag limits how quickly the wood can lose moisture and may help control cracks while drying. Even so, open the bag several times a week and look for cracks that can be glued. Much better than just letting the bowl sit on a shelf right after it's turned.
